Canon MP830 message re: waste tank full. How do I get to it to empty it or replace it.
  • ldadz Oct 07, 2008
    Re: Canon MP830 printer. How do I change the ink waste tank. Dabbing the printhead with a q-tip was not a sufficient solution
    This doesn't answer my question about how to empty or replace the ink waste tank.
  • 3,037 Answers
Alright, the "waste tank" is basically a sponge where you can rinse it out (with gloves on) and then let it dry and replace or you can call the manufacturer (in this case Canon) and see if they will sell you a new one, Some manufacturers and models have replacements for sale, some do not.
You will then need to reset the printer with the method below
*AF-Key = Additional Functions key = the black button with the star in a head above it.
1) Enter SERVICE MODE. (Press AF-Key, followed by "scan", "copy", "scan" -Keys)
2) Select TEST MODE (press right arrow button 13 times).
3) Hit -OK-
4) Select [8] PRINTER TEST
5) Hit -OK-
6) It'll now say "- 8-2 +" press the right arrow key once to get "- 8-3 +"
7) Hit -OK-
8) Select 0. [INK COUNT].
9) Hit -OK-
10) It should return to showing the "8: Printer Test - 8-3 +"
11) Press the [Stop/Reset]key - (black key with triangle and circle on it) - (returning to the state of 4), and then press the [ON/OFF] key.
Posted on Oct 07, 2008
  • 4,889 Answers
The printer uses a fibrous pad to absorb waste ink which is siphoned out of the printhead during a cleaning cycle.
The only reason you should ever need to clean or replace the waste ink pads would be if you're receiving the "waste ink tank full" error message.
At that point, you can either buy a new printer or take it to a service depot to have them replace the pads and reset the waste ink counter or you can try to do it yourself. Average charges for doing this range from $50-$85.
You can try to reset the waste ink counter without cleaning the pads but you're in for a big mess if they get saturated with ink and start to leak on your desk.
First, remove the ink tanks and the cartridge carriage, then try to fish out the waste ink pad from under the carriage. (This should be possible without dissassembling the printer.)
Rinse out the pads using warm water and let them dry. Try not to destroy them by wringing them out. Use a bunch of rags to press the water out and help them dry more quickly.
When the pads are dry, you can use the following information to reset the waste ink counter and resume printing without errors.
3) Hit -OK-
5) Hit -OK-
7) Hit -OK-
9) Hit -OK-
    Sergeant:
    Champion:
  • 200 Answers
Hi
Here is the reset process. You need to carefully follow the steps for it to work. Not to defend Canon but without the waste ink counter you will at some point end up with ink leaking from the printer.
Waste Error Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange.
6: Press Power to set data
I hope this helps.
Thank you
  • 19,396 Answers
Often you just have to reset the counter, and it is not neccessary physically cleaning or emptying the waste ink tank.
Try the procedure below:
1) Power off the printer
2) Hold the RESUME button then press and hold POWER. (beeper MAY sound once, or may not )
3) Hold POWER and Release the RESUME button.
4) Press RESUME twice, then release both the POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times
6) Press power
    Genius:
  • 1,239 Answers
HI  FIRST REMOVE CATRIDGES CLEAN IT FOR BETTER ..............AND THEN REPLACE RING AFTER CLEANING IT;
  • 1,800 Answers
    Guru:
  • 1,894 Answers
The waste ink tank refers to may be a small well, surrounded by a
rubber ring, that sits under the cartridge when it is parked.
Place a cotton tip swab ("Q-Tip") over the hole to wick out the ink inside.
  • dewan nafees ahmed Oct 08, 2008
    i told you the easy way top empty the ink tank.
    did yo follow that?
Tip
"The waste ink absorber is almost full" message?
This applies to the CANON PIXMA MP130 and other ink-jets made by Canon/Pixma.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear up the error, but eventually you'll need the waste tank to be emptied or replaced. And as far as I know, you can't find the replacement parts to buy, nor the instructions to empty the waste tank.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there.
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to empty or replace the waste ink absorber nor the necesary replacement part.
on Apr 02, 2010 | Office Equipment & Supplies
I got the message "waste tank full" and now the
your printer has a second tank for colleting all the unused waste ink.
this needs to be replaced with an empty one or cleaned out.
i hope this was useful.
Jan 24, 2011 | Canon i455 InkJet Photo Printer
I am getting an error that tells me "waste tank is nearly full" - what is this what do I do? I expect any time now to be unable to print at all. Right now I can proceed. Where is the tank how do I...
It is the tank where all the waste ink goes in when the printer heads gets cleaned and it needs to be removed and cleaned and then re fitted this is messy to clean properly and you can replace with a new one but this will cost you money
Oct 11, 2010 | Canon PIXMA MP830 All-In-One InkJet...
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
5) Select OK
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Canon I965 waste tank almost full - how do I clean/empty or clear
You will have to get it replaced by a Canon agent.
Phone Canon for nearest agent
Just had mine done cost £50.00 +VAT
The codes on line to reset counters will not solve the problem and eventualy ink will leak from the printer.
Feb 24, 2010 | Canon BubleJet i965 InkJet Printer
Need to replace ink cartridge
http://reviews.cnet.com/multifunction-devices/pixma-mp830-office-all/4505-3181_7-31785803.html
Replacing the five ink tanks (cyan, yellow, magenta, black dye, and black pigment) is a simple task. The top of the printer flips up to reveal the ink tanks and the printheads, and by flipping a lever, you can pull out each tank individually. Being able to replace individual tanks is a boon, as you won't waste colors you use less frequently. Also, you won't need separate photo ink to print photos, which we appreciate. Canon ships the Pixma MP830 with full ink tanks. Replacement color and dye-based black ink tanks cost $14.25 apiece, while the pigment-based black ink tank costs $16.25. Canon estimates the cost per page for both black text and color text to be an inexpensive 2 cents.
May 31, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I get an error message on Canon i960 printer that tells me the waste ink tank full. How can I empty this myself?
Read it all here.
Scroll about half the page, to:
WASTE TANK ALMOST FULL or FULL ERROR MESSAGE PROBLEMThere is explained how to get rid of the error message very easy, and how to clean the waste ink pad manually. The latter seems not to be necessary, though.
Mar 27, 2008 | Computers & Internet
299 people viewed this question
jasbo
jasbo
