Question about Lexmark X342n All-In-One Laser Printer
FAXES WON'T GO THROUGH
FAX PROBLEM: E906 ERROR CODE. A FEW PAGES GET SCANNED AND THEN ERROR CODE E 906 APPEARS.
  • ryujpn Dec 01, 2008
    same problem
  • 1,602 Answers
CONTROL PANAL, OPEN FOLDER, HIGHLIGHT PRINTER OF FAX MACHINE GO TO SERVER PROPERTIES OR PROPERTIES AND CHECK THE PORTS, DO SOME ALIEGNMENTS, UPDATE SONE DRIVERS, SEE ANY ERRORS
GOTO DEVICE MANAGE LOOKING FOR ANY TYPE OF MARK GREEN ARE GOOD AND RED AND YELLOW OR ORANGE IS BAD
CLICK ON THEM AND FOLLOW INSTRUCTIONS
ROD
Posted on Feb 04, 2009
Brother FAX-8070P memory shows full and does not send all pages at one time?
This message means the memory capacity of the unit has been exceeded. The amount of memory used depends on the amount or type of data on the documents being faxed or copied.
  1. If you get an "Out of Memory" message while scanning the first page of a fax, press Stop/Exit to cancel scanning.
  2. If you get an "Out of Memory" message while scanning a subsequent page, you can either press Fax Start to transmit the pages that were scanned so far or press Stop/Exit to cancel the operation.
When Fax Storage is set to On, a copy of all received faxes are stored in the memory, thus using up a % of the memory available for other functions.
The Fax Storage feature is utilized for Fax Forwarding, Fax Paging and Remote Retrieval. If you do not need these features, verify Fax Storage is set to Off by doing the following:
  1. Press the Menu/Set key.
  2. Press the arrow key until FAX appears on the LCD. Then, press Menu/Set.
  3. Press the arrow key until REMOTE FAX OPT appears and then press Menu/Set.
  4. Pressthe arrow key until FAX STORAGE and then press Menu/Set.
  5. Check the setting. The display will read ON or OFF. If the setting is ON, press the arrow key until the display reads OFF.
  6. Press Menu/Set.
  7. If you have faxes stored in the memory, you will receive a message that reads Erase all fax? 1. Yes 2. No. If you want to erase all the faxes in the memory without printing them out, press 1 (Yes) and then press Stop/Exit.
Note
    If you would like to reprint the saved faxes, press 2 (No), press Stop/Exit and continue to the following steps for instructions on how to print stored faxes.
If you do need the features that require Fax Storage to be On, the stored faxes will need to be erased or printed to remove them from the memory and to allow additional memory to be available. Follow these steps to print the stored faxes:
  2. Press the arrow key until FAX appears on the LCD and press Menu/Set.
  4. Press the arrow key until PRINT FAX or PRINT DOCUMENT appears and press Menu/Set.
  5. Press Fax Start.
  6. After printing is finished, press Stop/Exit.
Jun 06, 2011 | Brother FAX-8070P Plain Paper Laser
My Sharp UX-355L Fax machine printed unwanted information
Sounds like you have the machine set up to print reports on all occasions, fax transmission, error, etc. You can change this by doing the following:
1 Press these keys:
The display will show:
FUNCTION
TRANSACTION LIST
2 Press a number from 1 to 5 to select
the condition for printing.
ALWAYS PRINT A report will be printed after each
transmission, reception, or error.
ERR/TIMER/MEM A report will be printed after an error,
timer operation, or memory operation.
SEND ONLY A report will be printed after each
transmission.
NEVER PRINT A report will never be printed.
ERROR ONLY A report will be printed only when an
error occurs.
To print from memory:
If the memory becomes full...
If the memory becomes full while the document is being scanned,
MEMORY IS FULL will appear in the display.
♦ Press the START/MEMORY key if you want to transmit the pages
which have been stored up to that point in memory. The remaining
pages will be ejected from the feeder. After transmission, the memory
will be cleared and you can transmit the remaining pages. You
will also need to transmit the page which was being scanned when
the memory filled up.
♦ Press the STOP key if you want to cancel the entire transmission.
Hope this helps. : )
Mar 30, 2009 | Sharp UX 355L Plain Paper Thermal transfer...
OUTGOING FAX ERROR CODE: NG
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
To do this:
Press Function/Set, 3, 9.
This should take you to MEMORY TX
and MEMORY TX: ON?
Then press either the left or the right arrow (< or >) to switch on or off, and press Function/Set.
For the next fax transmission only, press < or > to select
NEXT FAX ONLY and press Function/Set.
This will mean you don't add any more to the memory and may be able to send faxes. There is a possibility that you will only be able to fax using manual transmission, but at least you should be able to use the machine to fax at all!
I apologise if the jargon is confusing, just try to go through the process one step at a time and you should be fine.
Hope this helps :)
Chris (ziraffa)
Dec 13, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Confirmation
By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Oct 14, 2008 | HP LaserJet 3055 All-In-One Printer
Hi, Remote Fax Error being displayed
As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
Note: The scanned documents will only be saved in the memory before the whole fax is sent if the Scan Before Dial option is turned on. (This is the factory default.) Up to 50 black-and-white fax pages can be stored in memory at standard resolution when there are no pending faxes in the queue.
Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX mode.
Press Select.
Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
Change the setting from Yes to No using the + (right arrow) button.
Press Select.
Note: The Scan Before Dial option controls whether a document is scanned before a call is dialed. This parameter only applies to a mono fax that uses either 200x100 or 200x200 resolution. Higher resolution mono faxes and all color faxes are scanned after the call is dialed and the receiving machine's capabilities are known.
Lower the fax transmission speed to 14400 or even 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
Press the Fax button, then press Options 15 times to get to ADVANCED FAX.
Press Select.
Press Options 10 times until MAX SEND SPEED appears on the LCD display.
Change it to 9600 BPS using the - (left arrow) button.
Press Select.
Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
Press Select.
Press Options 11 times until ERROR CORRECTION appears on the LCD display.
Change the setting from On to Off using the + (right arrow) button.
Press Select.
Note: Turning off this option makes it possible to receive a fax when the receiver fax machine does not support certain error correction modes. The X6100 Series only supports 1-D MH encoding with the error correction. Fax transmissions without ECM and other ECM types can result in bad quality on the received page.
Dec 19, 2007 | Lexmark X5470 All-In-One InkJet Printer
NOTE this option may vary to printer try USING OPTIONS TO SET CHANGES
To resolve the problem, try the steps below. After each step, try to send a fax again.
1. As some fax machines are not capable of receiving color faxes, legal size faxes, or faxes at 200x200 dpi resolution, make sure you are sending an A4 or letter size (not legal size) page at standard resolution:
* Press the Black button for a black-and-white fax. Press the Quality button to check the selected resolution.
2. Make sure the All-In-One has enough memory free when you want to save the scanned documents into memory before sending the fax. Please refer to the following document: Click here to link to the relevant document.
3. Turn off the Scan Before Dial option by pressing the following keys on the operator panel:
1. Press the Fax button, then press Options untill u see ADVANCED FAX mode.
2. Press Select.
3. Press Options nine times until SCAN BEFORE DIAL appears on the LCD display.
4. Change the setting from Yes to No using the + (right arrow) button.
5. Press Select.
4. Lower the fax transmission speed 9600 bps, as some older fax machines are not capable of receiving a fax at a high speed. To do so:
1. Press the Fax button, then press Options untill u see ADVANCED FAX.
2. Press Select.
3. Press Options untill u see until MAX SEND SPEED appears on the LCD display.
4. Change it to 9600 BPS using the - (left arrow) button.
5. Press Select.
5. Turn off ECM (Error Correction Mode) by pressing the following keys on the operator panel:
1. Press the Fax button, then press untill u see to get to ADVANCED FAX.
2. Press Select.
3. Press untill u see ERROR CORRECTION appears on the LCD display.
4. Change the setting from On to Off using the + (right arrow) button.
5. Press Select.
Nov 16, 2007 | Lexmark X4270 All-In-One InkJet Printer
HP officejet 7210 fax error
HP Officejet 7210 All-In-One InkJet Printer
Error code: 405
When I send a fax I have a dial tone and the fax feeds through, I hear the other end answer it says it is sending and then I get the printed page that says: "A communication error occurred during the fax transmission."
Oct 29, 2007 | HP Officejet 7210 All-In-One InkJet...
Lexmark X342n All-In-One Laser Printer Logo
463 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
