Question about Toshiba 57H83 57" Rear Projection HDTV
Red bows and wont realine
Got this second hand and that is when it first happened, at first it was only for a few seconds then minuets now permanent, the red gun/lamp bows at top and bottom in convergence mode will move side ways but not up and down
    Scholar:
  • 142 Answers
Replace the red AND blue convergence IC's. Both need to be changed. You change the blue IC to ensure your repair will be reliable. They are mounted to large. finned heat sinks because they get very hot..hence why they fail more often than any other part in a projection tv. The # on the chips will start with "STK-" followed by numbers. These IC's are available through tritronicsinc.com. They cost about $15 to $35 each. Good Luck!
barneyluc
Posted on Oct 07, 2008
  • 4,234 Answers
This is a problem within the convergence circuit. If you can solder, you can fix this yourself. Please confirm that the model is 57H83 and whether oor not you wish to attempt the repair. I will then provide additional details and instructions.
Thanks,
Dan
Hello I have a mitsubishi vs-45603 with what appears to be a convergence problem.
You may have bought bad chips or your soldering...
This is a common problem on many brands of Projection Tv sets. Its usually a convergence issue. You can get more details and a solution here on fixya using this link http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
Mar 22, 2012 | Mitsubishi VS-45603 45" Rear Projection...
Tip
Simple tips on becoming a better archer
a few simple tips you can use for shooting your bow and to improve your arrow grouping . first it starts out with a good stance your feet should be shoulders with apart but not over spread apart.you will want to face 90 degrees to either the left or the right of the target depending on your shooting hand .second your draw ,when you draw your bow the bowstring should sit right below the far outside corner of your eye..thirdly calming your self take a few deep breaths and hold your last breath till your ready to shoot and settle your pins (sights) on your target remember to use the right pin for the right distance.. fourthly remember not to drop the bow when you release the arrow.i dont mean actually dropping the bow on the ground but lowering your extended arm holding the bow forward to quickly before the arrow has time to release .dropping the bow can and will cause your arrows to drop too ...shooting your bow at longer distance will tighten up your arrow grouping at closer distances
on Jul 24, 2012 | Archery
Sound Cutting Out
Somthing is tripping th amp breaker...
Try unplugging it for several minuets & see if clearing it helps..
Hope this helps !!
Please rate me good ;o)
Jul 11, 2009 | Teac AG-780 2 Channels Receiver
Wont autofocus, bow in blue color at top, cant adjust blue convergence
hello it's the convergance chips my be the problem get a quote from an engineer its a big job 2 do yourself trust me i've repaired a few my self i hope you get it fixed good luck
shaun
May 21, 2009 | Samsung Televison & Video
Hour and minute hands dont move, second hand does
You better go to a watch service center to replace depected parts ,the problem of your watch is a broken center wheel,need to replace with a new one with identical size and caliber,so its works normal again.
Hope it may help you;
Regards;
VOTIT
Apr 23, 2009 | Watches
Camera won't zoom in or out
It is a glitch but turning your unit off and removing the battery for a few seconds will reset the camera. This is how I fix the problem with mine.
Apr 03, 2009 | AT&T Blackberry Curve 8300 Smartphone
Uniden cordless phone
I found that if I hold the "find hs" button on the BASE unit (right above the red charging light) for a few seconds, it works!! Thank goodness there is a solution! Thanks for the help.
Feb 07, 2008 | Uniden Cordless Phone
PT-51HX42 51inc. - picture bowing
This happened a few years ago to me. I called the repairman out and he said that I had my tv too close to a magnet source, which turned out to be a speaker and also the reciever for my home theater. See if this may be your problem. Good Luck.
Jan 02, 2008 | Panasonic PT-51HX42 51" Rear Projection...
Toshiba 57H83 57" Rear Projection HDTV Logo
103 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
