i have ford explorer 4WD .and it was drive ok.after that the reverse gear not working .but the forward gears working good.i check the trans oil and every thing is ok in the car.and there is no lights on.i dont know what to do.i have ford explorer 4WD .and it was drive ok.after that the reverse gear not working .but the forward gears working good.i check the trans oil and every thing is ok in the car.and there is no lights on.i dont know what to do.
You can't post conmments that contain an email address.
no car told at all, this ED30 is diesel engine by Nissan.
no question all asked,
my wild guess is you want to by car/truck parts for secret car?
Nissan Patrol? year told
parts are sold by maker,model, engine and year.
not by reverse look up, (google would be only hope reverse)
put car enigine in a boat and forgot the cars spec? IDK wild guess.
Im assuming you refer to the code P1847. This translates as "Transmission Transfer Case Contact Plate 'A' Open Circuit".
This is a fault on the electronics on the transfer box under the car. That's the gearing box that splits the drive between front wheels and rear wheels. It also controls your High and Low ratios for the gearbox.
These gearboxes were notorious for failing the reverse gear. The reverse gear wears out easily and keeps popping out. You can try shifting the gearbox into 3rd gear before going into reverse. This helps align the syncros in the tranny. Of course make sure you are not moving or if you are have the clutch depressed when shifting. You can also try http://www.international-auto.com/ for parts. They may be able to help you.
