Question about Belling Ovens
Belling Cooker BE 145
THE AUTO SYMBOL ON THE COOKER TIMER IS CONSTANTLY DISPLAYED, COOKER WILL NOT TURN ON USING THE + - CONTROLS, HOW DO I TURN OFF AUTO?
  • 4 Answers
SOURCE: ovens on cooker
DEPENDS ON THE MAKE AND MODEL EACH TIMER OPERATES DIFFERENTLY, BEST SOLUTION IF YOU DONT USE THE AUTO FUNCTION IS TO HAVE THE TIMER WIRED OUT SO OVEN COMES ON REGARDLESS IF THE TIMER IS SET OR NOT.
Posted on Feb 14, 2008
SOURCE: Beko Cooker dvc565
once you take of the back of the oven there are some wires going from the cooker to the back cover on one of the wires you will see a microtemp thermal fuse protector this connects the two wires (the white wire) this needs replacing you can get them from tdspares.co.uk we will be getting 121c degree. Hopes this helps
Posted on Mar 04, 2008
  • 1462 Answers
SOURCE: electrolux EOG7330 gas cooker - electric timer fails?
i suspect there is no fault with timer. there is an overheat stat usually on top of the oven but sometimes inside the back. if this detects overheat, then everything is switched off and comes back on after cooled down.
if this is the case, then suspect lack of ventilation causing the overheat or the casing cooling fan failed.
get back to me if i got it wrong
Posted on Jul 18, 2008
SOURCE: Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Posted on Aug 01, 2008
SOURCE: beko dvc6531 cooker
i can send u a copy of user manual if you need one you have to hold the first two buttons in then move time with up or down please email me if you need more info andyali09@btinternet.com
Posted on Aug 30, 2009
I have just baught a second hand belling double oven cooker, we have switched it on and the timer is constantly buzzing! And the top oven and grill don't work! Any ideas on wot could b wrong?
The timer has been set and the cooking time is finished. That is why it is buzzing and the oven is in a turned off state. You need to acknowledge the cooking time finished, and set the oven back to Manual operation from Automatic. In the old days you pressed one of the buttons by the clock that was used to set. I used to have a Belling Double Oven in the UK, but I can't remember about the timer.
Google
make model manual
Google
Dec 19, 2016 | Belling Ovens
Replacement user manual for Belling Format 645 cr double oven electric cooker
http://www.manualsonline.com/mdownloads/ff2c5d47-49a9-4d8c-9232-8033f1e3e147.pdf
Apr 13, 2014 | Belling XOU482 Electric Double Oven
Free standing belling cooker model numbers
try pushing 2 buttons on left and 2nd button in from right side
push left ones first then the other! should stop it.
Could try pulling buttons out and then replacing them best is to consult a local engineer!
warmest regards
Richard The Repairman
Mar 28, 2014 | Ovens
How do i take out the old cooker element on my belling xou252 cooker
If it is a fan assisted oven, then the element should be behind a removeable cover at the rear of the oven,
Be careful not to lose the wires behind the oven compartment.
Hope this helps.
Dec 19, 2009 | Belling XOU252 Electric Single Oven
Electric oven will not switch on. No heat, no fan. There is a timer display that is counting up and has the word AUTO showing. The gas hob works normally. How can I turn the cooker on?
Hi. You probably have to switch the oven onto manual control. Auto would turn oven on at a preset time. Is there a button with a hand symbol on it? This might be manual. Timer should show clock when in normal manual operation.
Aug 22, 2009 | Tecnik Ovens
Trying to set oven timer
Hi, switch off the mains for the cooker, wait for about 15 seconds then press the 2 buttons on the left and hold them, and then press the - or + button to set the time.
Cheers
Feb 19, 2009 | Belling XOU482 Electric Double Oven
Cooker problem
If it has a timer, make sure it is set to manual or it will not heat, another possibility is a faulty thermostat, you need to find out if you are getting power to the element, if you are then element should work unless you have got a faulty one.
Plz rate this solution.
Dec 15, 2008 | Belling Ovens
Belling builtin electric cooker formula multifunction double oven think 488BH no instruction book dont know how to use the timer and different parts of fanoven etc.
get manual here
http://rapidshare.com/files/369550394/BellingFormulaMultifunctionDoubleOven.pdf.html
good for 60 days only
Nov 09, 2008 | Belling Ovens
Oct 29, 2007 | Belling XOU482 Electric Double Oven
Ovens Logo
63 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
