I an Optima ep719 dlp projector and have recently changed the bulb because my screen started flashing, but now it flashes for about 10 seconds then shuts down. i have put the old bulb back in and it now shows the same symtons.
  • jwalting Oct 13, 2008
    Its most definately something to do with overheat, however I does give me any LED indications, and can turn the unit back on within 15 seconds, it lasts ofr another 10 minutes and shuts down again after a slight period of colour flicking.
    I an Optima ep719 dlp projector and have recently changed the bulb because my screen started flashing, but now it flashes for about 10 seconds then shuts down. i have put the old bulb back in and it now shows the same symtons.Comment by jwalting, posted on Oct 13, 2008
    Brigadier General:
  • 6,966 Answers
A couple of initial suggestions:
  • try a hard reset, unplug from the mains for at least an hour and try again;
  • reference these FixYa pages; 1, 2.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 13, 2008
  • 19,396 Answers
That was not the bulb, your old bulb is still fine, when the bulb needs replacement, it turns off, do not start flashing.
Reasons for this can be a fault in the small board powering the lamp, a fault on the main board, or a bad cable or connector.
When it is properly overheating, it means that the unit is developing more than the normal amount of heat, and for this reason it shuts down (do not stays on flashing).
In your case , is more likely a faulty component, like a defective IC, that is manifesting the fault only after a while.
You can try inscecting the connectors (always power unplugged), checking if there is excessive dust on the inside and eventually hoovering it (from distance not to damage components inside), and eventually, carefully removing and putting back lamp. I don't think that will fix it, but you can try.
To fix this you will probably need a technician. If you decide to call for repairs, you can use the phone number listed on the owner manual to contact factory service.
  • 10,594 Answers
Please confirm all fans are running in projector. If fan stops this problem happens.
  • Shahid Electronics
    Shahid Electronics Oct 13, 2008
    Please reset lamp time according to user manual.
    Check any LED blinks as error code according to below mention picture ...
    You should Reset Lamp Hours after Lamp Replacement as per below mentioned picture.
    Above info taken from user manual of Optoma EP719.
    Guru:
  • 1,894 Answers
I think this unit is shutting down due to some heating problems
please check if the unit is getting over heated in power section
Posted on Oct 07, 2008
Sharp XR-30X starts up then shuts down after 30 seconds.
sounds like it is overheating -- are the fans installed pointing the correct direction, all spinning up well?
Jan 21, 2014 | Sharp XR-30X DLP Projector
I have an Optima Model EP719 Projector. Suddenly I am getting white vertical lines and can't find a solution for removing them.
I would try switching out the DVI cable first. It could be faulty. This would be the easiest and cheapest solution to check.
Jun 09, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma EP719 settings?Colorwheel? Bulb?? Cable?
take the lamp out and shake the projector gently and tilt it in all directions and listen for something loose near the front of the projector. if you hear something it could be the light tunnel has collasped or the colowheel has lost its segments.
May 21, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optima EP719 won't power on - when power button
check that the lamp is on securly and that the cover is on securly too.
Feb 02, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
I have the Optoma ep719 and it will not power on. I plug it in the power light flashes. When you hit the power, the fans will come on and the bulb will light up for about 2 sec. Then it will go back to the...
some dry out, and you can't tell by looking at them. see if the colorwheel is spinning. if it chirps before it shuts down, or if it doesn't spin at all, replace it. otherwise replace the ballast.
Oct 27, 2009 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Projector performance
I've been reading that indicates a dying lamp bulb.
Jul 02, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Televison & Video Logo
4,148 people viewed this question
Top Televison & Video Experts
