Question about Toshiba (4CH-VOUT) Sound Card
BIOS Disc needed
My laptop is toshiba dynabook Sattelite 1801 System unit.
When I start laptop it shows one dash blinking on black screen.
When i go to boot menu by pressing F2 key,It gives me option
1) Floppy Disc
2)CDRom
3)Internel HDD
4)LAN
Once it has shown Insert BIOS Disc in Disc Drive....
I am not getting the problem.........
Please suggest...
Your sugetion will be valuable for me..
Thanks and Regards
Rahul
  • 1 more comment
  • rago1985 Oct 07, 2008
    thanks 4 suggetion,
    boot from internal hdd
    Nothing is displayed on screen only dash blinking apart from the boot option.....
  • IT aid
    IT aid May 11, 2010
    what OS are you using ?
  • IT aid
    IT aid May 11, 2010
    hi
    check your BIOS configuration ,try boot from internal hddand let me know what happend?
    regards
Windows XP....
Posted on Oct 08, 2008
Once powered on it goes to black screen and says - INVALID SYSTEM DISC,replace the disc, and then press any key.
Are you sure the BIOS is set to boot from hard disk?
It looks like it is trying to boot from network (PXE) and then from floppy disk.
Jan 04, 2014 | Computers & Internet
My Toshiba Satellite L45-S7423 PC Notebook will not star it brings me to a screen with an underscore key blinking.how do i get it started?
Hi King,
I see that you are having issue with your Toshiba and as you mentioned that you are seeing a black screen with a blinking cursor and I believe that it is on the upper left side of the screen.
Having this blinking cursor means that the machine is not booting into the Hard drive, we will check several things on your laptop to find out what is causing this on you laptop.
  • First as soon as you power your Laptop ON keep on tapping f12 to get to the boot menu, once you see the boot menu screen it will show you a list the first one should be you Hard drive it should say SATA so on ans so fort click on it then press enter this should boot into your Hard Drive but it still you get the blinking cursor then we will need to check the BIOS.
  • To get into the BIOS from shut down as soon as you power the system on keep on tapping F1 this will show you a Blue screen it may say Phoenix BIOS on the upper left side or center or may be different,
  • Once in the BIOS screen there will be tabs on top of the screen for options, look for boot check the Boot sequence and change the first boot priority to the Hard drive.
  • But doing both the instructions above will only work if the Hard drive is detected, by doing F12 for the Boot menu if the Hard drive is not on the list then the Hard Drive will most likely not be in the BIOS as well and this means that th Hard Drive on your system may need replacing.
I believe that this is a far as we can go since there is no other option to do regarding this concern, unless you would know how to open up you Laptop from beneath and re-seat it from it connection, re-seat meaning remove and reconnect.
Have a nice day I hope that I was able to provide details that can help .
Apr 07, 2011 | Toshiba Satellite L45-S7423 Notebook
Need help with toshiba dynabook satellite 1801
Toshiba bios password removal process is meant for use on Toshiba laptops that you own or have had permission from the rightful owner to remove the password. If any of these processes are done incorrectly it may result in complete system failure or permanent system damage (you've been warned!).
Some Toshiba bios passwords can be reset using the Key Disk.exe utility, to do this you need a 1.44Mb floppy disk. Format the disk using Windows and then with a hex editor, change the first five bytes of the second sector to 4B 45 59 00 00.
Then put the floppy into your machine and boot it up, you'll be asked for a password, just press Enter. Then when you're asked to set the password, type Y then Enter, this will get you into the bios configuration where you can then type in a new password.
Aside from the KeyDisk, you can build a parallel Loopback plug, this is a simple device that plugs into the parallel port of the machine and removes the password when you boot it up.
To make it you will need a 25 pin DB25 plug, take the plug apart and join these pins using some old cable;
Pins: 1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15, and 18-25
Plug it into your parallel port and boot up your machine, the password should be removed as soon as it boots.
Note: This will work on majority of older Toshiba's (1995 – 2002) and obviously only ones that have a parallel port.
Apr 28, 2010 | Toshiba Satellite A135-S2276 Notebook
Blinking white dash during boot.
Something has messed with your MBR, master boot record, which is a small sector at the beginning of your first hard drive which tells the bios which partition to boot. You'll have to use your xp or vista's installation disc to repair the system.( Choose; repair this installation of windows when prompted )
While you are in the bios check under the boot section the order of your boot devices. If you have more than 1 HD check that the one containing your OS is first.
May 08, 2009 | Toshiba Satellite A105-S4384 Notebook
Toshiba Sattelite Pro
r u check settings in bios
for harddrive there its showing or not in bios otherwise first try to configure the harddisk then try for hardware part
Aug 24, 2008 | Toshiba Satellite A60-S1561 Notebook
Cmos error on bootup
Carefull! The 1800 had a notoriously lousy MB/bios problem. While it still works, get yourself to Toshiba support and get the LATEST bios for the right version of your board, and get it IN ASAP...
Otherwise you might well end up with a brick..
Oct 23, 2007 | Toshiba Satellite 1800-S204 Notebook
Computers & Internet Logo
116 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
