Question about Motorola Mobility i850 Cellular Phone
Motorola i850 will not charge completely
My phone will not charge on the wall or car charger. I went to the Nextel store and purchased a new battery 2 days ago and turned the phone off to let it charge. When I turned it back on the next day, it still showed a low battery. Any suggestions? I just bought the phone in March 2008.
  • 32 Answers
Check may be the charger is bad if not so lose your phone, at the botton, at charging port side u see two seperate leg re-solder it.
Posted on Dec 07, 2008
Where can i buy batterry and charger of motorola i550 plus?
The battery is readily available online or through any Motorola 2-way radio dealer. You can use part number NTN8971 or NNTN4190 NiMH battery. The phone should also accommodate 4 AA batteries instead of the NiMH battery. (Be certain to never try charging the phone with the AA batteries inside, as it is not designed to do this.)
The wall charger part number NTN1680 is listed as being no longer available from Motorola Solutions. However, during a Google search it appears several vendors still have these available for just over $7 US dollars.
The i550 was a primary phone used in the iDEN Nextel system. It operates on 800 MHz and likely needs to be connected to a system to work. I do not know if it will work as a 2-way radio without being connected to a system. The type of system these were used on has been completely or for the most part shut down. According to this article it will be completely shut down by June 2013. http://www.computerworld.com/s/article/9227557/Sprint_to_shut_down_Nextel_iDEN_network_next_year
Here is a link to the user manual for the i550 http://www.cellphones.ca/upload/manuals/motorola_i550plus.pdf
Best regards.
Sep 21, 2012 | Nextel Motorola i550 plus cell phone w/...
My charger for my Motorola T6510 is not charging. The charger is getting power.
Check your battery contacts, both on the radio and the charger. Clean with a pencil eraser if needed. It is possible you are not getting good contact. If both radios are not getting charged in a dual well charger, you may have a problem with either the wall adapter or the base. (Assuming your batteries are good.) Wall adapters burn out over time, somewhat like a light bulb.
Replacements are available at the Motorola online store. http://www.store.motorola.com/2-Way-Radio-Rechargeable-Battery-Upgrade/dp/B003H0FUD2?ie=UTF8&id=2-Way%20Radio%20Rechargeable%20Battery%20Upgrade&field_availability=-1&field_launch-date=-1y&field_browse=2265964011&searchSize=12&searchPage=1&searchNodeID=2265964011&refinementHistory=brandtextbin%2Csubjectbin%2Ccolor_map%2Cprice%2Csize_name&searchRank=salesrank This kit contains a pair of new batteries and a complete charger.
Best regards.
Nov 04, 2010 | Motorola T6510 XLR Talkabout Two-Way...
I have a t-mobile simcard and is asking me for a lock code
If you are attempting to use a T-Mobile SIM card in a Nextel Motorola i730 mobile phone it will NOT work.
T-Mobile phones operate off of a GSM network. The Nextel i730 operates on an iDEN network.
The phone you have can never be compatible with the network you are trying to use it on.
Sep 07, 2009 | Motorola Mobility Naztech Nextel Iden...
Brand new motorazr V3s. draing batteries. only 3 hours of use
HEY THOSE CHINESE CHARGER ARE NOT GOOD.. THEY SUM HOW NEVER CHARGE THE BATTERY PROPERLY ND THE BACKUP IS LESS. CHARGE USING UR MOTOROLA CHARGER ND IF U STILL EXPERIENCE PROBLEM THEN U BETTER GO TO MOTOROLA
Aug 16, 2009 | Motorola Mobility RAZR V3
Sell nextel i9 i877 i876 i880 i580 phone
GOSTARIA DE SABER COMO TIRAR CODICO ESPECIAL DE NEXTEL
Jun 03, 2009 | Nextel i860
Subsidy code for i850
Sorry there are no subsidy codes for the i850. This means that you have used the wrong type of SIM Card. You can only use a Sprint Nextel or Boost SIM Card in an i850. If you are using a correct SIM card, you will need to have this repaired at a local service center. This is covered completely by Sprint Nextel's ESRP (Equipment Service & Repair Program) and TEP (Total Equipment Protection), and can be done at any Sprint Nextel Service & Repair Location. If you do not subscribe to ESRP or TEP, the charge for the repair will be no more than $55.
Feb 28, 2008 | Motorola Mobility i850 Cellular Phone
Need i850 special code
Sorry, there is no special code. You can only use the correct Sprint Nextel SIM Card with this phone. If you are using the correct SIM Card, you will need to have this repaired at a local service center. This is covered completely by Sprint Nextel's ESRP (Equipment Service & Repair Program) and TEP (Total Equipment Protection), and can be done at any Sprint Nextel Service & Repair Location. If you do not subscribe to ESRP or TEP, the charge for the repair will be no more than $55.
Jan 15, 2008 | Motorola Mobility i850 Cellular Phone
Phone works better without a battery cover
You will need to have this repaired at a local service center. This is covered completely by Sprint Nextel's ESRP (Equipment Service & Repair Program) and TEP (Total Equipment Protection), and can be done at any Sprint Nextel Service & Repair Location. If you do not subscribe to ESRP or TEP, the charge for the repair will be no more than $55. If you just bought this unit within 30 days ago, you should be able to get it replaced at no charge from the location you bought it from.
Dec 08, 2007 | Motorola Mobility i850 Cellular Phone
Motorola Mobility i850 Cellular Phone Logo
73 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
