Question about Refrigerators
Dual zone Danby Wine Refrigerator. Sounds okay running. Both areas now cool to only 62-64 degrees.
  • 958 Answers
Adjust the thermostat all the way to the coolest position and observe it for 24 hours
if it is still 62-64 degrees, then something is wrong. observe what is happening with the unit. is the compressor running, is there a fan which could not be running? or anything that you think is not right.
tnx 4 using fixya,
Posted on Oct 07, 2008
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Sep 26, 2016 | Danby Silhouette Dual Zone DWBC14BLS 13.90...
How do I fix a 2 Whirlpool/Danby WWC287BLS 2 zone wine cooler with 1 zone that operates correctly at set temperature but the other zone gets way too cold (36 degrees) and the compressor keeps running.
Check to see if the thermostat is possibly being blocked by something. If one zone is working correctly there must be an obstruction or problem with the thermostat sensor.
Sorry can't be of more help
Nov 24, 2014 | Furniture
Wine cooler doesn't cool
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oct 06, 2012 | Kalorik WCL-20629 18 Bottle Dual Zone Wine...
I just bought a dual zone wine cooler. What temperatures should I set both compartments to?
Red wine should be stored between 58-68 degrees Fahrenheit and the whites should be cooled at 46-56 degrees.
Jul 31, 2012 | Furniture
Temperature in both upper and lower zones will not go lower than 50F. Cooler has 3 bottles of wine. Is there away to recharge with coolant/clean fans...? Thank you
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor.
Before cleaning the condenser coils, unplug the refrigerator to avoid a shock hazard.
Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.
Jul 10, 2011 | Danby DWC283BLS Wine Cooler
Compressor runs and gets hot but does not cool unit
This product has been discontinued
i dont think many danby units are parts supported
more likely generic after market parts fitted by air con mechanics do the job
relay first might be a thematic one and an compressor motor fan relay
then check gas pressure
Mar 06, 2017 | Danby DWC283BLS Wine Cooler
Three Temperature zones
Did you read the owners manual? It will be kind of hard to tell you because there are so many different settings for different areas.
Dec 26, 2007 | Danby DWC310BL Wine Cooler
Dose not get cold enough?
Does the compressor run or shut off when it gets to 55 &57? Leave unplugged over night and try again.. Let me know.
May 30, 2007 | Danby DWC283BLS Wine Cooler
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
