Question about iRiver T20 MP3 Player
How do you replace the 3.7 volt lithium polymer rechargeable battery in an iriver t20 mp3 player?
I have an iriver t20 mp3 player which has given many years excellent service. The battery has died. Where can I buy a replacement battery? How do you open the unit to replace the battery? The iriver website only says send the unit to their service centre. It can't be that hard to change the battery. I did it for an iriver H340 without any problems. Thanks Bilby
  • Harry Lew Jan 23, 2009
    Need to replace iRiver T20 MT battery. How does the case come apart?
3 Suggested Answers
SOURCE: iriver h340 - new battery charges but does not work when not in electicity
They may need to be on the other way.
Posted on Jul 30, 2008
SOURCE: Iriver H340 - new battery charges, but does not work...
Hi, I had the same problem with my H340. I bought a battery for $16 on eBay and swapped them out. The unit would say "Charging" but would never "Complete". When disconnected from the AC, it would not power up at all. I opened it up again and noticed that the old battery connections had the red wire on the left, the battery had the red wire on the right. I took the black and red wires out of the quick-connect jack and swapped them so that the red wire would no go into the player on the left. Works like a charm now.
Posted on Oct 13, 2008
Iriver t20
I had the same problem. I reinstall windows media player 11 and now the system recognize my iriver T20!!! When reinstalling WMP 11 i had T20 in the USB Port!
Angel Greece
Nov 06, 2008 | iRiver T20 MP3 Player
Battery life? replace? how much?
The battery for this player lasts 1Day(mp3) and 5-7hrs(video.)
You cannot fit a replacement yourself as you will have to take the player apart. Proffessional help is advisable. A replacement battery will cost around 15$.
And you can carry but cannot view documents on this player.
Here are the complete specs for your player
  • General
  • Width 2.3 in
  • Depth 0.4 in
  • Height 4.2 in
  • Weight 3.4 oz
  • Localization : United States
  • Packaged quantity 1
  • Digital storage media type None
  • Digital Player / Recorder
  • Digital player supported digital audio standards WMA, WAV, ADPCM, MP3, AAC
  • Digital player response bandwidth 20 - 18000 Hz
  • Digital player sample rate 48 KHz=8 KHz=11 KHz=32 KHz=44.1 KHz=16 KHz=22 KHz
  • Digital player signal-to-noise ratio 84 dB
  • Digital Player total harmonic distortion 0.05 %
  • Digital player ID3 tags support Yes
  • Digital player additional features Variable bit-rate compatible, WMV playback
  • Battery
  • Rechargeable Battery Rechargeable
  • Battery Enclosure Type Internal
  • Included Qty 1
  • Technology Lithium polymer
  • Battery 1 x Lithium polymer Rechargeable Internal
  • Battery Life Details Video playback 6 hour(s), MP3 playback 30 hour(s)
  • Capacity 880 mAh
  • Connections
  • Connector type 1 x Headphones Mini-phone stereo 3.5 mm, 1 x USB
  • Slot(s) provided None
  • Slot(s) Required None
Oct 05, 2008 | Philips GoGear SA5285/37 Digital Media...
Jun 28, 2008 | iRiver H340 MP3 Player
How do I take it appart
Lately, they've been building disposable MP3 players. Mine has got a lithium/ polymer battery that "should" last for years. Once it's shot, the whole thing is shot- unless you run it off the charger. So much for portability.
Feb 07, 2008 | iRiver H10 MP3 Player
Windows xp drivers
Make sure you have the latest version of Windows Media Player. XP has all the right drivers but the iRiver needs to synchronise with Media Player inorder to transfer music onto the player using the sync function. Get Media Player 10 or higher then plug the iRiver into the computer.
Jan 18, 2008 | iRiver T20 MP3 Player
Conectivity
All the info/manuals/drivers/upgrades for the iRiver T20 can be found here:
http://www.iriver.com/product/p_detail.asp?pidx=71
Dec 21, 2007 | iRiver T20 MP3 Player
Iriver t20 problem
have you tried hitting the reset button when it hangs? You need to use a pin to do so, there's a small hole on the end of the player.
Nov 30, 2007 | iRiver T20 MP3 Player
Battery does not hold charge, does anyone know what kind of battery i need?
I have the same problem with my player. The manual says the following under the specs: Power Power Supply AC Adapter DC 5.0V, 2A Battery Lithium Polymer Battery Does this help? chichuck
Sep 08, 2007 | iRiver H320 MP3 Player
iRiver T20 MP3 Player Logo
504 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
