Question about Dishwashers
My aquarius hot point fdw70 comes up with error a10
  • Anonymous Mar 17, 2009
    a10
Check out www.selfix-uk.co.uk for all hotpoint error codes and what they mean
Posted on Oct 07, 2008
Hi the belt on my hot point Aquarius wdl520 has come off how do I put it back on please
If the spin is noisy the belt will come off continually.
The belt is very tight to put on as it's elasticated.
Sep 05, 2017 | Washing Machines
Dishwasher not doing anything
hi does anyone know what error A06 for the Hotpoint Aquarius FDW70 means and if it can easily be fixed
Jun 13, 2013 | Dishwashers
Hotpoint Aquarius WDF740 error F13? what is this?
Dear Sir,
My problem is wdf740k hot point after the water fill machine get on it will work about 6 - 7 minutes and the error F 13 showing and lights are winking.
prasadh
Mar 07, 2011 | Hotpoint Washing Machines
We have an Hotpoint FDW70 Dishwasher that for some time has had an A10 fault which although stops the machine some times 70% of the time it does a full cycle. However it is now tripping out the electric at...
hi the fill valve triac is the plastic vlave that the inlet hose connects to you can get them for about £10 you reset the machine after replacing it by switching it on, pressing the power button leaving it off for about a minute then switching it back on, and the onboard diagnostic unit resets automatically.
Sep 25, 2009 | Dishwashers
My Aquarius FDW70 keeps coming up with code A10
Dear sir,
If your dish washer is type EV02 Module,
Error A10: means Faulty fill valve.
Check valve and associated wiring.
If your Dishwasher is
Standard Module + FDW70 + FDW75,
E10 means Heater fault.
Check heater and associated wiring.
i think it helps for solve your problem.
if you have any doubt regarding this issue leave a feedback we will glad to assit you.
Have a nice day
good luck
Sep 12, 2009 | Dishwashers
Hot point aquarius 1100 - does this have a heating element for cold water feed ? or does is need direct hot water feed ? (there is a inlet at back for both hot and cold so presume no heating element ?)
All Hotpoint washers have heater element regardless of whether they are cold fill only, or hot and cold fill.
if 2 connections at rear, then it is hot and cold fill, if only 1 connection, then it is cold fill only.
Please rate my solution.
Thanks.
Jul 24, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
How do i find the float switch for a Hotpoing Aquarius FDW70
Open the DW. Look in the front right or left corner of the tub.
You will see a plastic dome.
The float switch is directly underneath the dome.
Remove the toe kick plate and located the float switch from the bottom.
Sometimes they get stuck.
Jiggle it then try the wash cycle.
If that does not work, replace the float switch.
Feb 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hot point aquarius wf740
Hi.
F03 indicates that the wash thermistor is open or short circuit.
I think you need to call engineer to sort the problem
Please leave feedback.
Dec 02, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WF100 Spin Hot
use a label maker they cost 15 to 20 and the labels last forever.
there are ways to stencil them on but they will come off unless you use plastic paint.
Apr 02, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius+ FDW70 Error Codes
i have the same on my dishwasher and have just been looking on the net. Found out that the error code A10 means open/short circuit fill value traic. Whatever that means!!! and to book a service engineer. Hope that helps
May 04, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Open Questions:
Brand new dishwasher will not finish washing, it just beeps and the lights flash red - CANDY CDP 1L39W/K I have a brand new Candy dishwasher model CDP 1L39W/K that won't finish it's wash cycle. When I do P5 for a fast 5minute cycle I hear the dishwasher fill up, it begins to wash, and then after it drains the water, then the dishwasher begins beeping repeatedly and flashing the red light under the P5 setting. When I check the detergent slot it hasn't been used yet. When I select a long wash like P3 the same thing happens after it drains the water, so I think the error occurs after the first rinse cycle? When I push down reset all the lights flash and then blink sequentially just like the dishwasher is waiting for a new cycle input, but the water pump to drain the water never turns off. If I push the power button the unit turns off but the water pump keeps running. Only when I disconnect the power cord from the wall will the pump turn off. If I reconnect the power cord the pump turns back on sometimes. I read online that maybe the flood switch was hit and to tilt the unit and drain water, I took off the kick panel and didn't see any water, and tilted the unit back and forth as instructed. The first time I tried this I think it may have helped the water pump turn off after I reconnected the power cord. But when I ran a cycle again nothing changed. I also waited a few days afterwards because I was busy at work enough time for any water to dry up but this didn't help. I'm in Vietnam and the customer support is Vietnamese so I thought I would try this before I have to see about the warranty and shipping the unit far north for repair. Any help is really appreciated, I can post a video of the beeping, blinking lights, and water pump running after I unplug the unit it'd help. I so badly want this dishwasher to just work, it was a big purchase here and a lot people don't understand why I'd buy it so now that it's not working it's really embarrassing! Thanks again!
Jan 22, 2018 | Candy Dishwashers
Dishwashers Logo
572 people viewed this question
Top Dishwashers Experts
