Question about Compaq Evo N610C Notebook
Multiport w200 wireless goes to blue_screen with belkin G+ router
I have a compaq evo n610c + multiport w200 with XP sp2. every time switch on wireless laptop goes to blue screen. Belkin N1 router works ok with fsc laptop.
  • foldynp Oct 29, 2008
    I've completely the same problem. Compaq ECO n610c with W200 wifi, WXP, SP3 goes to bluescreen everytime I switch on wifi. I don't know router type, but it is in Copenhagen's municipal library (diamond)
  • michaelplevy Nov 04, 2008
    I have the same problem on the same hardware. It used to work great for me, but about a hear ago I had to reinstall windows. SInce then, I have not been able to get Wifi working.
Http://www.fixya.com/support/t612983-blue_screen_hp_wlan_multiport_w200 seems to have the solution.
It says:
Rollback the W200 driver to version 1.00C. Subsequent drivers are incompatible with XP SP2.
Unfortunately, WPA support came in version 1.00E, so W200 + XpSp2 = no WPA support. :(
I removed my wirelss drivers and compaq wireless client software, then installed the older driver from http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=hb-13082-1&lc=en&cc=fr&dlc=en&os=228&product=235687&lang=en which is sp23031. This seems to have worked. multiport w200 wireless goes to blue_screen with b - s.gif
Posted on Nov 04, 2008
Hi Guys. Compaq Evo N610C equipped with Wlan Multiport w200. Can not connect to equipment using WPA2 encryption. Do you know a solution ???? Thanks
Yes you have to go to your internet's routers web setting page and change your settings from whatever you have now to WEP and follow these instructions.
Sup guys i found the cure to this horroble blue screen death for this N610c. Ok i called hp and they wanted $69.99 for tech support well just imagine what i told them to do lol. Anyway i did my research and guess what i found out. That the updated driver is made to screw up your connection so that you have to call tech support and they can steal your money.
Im a computer technician since 1990 and what i discover was that beautiful driver that works here is a list of drivers that cannot be used on the Evo N610C because it causes conflits that no one can fix i know for sure.
List of the no no drivers are:
These drivers will make your screen go from windows to BLUE.
sp29156
sp28252
sp29156
Here is how i fixed the problem i deleted everything that had to do with LANMultiport drivers every single one then i searched my laptop to remove the rest of the lost files.
Once that was done the i installed this driver (sp23031)
Once that was installed and the puter rebooted the wifi card found my wireless connection and asked me to input my Network Key and walla it works great now without any problems.
Im using windows XP Home i just bought memory cause im installing windows 7 32 bit.
Finally the key is this driver (sp23031) for both home and pro eddition.
Here is the link to download your driver:
It works! Please hit me up a feedback
Dec 15, 2010 | Compaq Wireless MultiPort W200 802.11b...
Compaq evo N610c working fine until a few months ago when Wlan w200 started having problems. I was getting blue screen of death when ever I had internet connection for a small period of time (about 40...
dear sir good day this problem used to appear when a bad driver is installed or a damaged windows in near so reinstall your system as Microsoft says in this article http://technet.microsoft.com/en-us/library/cc957609.aspx thank you
Dec 27, 2009 | Compaq Evo N610C Notebook
Need help with Wifi Connection with COMPAQ EVO N610C LAPTOP
First you will need a router which will enable you to create a wireless network for your internet connection. I recommend, if you're purchasing online, to use Tigerdirect. Then you would need a USB wireless adapter for your laptop which will enable it to communicate with the wireless router and establish an internet connection.
Below are some links for the most affordable and best rated products you need.
USB wireless adapter.
Wireless router
Oct 05, 2009 | Compaq Evo N610C Notebook
Compaq evo n610c
yes i solved the problem. Remove the wireless lan. Start the computer go to regedit hkey_local_machine/software/Compaq Wireless LA delete it and restart. download SP23031 search on google and run without wireless lan W200. Restart with the card installed it will configure itself.
Jun 24, 2009 | HP Compaq Evo n610c Notebook
W200 cause a blue screen
First of all: If you install SP2 you don't have to install SP1 over it. It already did. Secondly, don't install SP3, it destroys Windows XP.
Try reinsalling the PC with SP2, install the drivers and do nothing else, see if that helps.
If not, by all means post back here,
Yannick.
Jun 16, 2009 | HP WLAN MultiPort W200 802.11b Wireless...
Blue screen on HP WLAN MultiPort W200
May 21, 2008 | HP WLAN MultiPort W200 802.11b Wireless...
Wlan W200 connection problem
There is a solution to this, and you won't have to buy a new card. The folks at HP, however smart in their design of this laptop, have not properly updated the bug fix for the wlan w200 drivers. What you'll need to do is actually take back your network adapter driver all the way back to Version 1.0 revision C. I did this with an n610c that I got for free because it was BSOD'ing every time the wireless was turned on. For the most part the wireless can handle older routers and wlan areas, but will BSOD when within range of a wireless "N" adapter. Simply download the driver version 1.0c and you should have no more issues.
Tip: You can disable the card manually by pressing your "Fn + F2" keys, rather than trying to navigate your menus before getting the BSOD.
Nov 07, 2007 | HP WLAN MultiPort W200 802.11b Wireless...
WLAN Multiport W200 not connecting to wireless network
Anyone who has this problem: the problem is with the W200 driver that HPclaims you should use. Download this driver instead and your problems should be fixed:
Oct 20, 2007 | HP WLAN MultiPort W200 802.11b Wireless...
Compaq Evo N610C Notebook Logo
570 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
