Question about Canon imagePROGRAF W7200 InkJet Printer
W7200 PRINTHEAD ERROR
Take it out and clean all contacts, worth a try as they cost £500 from canon. An engineer told me they usually only last about a year and after problems with the cutter failing and colour problems in drawings we got a new one which fixed the problems. Third new printhead in 4 years, canon should be ashamed.
Posted on Oct 07, 2008
Hi my plotter always print a blue color on all pages.for each kind i print i have it has no differences.does any one knows about my problem? my plotter model is Canon W7200 thanks best regards
Try printing the Nozzle Check pattern. Check if colors are printed correctly. If not, try Printhead Cleaning A first then check again the Nozzle Pattern. If there's a small changes to the pattern, try Printhead Cleaning B. If problem persist, try changing the Printhead.
Oct 09, 2014 | Canon imagePROGRAF W7200 InkJet Printer
Just replaced the printhead with a new one and get error message E02802
are you sure you have placed the right head, this error has to do with wrong head.
Jan 21, 2010 | Canon imagePROGRAF W7200 InkJet Printer
Canon w7200 service manual
You can download service manual for CANON W7200/W7250 from;
http://dl.owneriq.net/f/fb283499-7d17-4044-bf68-b415e6ed0073.pdf
Regards;
Hassan
Sep 03, 2009 | Canon imagePROGRAF W7200 InkJet Printer
Plotter canon w7200
HO il medesimo problema...come l'avete risolto?
Grazie
alberta
Feb 10, 2009 | Canon imagePROGRAF W7200 InkJet Printer
Error : print head error . turn power off
have you tried reseating the print cartrige or the wire strip that connects to it?
Oct 16, 2008 | Canon imagePROGRAF W7200 InkJet Printer
Canon W7200 Error code E02D05
The Service Manual says:
E02D05 Airflow fan error
Fan rotation could not be detected while the air flowfan as running.
Probable problem locations
Air flow fan, engine controller, system controller
Remedy
1. Cable connection check (check - replace
2. Replace air flow fan
3. Replace engine controller
4. Replace system controller
I wish success
AToe
May 05, 2008 | Canon imagePROGRAF W7200 InkJet Printer
Problem in w7200
Hi - I had a different problem involving the carriage, but the solution may help you. There is (or should be) a pin on the carriage, visible on the right side when you lift the plastic pieces that hold in the printhead. This pin is about 2 in long and varies in diameter from about 1/8 inch diameter to 3/16 inch diameter. If this pin is not there, which in my case it had fallen down into the ink purge unit, the black will be shadowed by magenta. I don't know how to fix that part, but if the pin is gone you may soon have a bigger problem, which is the pin binds in the gears of the ink purge system and the printer won't do anything after that. Check for the pin, and if its gone and you live in an area where someone can service your machine call them up! In my case i was able to dig the pin out myself and the printer works again, but there is a slight overshadow of magenta.
Nov 21, 2007 | Canon imagePROGRAF W7200 InkJet Printer
Canon imagePROGRAF W7200 InkJet Printer Logo
663 people viewed this question
old marine
old marine
