Question about HP Pavilion dv6000z Notebook
STOPWATCH CODE IN ASSEMBLY LANGUAGE
Please.... it must be simple...
  • 2 more comments
  • mrl05 Nov 17, 2008
    i need to create a stopwatch that will display on an lcd screen for hcs12 board. Also the pushbuttons are used to start, stop and pause the stopwatch. please help
  • g-22 Nov 20, 2008
    stopwatch in assembly language with pushbuttons that would start, pause, and reset on the lcd screen
  • kivenn Mar 16, 2009
    VB, Visual Basic
  • The Tech May 11, 2010
    What type of code do you want?
    VB, Visual Basic
    VB Script
    C++
    C#
    Java
    Javascript
How to create a timer layout and codes using the visual basic 6.0?
Posted on Mar 16, 2009
    Problem Solver:
  • 11 Answers
HP Pavilion DV6000 Notebook main problem's are Power Problem, Vista Error etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here
Posted on Oct 08, 2010
Assembly
Posted on Nov 18, 2008
  • mrl05 Nov 18, 2008
    i am using xp
Do I need a stopwatch for running?
A basic stopwatch is pretty helpful when you're going for a run. It helps you keep track of your endurance progress in comparison to the distance you ran. I bought a simple 10$ stopwatch and it serves me pretty good for my running routine.
Aug 02, 2012 | Exercise & Fitness
How do i stop the chime on the hour with a Timex marathon stopwatch
http://www.timex.com/info/Product_Instruction_Guides_Downloads
There are two ways to find the user manual for your Timex watch.
1. Find your watch on the list below and click on the language link for your manual.
2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table at the bottom of the page.
http://assets.timex.com/user_guides/W15_M774/W15_M774_NA_EN.pdf ??
Feb 08, 2011 | Timex T5G811 Marathon Stopwatch
How to stop stopwatch on revo rv1006 watch changed the battery but need to stop the stopwatch
Push the upper button once. The stopwatch hand will freeze. Push the bottom button. Stopwatch hand should move to ZERO position. Rate me, please.
Jun 24, 2010 | Watches
I need the operation manual for the 228 stopwatch
You can get the manual on link below.
http://www.sportline.com/manuals/228.pdf
Please rate 4 thumbs for the free answer
Mar 01, 2010 | Sportline Stopwatch
Festina Dashboard watch - Adjusting the hand of the stopwatch
Your watch has quartz movement and stopwatch adjustment by one step (one full second) only. That means you will not be able to adjust stopwatch hand by using pushers on your watch as each push of the pusher will advance stopwatch hand for the full second, not the fifth or the tenth of the second, and the hand will stay slightly off anyway.
This happenened because the IC (integrated circuit) in your watch miscalculated the teeth count on chronograph wheel and stopped one or two teeth past or under the zero point. It doesn't happen very often, but in your case it did and the only solution is to find your nearest watch repair shop and ask for resetting stopwatch hand to zero.
This procedure needs partial disassembling of the watch and quite a great skill as the stopwatch hand must be removed and then refitted with great accuracy. All this needs to be done by very specialized tools as well.
I think this is the only solution of your problem unless you can live with that and just leave it as it is.
Do not forget to rate, please.
Feb 09, 2009 | Festina Dashboard 6719/3 Watch for Men
What is a compiler and ite story
A compiler takes code that you have writin, and 'compiles' it into machine language code ex.10010011, a language that your computer can understand and execute.
Jan 15, 2009 | Computers & Internet
How do I use the stopwatch on iPod nano?
"iPod Software 1.0 for iPod nano introduces a Stopwatch feature. You can use the Stopwatch as you exercise to track your overall time and, if you're running on a track, your lap times too. The Stopwatch menu is located in the Extras menu. To access the Stopwatch from the main menu, select Extras, then Stopwatch, and then Timer (Extras > Stopwatch > Timer) to see its display. Total time of session Current lap time Left button (Start function shown)1 Battery indicator Right button (Clear function shown)1 The left and right buttons' names and functions will change, depending on the current state of the Stopwatch. Using the Stopwatch When you first enter the Stopwatch screen, the left button is labeled Start and the right button is labeled Clear. To use the Stopwatch, select the Start button (use the Click Wheel to highlight the Start button, then press the Center button). The Stopwatch creates a new session, and both the total time of the session and the current lap time begin counting: When these counters begin, the left button changes to Pause and the right button changes to Lap: If you select the Lap button, the current lap time will be recorded in the session's log, then the Stopwatch resets the lap time to zero and begins counting the new lap's time. The total time of the session will freeze for 5 seconds after you select the Lap button so you can quickly view your total time at the end of that lap. After 5 seconds, the total time of the session displays the correct total time and resumes counting. If you select the Pause button, both timers will stop counting and the left and right buttons will change to Resume and Done, respectively. If you select Resume, both timers will begin counting again. If you select Done, the Stopwatch records all the final times and creates statistics for your session in a log. Please note that selecting the Done button does not reset the display. You will see the final times for your total time and lap time displayed: To reset the display, select the Clear button (appears after you click Done and then select Timer again). Stopwatch Behaviors You can play music and use the Stopwatch at the same time. When iPod nano displays the Stopwatch screen, the Play/Pause, Next/Fast-forward, and Previous/Rewind buttons control music playback as usual. If you're playing music, you'll see an icon in the upper-left corner of the Stopwatch screen that indicates the current playback state: A play icon indicates that music is currently playing. A pause icon indicates that a song is currently paused. You can use the Menu button and the Click Wheel to navigate to other menus without interrupting the Stopwatch. Note: The Stopwatch will prevent your iPod from sleeping if it's counting. The Stopwatch will automatically stop if any of these three conditions are met: The total time counter reaches 24 hours iPod goes into hibernation (you can start it again when you wake iPod) You conne
Sep 28, 2005 | Apple iPod nano
HP Pavilion dv6000z Notebook Logo
1,530 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
