Question about BEL 980 Radar Detector
Bel 980 Error Message
I have a Bel980, in last two days in start up routine it gets part way thru and then flashes the Error Message ?PLL LCK. No solutions in Handbook.
No Tech support from dealers now. Help, feel naked without it !
Broken Cord plug
you can buy new ones on ebay
Apr 01, 2009 | BEL 980 Radar Detector
Does the bel 980 need to be upgraded ??
BEL no longer offer upgrade or repair for the BEL 980 detector
May 27, 2008 | BEL 980 Radar Detector
My bel 980 speaker quit working
On mine you can barely hear it on the 9 setting. I put in a different speaker but no difference. I did look up the number on the IC chip near where the speaker connects (34119) and it came back to a 500 mW audio amplifier, so you could probably replace that and fix it. I think it's what you call a flat-pack style chip. Not as bad as surface mount but will still require a tiny soldering iron. I think the actual part number ended up being MC34119D and should cost a dollar or less.
Apr 24, 2008 | BEL 980 Radar Detector
980: Fatal Error
From the Service Manual:
*Service call
*Error by media
clinging to the fuser
*Media has clung to the fuser.
*Power OFF
Replace the fuser unit.
Suggestion -
Before you replace the fuser, take it out and check for a piece of stuck label, paper, etc. You can spin the fuser roller by turning the gear on the side.
Apr 07, 2008 | OKI C5800Ldn Led Printer
Operating Voltage
It is 12 volt (or at least mine is). You should be able to connect directly to a fused supply, but I would advise checking output with a meter.
Feb 17, 2008 | BEL 980 Radar Detector
How to open Bel 980 case
they are two on back thke the bottem then the top will come off the problem is there are two hinges in the front part on each side u have to compress each side with a very tiny flat head screwdriver. note be very careful this unit is not make to take apart easy but it can be done i have the same problem i am going to radio shack to see if the have the part for the voltage but first i am going to re sader the contection first. hope this works mark
Feb 16, 2008 | BEL 980 Radar Detector
Bel 980 problem
I have the same thing wrong with mine ! I put it in my other car and it works fine. Found out it was my alternater was not working right! Hope this works for you
Nov 08, 2007 | BEL 980 Radar Detector
BEL 980 Radar Detector Logo
186 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
John Nolan
Jerry Greenberg
Jerry Greenberg
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
