Question about O2 Xda II Smartphone
My o2 celphone won't turn on
When i was walking to the second floor i tried to turn my o2 cellphone on. then it doesn't turn on . but it is fully charged and doesn't have a sim card i have the same problem as you had with you O2, it wont turn on and i even tried the hard resetting but it didnt work. i dont know how to do the boot loader as the other solutions have said.. i hope there's another solution to what has happening to my PDA.
3 Suggested Answers
rhuzmarhuz
  • 167 Answers
SOURCE: my o2 celphone won't turn on
O2 XDA Atom / O2 XDA Atom Pure / HP rw6828:
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device.
*Note: Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost.
i hope it will help your prob.
Posted on Jan 13, 2008
  • 3 Answers
Dear Jlrenzzy,
What Rhumarhuz say is true, however if your phone cannot do what he says anymore then try this step:
1. go to boot loader by pressing cam+reset (remove battery first for about 5-10 seconds then put it back in)
2.you should see quanta boot loader MN1 etc on a blank screen.
3. connect your phone to pc via USB then perform Rom update.
you can download those utility from the O2 website (seeo2.com)
Posted on Jun 09, 2008
Phone is charged and won't turn on, also reset doesn't work
your battery is probably broken, try replacing it (ifixit.com), or let someone else fix it for you.
Dec 02, 2012 | Apple iPhone 4S
Computer working perfectly fine one day, the next computer won't turn on for no apparent reason. when switching the power button on, computer begins to boot up for a brief moment, then automatically...
It's probably your logic board. One thing you can try that may help you out is to take out the battery (if you can) and press and hold the power button for 10 seconds. If it's a capacitor problem on the board that should discharge it. If that doesn't work then you should probably try to turn on the computer while holding CMD + Option + P + R to reset the PRAM. If that doesn't work then you're probably going to have to seek professional help.
Aug 04, 2011 | Apple Computers & Internet
My Canon Powershot SX120is camera was dropped on a high school gym floor. Since then it hasn't turned on. I think the battery connections on the little battery door are damaged, since you can tell...
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 25, 2011 | Canon PowerShot SX120 IS Digital Camera
Just had both o2 sensors replaced and now the truck won't shift from 2nd to 3rd gear. Evidently it had been slipping a bit before but now it won't shift into 3rd at all. The tranny is an E4OD......
O2 Sensors --- not related to shifting
New transmissions --- are only new once
When installed on the assy line
Has to be rebuilt if necessary
PO 147 ---O2 Sensor Heater (Bank 1 Sensor 3) don't have one of those
PO714 -- Trans Temp Sensor -heat for the slipping
PO 471 --- Exhaust Pressure Sensor -don't have that either
Need a new guy
Not very professional were they
Jun 13, 2011 | 1997 Ford Expedition
Failure in power supply
Try to power drain your celphone anshul_sood, turn off celphone, remove battery and hold the power button of your celphone for 5 seconds. Then plug back the battery and charger. Turn on the celphone..
If symptom persist, go to the nearest nokia center in your place....
Hope this helps...
May 08, 2010 | Nokia 5800 XpressMusic Smartphone
My celphone is no signal
If your cellphone has no signal, then maybe there is no network coverage in your area or there is network problem being experienced in your place. Try to switch other sim to know that your cellphone is causing the problem or the network.
Oct 29, 2009 | Cell Phones
About Xda mini o2 problem, how can i now if my cellphone is fully charged?
tap on the battery icon you can see the percentage of battery charged, on charging orange light turns to green when battery is full.
Oct 26, 2009 | O2 Xda II mini
In my nokia cellphone the ring tones would not sound when someone is calling me and i tried to go to menu and ring tones but it will just turn off the cellphone and then bat on but the ring tone will not...
In this check the battery status. If the battery is fully charged take out the battery and the sim card re-insert it after 2 minute, then go to settings select profile then incresed the volume and try still if it is not working you need to walk in to the nearest service center it might be the hardware issue.
Oct 12, 2009 | Nokia 1661 Cell Phone
Hi i have the problem to my cellphone...... plz hurry and help me
remove the battery for one second and put it right back in and that should unlock it
Jan 15, 2009 | Panasonic Home Theater System System
Dec 01, 2007 | O2 XDA Mini S Smartphone
O2 Xda II Smartphone Logo
212 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
