Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Bad water & ice cube taste
Our Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. We replaced the copper tubing which delivers the water to the fridge and that didn't help. We replaced the copper tubing again with plastic tubing...no better. Any suggestions? Our tap water doesn't taste this bad. I have a kenmore Wide by side,  the water and ice were fine until I replaced the filter, now it smells and tastes bad.  We have looked for many solutions. I don't see how the lines are the problem, because when I put the old filter back in (we were going to send it for recycling) after we ran the water it was fine again.   I think a call to sear's with link to this site is in order.
  • Anonymous Oct 11, 2008
    I have the Kenmore Elite bottom freezer with ice cube maker. The ice cubes smell horrible, like onions or something weird. I do not have the water dispenser, just the ice cube maker. I throw out all the ice cubes after a few days and start fresh, still smell. What's up with this. I thought I'd be thrilled never having to make cubes again with trays, now I regret buying this thing.
    Help!!!
    New Friend:
I know EXACTLY what it is..we have the same issue with new filter replaced and have run 50 gallons of ice and water through this thing. It's toxic plastic chemicals that Kenmore AKA China uses to make these fridges. We're stuck with buying ice at the store..again!
Posted on May 09, 2013
  • 958 Answers
Then change your filter. the new filter could be different with the old filter. check the new filter, see if there is odor removal and taste removal with it.
if not then get the filter with carbon filter, odor and taste removal.
then with a new filter, run about 5 gallons of water before using the water for drinking.
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
2 Suggested Answers
SOURCE: Bad water & ice cube taste
We have the same problem; it started when we moved to a house with well water. Now we buy ice and dump it in the ice maker and drink bottled water. All this money for a side by side with water and ice despenser for nothing! We also have front loader washer smell. Is it well water? I miss the city...
Posted on Jun 23, 2008
Ice cubes taste bad
I have heard of people having problems with some stainless steel waterlines giving off a bad taste, if the filter is new you may need to replace the water line.
Mar 04, 2014 | Thermador Refrigerators
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
Nasty tasting ice cubes
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Jul 13, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Metalic taste in cold water and ice cubes from refrigerator
I had a similar problem and I was able to get rid of it by replacing the copper lines that go to the refrigerator with plastic ones. It didn't make any sense to me since the pipes are all copper, but the taste is gone and hasn't come back.
May 21, 2010 | Kenmore 57029 Side by Side Refrigerator
Water smelly bad taste. Sat for two months during kitchen remodel. Filter has been changed, and water flushed and ice cube ran several times. Can plastci lines be replaced? thanks.
When the fridge was turned off during that time ,the water left over inside the reservoir(plastic container inside the refrigerator side where the water keeps cycling and staying cold) might gone bad and contaminated the reservoir,in this case the reservoir needs to be replaced.But first try replacing the water supply line , if it's copper or a gray plastic pipe ,also could give bad taste to water.
Oct 01, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker water taste like chlorine but tap tastes fine
Put a in-line water filter on the water line if you want. The taste is from the food and items you have in the refrigerator. Clean it out and keep your items in proper storage. Ice collects the smells in the line and the fridge. Change your ice that is sitting in the bin, wask out the bin with water and baking soda. Hope this helps.
Apr 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
the feed line of the water source is bad replace it you will also need to clean the ice makers insides to remove the rest of the contamination
and 2 more suggestions:1) change the filter - older refers have the filter in the water line serving the ice maker - newer refers have the water filter in the refer (it looks much like an auto oil filter); 2) do not store ice for extended periods when ice use is not high e.g. during cooler months. Unless you use a full basket of ice over say a few weeks you should dump all and start over periodically.
thanks.
Sep 16, 2008 | Refrigerators
Very bad tasting/smelling water and ice cubes - Superba KSRS27QAAL05
Since I found that the water itself being fed to the trays and being dispensed was bad. I replace the nylon, reinforced plastice icemaker hose with 1/4" copper supply line. That, along with purging the hopper (getting rid of) any old ice as well as washing the hopper out real good and giving the freezer a general cleaning - seemed to do the trick. No repugnant odor or taste. (I didn't even replace the filter- the cycle is every 6 mos.)
Hope this helps others who may be experiencing this same prob with this type of side by side appliance.
Lou
Jul 30, 2008 | KitchenAid Superba Architect KSCS25INSS...
Our refridgerator has terrible tasting ice and water and we have tried everything to fix it. Is there a sure fire way to fix the problem. I would love to use the ice maker and water.
miracow
Mar 02, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
1,290 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
