First, go to this page:
Lexmark X8350 Support
Click on the
Downloads tab. You will notice that there are 2 Vista drivers:one for 64-bit (X64) and one for 32-bit. If you are not sure which one you have, go to your Control Panel and select System. if you have a 64-bit system, it will say so in the window. If it doesn't say, assume it is a 32-bit system.
Once you determine which yours is, select the proper one and click on
Download Now to the right of that driver. When you get a download window, select
Save and direct it to save it to your Desktop.
When the download is complete, close all your open programs. Make sure you uninstall the previously installed Lexmark software and delete the printer from the Control Panel Printers option.
Follow the same Setup procedure as before, except instead of inserting a CD you will run (double-click) the file on the desktop that you downloaded. Follow the instructions given as it installs.
There are also some good links on the other tabs should you need them. On the Documents tab there is a link about installing a downloaded driver. On the Publications tab there are links to the User and Setup guides.
If you need further help, just Comment back.
Thanks for using Fixya.
