Question about Pentax K1000 35mm SLR Camera
Viewfinder It's dark when I look through the camera's viewfinder. Could it be a low battery?
Presuming the lens cap is off, does the camera function normally in other ways, or has it jammed? If it's jammed, then the mirror tensioning lever (cocking lever) has probably slipped of it's catch lever (trigger). That can happen if the camera is dropped or jarred after it's wound and ready to shoot.
The repair requires no new parts and only takes a few minutes, but it does require removing the bottom cover. It's quite simple to someone who knows the cameras; however there are a lot of little parts in there so it can be a daunting task for a first timer or someone with limited mechanical skills.
Surf the net and you will find downloadable copies of the Pentax K1000 Service Manual. Here's one site: http://www.robertstech.com/manuals.htm. Scroll down the page a ways until you see some available service manuals. Click on the K1000 Service Manual.
Read pages 8 thru 10, starting with "Removing the Bottom Cover". You will need a couple of small, jeweler's screw drivers, one Phillips to remove the bottom cover's screws, and one straight to carefully pry off the E-clip that retains the Catch Lever. A small needle nose pliers may also be helpful for removing and replacing the E-clip.
Remove the bottom cover, remove the E-clip retaining the Catch Lever, remove the Catch Lever far enough that the Mirror Tension Lever can be moved back to where it belongs (the shutter will probably fire when you do that... that's okay), replace the Catch Lever, replace the E-Clip, replace the bottom, go take pictures.
Good luck
Tim
Posted on Oct 28, 2008
You have the lens cap on.
Posted on Oct 20, 2008
Viewfinder is dark until picture is taken.
Have you tried pressing the display button ? It should switch from LCD to viewfinder.
Jan 26, 2013 | Canon PowerShot G2 Digital Camera
My viewfinder went dark on me while taking pictures last night. The camera still takes pictures fine, but I can not see anything in the viewfinder. I see an 1842 on the screen when I first turn on the...
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Feb 27, 2010 | Canon PowerShot SD1000 Digital Camera
Have you tried pressing the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Feb 17, 2010 | Canon PowerShot SD1000 Digital Camera
I recently purchased the D80 and had no problems, it worked great and took magnificant shots. However, the other day I turned it on and the viewfinder was now, dark and out of focus. The battery was fully...
Check the mirror. The image you see in the viewfinder comes through the lens, and is reflected by the mirror. If it's dirty, it will affect the image you see. When you take the picture, the mirror lifts up, the viewfinder image is interrupted, and the light from the lens goes to the image sensor. So...if the mirror is dirty, the picture will be fine but the viewfinder image will be dark or out of focus.
Jan 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
When I look through the viewfinder, everything is dark....
First remove the battery. wipe off the battery contacts. reinstall the battery. Battery may be weak, replace.
If that fails, remove the lens. See the mirror in there?
If its stuck in the up position, you can return it by hand. But I recommend a toothpick. It won't leave fingerprints.
Oct 04, 2009 | Minolta Maxxum 400si 35mm SLR Camera
Image through nikon f80 dark and cloudy
I'm unfamiliar with the F80 but on models like the f65 and f75 the viewfinder screen has an lcd overlay and when the battery is exhausted or removed the viewfinder goes dark and blurry.
Looking at a picture of the f80 it looks like it's just an update on my f75 so it strongly suggests that you just need to insert a fresh battery. The lcd does draw power from the battery even with the camera turned off.
I hope that you found my answer useful, once you've tried another battery to confirm what I've suggested I'd appreciate it if you return the favour by rating my answer.
Jul 20, 2009 | Nikon F801S 35mm Film Camera
Dark and blurry
It will clear instantly with a fresh battery.
The viewfinder screen has an LCD overlay and even when the camera is switched off the screen uses a small amount of power. When the batteries are flat the screen is unpowered, the crystals in the LCD align randomly to both darken and blur the viewfinder image.
Please don't forget to rate my answer.
Jul 18, 2009 | Nikon N65 35mm SLR Camera
Everything is dark when i look through the viewfinder
it may be a battery , or stuck shutter.
remove lense and look inside mabe give some things a wiggle. make sure you have a full battery that you know works.
if your not sure and it is a valuable camera , take it to a service guy :-)
May 04, 2009 | Minolta Maxxum 400si 35mm SLR Camera
VIEWFINDER IS BLACK
oops might have left the lenscap on.. Is the battery charged? usually the viefinder goes dark when the battery is dead/drained.
Nov 27, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Pentax K1000 35mm SLR Camera Logo
138 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
