Question about Frigidaire FEF364DQ Electric Kitchen Range
Frigidaire Electric flat top Range
The range clock got stuck at 3:35 and the oven will no longer work? Range top elements still work. I unplugged and plugged back in to see if it would reset and the clock did not come back on?
My range will not hold the heat for either the convection or regular heat. the model number is CGLEF385AS2
Posted on Dec 24, 2008
Where are the relays that controls the oven on frigidaire electric range located
if range is self clean make sure door is closed, put on self clean wait about 0ne minute or so then cancel self clean . sounds like range is stuck in door lock Cheers
Dec 11, 2013 | Frigidaire FEF366 Electric Kitchen Range
Top and bottom heating element does not work on Frigidaire electric range ES300
Usually when both elements are not working and everything else is working fine, the problem is your OCU (oven control unit), commonly known to consumers as the clock.
The clock controls the oven and most times does not produce an error code when it fails.
You will need the actual model number from a sticker located on the oven frame when you open the bottom drawer, the sticker will have the model and serial number clearly listed.
Do a Google search for that model number and find the clock.
I've provided a link for what probably is the proper clock but without the full model number I can't say for sure:
http://www.appliancepartspros.com/frigidaire-clock-316207529-ap3764682.html
Apr 05, 2013 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Heating element in Frigidaire range, model number FEFL64FSD.
Either the bake element is bad or the clock / control is bad. Element can be tested with an ohms meter
Sep 29, 2017 | Ovens
is there voltage going to the erc (electronic range control)?
Feb 09, 2008 | Kitchen Ranges
Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Dec 13, 2007 | Frigidaire FES367 Electric Kitchen Range
Open Questions:
Frigidaire FEF364DQ Electric Kitchen Range Logo
828 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
