Question about Cameras
Minolta/maxxum 7xi will not switch on. top display shows film symbol and zero in bottom right.
I got another camera, Dynax 300i from ebay with exactly the same symptoms. While playing ( ! ) with the new one; I released the back and it reset into normal working mode. Tried the same on my 7xi and that has reset itself and is now working correctly.
Thanks for your time.
Posted on Oct 10, 2008
How to rewind film on minolta maxxum 5000?
Open door in the dark room.
See if it's already rewinded, but could be a stuck counter
May 12, 2014 | Minolta Maxxum 5000 35mm SLR Camera
I somehow put my camera setting onto panorama, how do i change this back to normal?
I think you mean Landscape. Just push the button next to the top display panel. Push it again until it shows the setting you want.
Panorama is not available on the QTsi. Panorama mode blocks out the top and bottom of the frame to give you a shorter picture top to bottom.
Landscape mode just biases the camera towards smaller lens openings to get more of the image in focus. By default, this makes exposure times longer, so use a tripod for landscape images.
lightspiritphotography.com
Dec 11, 2009 | Konica Minolta Maxxum QTsi with 35-80 lens...
Minolta dynax 5 camera, diplay has disappeared
does this model have the eye viewer also? if so check and make sure the switch is toggled to displayed and not for the eye viewer. look into the eye viewer and you should see your display. it is simple switch to toggle it to the display mode.
Apr 10, 2009 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Minolta maxxum 5 film camera shows blinking battery
It could be a problem of bad conductivity. Try cleaning contacts with spray oxide remover.
Onofrio
Mar 13, 2009 | Konica Minolta Maxxum 5 Date with 28-80...
How do i replace internal battery on the minolta maxxum 7000? i replaced the AAA batteries, but it still just flashes ''film'' in window.I have no manual and dont know how to get the film out.HELP!
Unscrew battery compartment on the right grip, and remove the battery holder (AAA's in most Maxxum 7000's) In the compartment you should see a silver colored metal plate, held on by 6 small phillips screws. Unscrew these, and carefully lift the plate, and move it aside (there's a tiny wire soldered inside the plate, so don't break it off).
Inside there should be a CR2016 lithium button battery. Replace it, and reassemble in reverse order.
NOTE: This probably won't fix any issues regarding the removal of the film, as the 2016 is just a memory backup battery for when the main batteries are removed.
to remove the film, install fresh main batteries, turn on the camera via the "Lock" switch and rewind the film. on the back of the camera, just behind the LCD screen, above the film door, you will see a grey button marked "R". Push and hold it, while sliding the gray slide switch immediately to the left of it to the left. The film should now rewind.
When the film is done rewinding, open the back via the sliding latch on the left side of the body with the gray button in the middle. Push the button, while sliding the latch down.
To insert film, place the cartridge in the same place and orientation as the old roll, and pull the leader over to the red dot on the bottom right of the film compartment, and close the back. it should advance to the first frame if done correctly, or blink 0 if done wrong.
If you need anymore assistance, contact me via email cwrrailfan at yahoo dot com
Have Fun with your 7000!
Mar 11, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 5000
I had the same problem with a maxxum 7000. Traced it to a bit of corrosion in the battery pack. It let just enough power through to run the computer, but upon releasing the shutter, it shut off.
You might check that. corrosion can be cleaned with vinegar.
-John
Oct 07, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Minolta Maxxum 7000
ONline manual from Minolta says "winding motor problem", try removing battery and reinstalling. It didn't work for me though.
Jul 13, 2008 | Minolta Maxxum 7000 35mm SLR Camera
What is the "light" or just red color at the bottom near the "open" the back button of my Minolta Maxxum 5 camera?
Elizabeth,
What you are describing is the film chamber lock indicator. Basically, once a film is loaded, you cannot accidentally (or intentionally!) open the camera until the film has been fully rewound. This is to prevent you ruining a film. The red indicator is just to let you know it's locked.
More details are on page 23 of the camera's manual. If you haven't got one, you can download it from here.
Matt
Apr 16, 2008 | Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Minolta Maxxum 7xi Complete User Guide
Hi , try to visit the fixya recommended site www.CameraBooks.com
Mar 18, 2008 | Cameras
Cameras Logo
93 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
