Question about Panasonic SJ-MR220 Personal MiniDisc Player
Problem recording with SJ-MR220
I am having trouble recording with the SJ-MR220. I set it up to record in the normal manner and the levels and time indicate that it is recording, I then stop it and it says it is writing the disc but when I go to playback the disc is blank. I am recording out of a dj mixer using a stereo Y cable into the line input. I monitor it whilst it is recording and it seems to be going through fine and it always looks like it has recorded and written the disc. I have never had this problem with any other MD recorder. A friend gave me this unit so it is second hand but I don't think it has had any use before. I do have the manuals but I can see nothing from them that I am doing wrong. Please help!
SOURCE: Panasonic DMR-E50 won't recognise blank DVD's only
You can only record to dvd-ram or dvd-r NOT dvd-rw!
Posted on Mar 20, 2007
SOURCE: DVD Recorder will not format blank DVDs
I kept formatting DVD's until I got the unit to work. Mainly, it was some DVD's I had earlier problems formatting. I tried two new DVD's (Maxell DVD-RW) and they worked thus far. I truly think the unit needs to be taken to authorized service center for evaluation or minor maintenance. My suggestion is to verify the DVD's will work with unit. Try to use better quality ones like TDK or Maxell. Thanks for responding to my problem. If I have others, I will contact you.
Posted on Feb 10, 2008
  • 33 Answers
SOURCE: Problem with Playback and Record on camera
The fix is really easy and costs nothing, just 10 minutes of your time!
*I fixed mine (twice) this way*
Turn the cam over.
remove all the screws holding the dark plastic bottom on the camcorder, remove it carefully.
Now you will see the ribbon cables, VERY GENTLY, wiggle them from left to right (about 1mm each way), then push them in.
Test by putting your battery back on and see if it holds a tape, or plays without blinking and switching off - you will be happy.
The fault is simply that one cable (I can't tell you which one) becomes loose over time, so it just needs to be pushed back in and the condensation error and/or the door closing problem go away!
A lot of folks are buying cams off eBay like this as it's such a simple repair!
Good luck - please help others - post back if it works!
Posted on Feb 21, 2008
  • 3 Answers
SOURCE: DVD recording problems
I have the same unit with the same exact problem. I ended up taking it in for repair and it's now working perfectly. I paid $100 for the repair. I dropped the unit off and picked it up myself. I think $30 additional is charged for shipping and handling in US.
PANASONIC CAMERA & DIGITAL SERVICE CENTER
1590 Touhy Ave
Elk Grove, IL 60007-5319
EMAIL camerarepair@us.panasonic.com
888-439-2676
Part Number
RFKNEH75VP
Description
RAM/DIGITAL PCB MODULE
Posted on Jun 28, 2008
pogiboi
  • 85 Answers
SOURCE: "NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
GODBLESS U
Posted on Sep 22, 2008
How can I stop clipping in audacity, Is there any way I can set audacity so it doesnt clip?
Sounds like you have too much volume range in your recording. If it is what I think it is you could use an automatic volume limiter on the input of the AudiCity recorder.
Aug 16, 2016 | Behringer C1U Studio Condenser USB...
Why would the output sound level on a MP3 vary so much?
MP3 songs are recorded at different levels. Many modern tunes have been deliberately recorded loud by the record companies for maximum effect.
If you are recording the songs yourself some recording software has a "normalize" feature. This increases or reduces the volume of the track to a certain level. Especially useful when you have tracks at different levels. By the way this is how they get CD tracks to play at the same levels. So you don't have to turn up the volume or turn it down every time a new track plays.
Nov 11, 2017 | Audio Players & Recorders
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Our church uses the Marantz Cd 633 Recorder. The problem we are having is that the playback volume of the CD is not high enough. You have to crank up the playback device all the way to hear recording at...
You have to isolate where problem is. Does a prerecorded disc play at normal volume levels? no? Check fade settings in menu. If yes, substitute another line level analog input from another device right at the recorders back panel. Test recording with that input and verify if recording level display can reach clipping level. If you have that and still have weak playback, again check for an in/out fade function being programmed. Also check volume selection in menu and try different settings, including 0.0. There is also a monitor mode to check input levels without using a test disc. Otherwise have unit checked by a repair business
Nov 22, 2017 | Marantz CDR633 CD Player Recorder
How can I digitize cassette tapes using the Marantz PMD670?
Take a set of RCA Jack cords (4 jacks) and on the tape recorders "out" jacks attach one pair and on the PMD 670's "In" Jacks attach the other pair. Set the tape a few seconds before where you want to record , set your levels to where you want them, start the recorder then start recording with the PMD.
You may need to test record a few seconds to make sure the recording is at the level you want it to be. Plug in a set of headphones to the PMD and listen in from time to time to make sure it's recording OK.
There you go.
Best,
Dan
Jul 01, 2010 | Marantz PMD670 Desktop Digital Voice...
It is not recording. I press play then I record. When I am finished I press stop. I then press finalize then record. But it does not record. Am I following the proper recording sequence?
Don't you have the manual?
http://download.p4c.philips.com/files/c/cdr870_17/cdr870_17_dfu_eng.pdf
Press REC and the RECORD indicator will start flashing when the unit is ready to record. You can set your levels for an analog input by playing it while in this mode.
When your source is ready and you have your levels set up, press PLAY on both units.
If you don't see the time incrementing , it's just standing still.
Apr 20, 2010 | Philips CDR870 CD Recorder
Trouble viewing recorded time-lapse recorder tape.
Sounds like the heads on your TLC 2100 Time-lapse recorder are in their last legs. This is normal for those units. The reason you are having those scramble lines towards the top of the screen is because you are not playing at normal play speed.
The problem with the switching between cameras is that the "dwell time" settings is set to high. Most dvr's you can just disable that.
If you are looking to upgrade look here.
Jan 15, 2009 | Security Labs Time Lapse Recorder
Magnovox MWR20V6 will not begin recording when it should.
This is more a work-around than a solution, as the unit is failing to function normally; however, having the identical problem I observed that the unit is failing to power on at 2:00 minutes before beginning recording, a necessary step to record to DVD.
My work-around is the following:
1) Set up the timer, inputting necessary date, time, etc. as normal. With the unit still powered on, start the timed recording mode by pressing timer set, as normal. You will see the red clock icon and the DVD logo iluminate on the VFD.
2) Press the Standby-On power button. This will power the unit on in VCR mode. You should at this time be unable to switch from VCR to DVD mode since the DVD is still in timer mode. LEAVE THE UNIT POWERED ON in this manner. The timer will function and the DVD will record normally.
I have no clue why my unit suddenly forgot how to power up on its own in order to record to DVD. If anyone has an answer for that one please post!
Tom Gee
May 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Panasonic SJ-MR220 Personal MiniDisc Player Logo
54 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
