After tv is turned on, about 1 hour later picture continuously flickers
SOURCE: rca scenium turns off and on
I had the same problem with mine. It was overheating. I installed a small cpu cooling fan on the back of the unit. No problems since. Good luck.
Mark
I wish I had the idea to install a cooling fan, a local repair shop fixed mine by replacing a power supply component, cost $575 including sales tax. I suspect that a cooling fan would increase the life of the power supply, I will install one!
SOURCE: TV worksfine for one hour, colors fade in and out, flickers
Color Wheel, Go website Encmpass Parts Distr Look up the part # if they do not have it in stock then go to E-Bay look under Electronic 1-800-638-3328
SOURCE: RCA P56812BL, Flickering Static like lines
Check all inputs and tuner, that you can, and report back.
Testimonial: "All inputs are in place, and connected properly. I have removed Cover from the back for further instructions. Flickering gets comes and goes depending"
