Question about IBM E54 15" CRT Monitor
Ibm 14"crt monitor white light is blinking screen is blank
When power on my monitor light is blinking but there is no display plz tell how to solve this problem
  • IBM Master
  • 19,396 Answers
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
Samsung 906vw blank screen
if the power light indicator is just blinking with no display, you must checked the power supply the common cause bulging electrolytic capacitor. just replace with the same value and rating then the problem solved.
Jul 22, 2012 | Samsung Computers & Internet
Dell monitor blank. nothing appears on screen. light is blinking by minitor power button, but nothing at all on screen. I hooked up to my laptop, still nothing. Checked power/ tried new power cable. No...
Make sure you set up your laptop to display to a second screen. Depending on your Operating system, go to your display properties and go to the settings tab. Then click on the second monitor and enable it.
Apr 08, 2009 | Dell E773C 17" CRT Monitor
Light blinking problem in LG 775N ( White ) 17'' CRT monitor
any shortage in secondry side of monitor ..
plz check shoting.
Feb 25, 2009 | Computers & Internet
Monitor is blank when we turn the computer on.
Maybe not. Find the FN key. It is usually BLUE in color
Then look on TOP row of Computer keyb (or all over) and find CRT/LCD.
Press the FN and that key and your screen should come back. You accidentally sw. it to CRT (outside, external monitor)
Jan 14, 2009 | IBM ThinkPad T23 2647 Notebook
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Contrast problem
my monitor IBM e54 have a problem its like the right button from the monitor automatically activates. so everytime i work contrast box appears. how can i solve this problem?
Jan 25, 2008 | IBM E54 (Pearl, White) 15 in.CRT...
Mag innovision LT716s monitor model 700p blank screen
Try to adjust the frequency.
Right click on desktop , properties, (my windows is in portugese. Dont remember the right name) configuration, button "advanced", display.
I hope to help u.
Good luck
Dec 17, 2007 | CTX PL 9 19" CRT Monitor
Blank screen (led indicator is orange)
it could be the cable from the monitor to the pc it is defactive try a new one cuz if the monitor works then it is the cable that is makeing your screen go blank
Oct 10, 2007 | IBM E74 17" CRT Monitor
IBM E54 15" CRT Monitor Logo
369 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
