Question about Digidesign BF Pultec Bundle (TDM + RTAS + AS) (DIGI99101314000)
Can't install! I have a mac pro running on leopard. When I try to install BF Pultec bundle, the message come up "the installer could not install some files in "/" Thank you Bob Heatlie
Everytime I try to print an invoice it closes quickbooks and asks to relaunch.
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
May 09, 2008 | Intuit QuickBooks Pro for Mac 2007: Mac
Trying to install HP photo smart c7180 on a mac and when clicking on the install icon a message window says power pc applications not supported
What version of system are you using on your mac, it is probably snow leopard (10.6) or lion (10.7). In snow leopard you can run powerpc applications but you need to install the part of the system that runs rosetta however in lion you can not run powerpc applications at all. This web page tells you how to instal rosetta on snow leopard http://www.macobserver.com/tmo/article/snow_leopard_installing_rosetta/ This webpage at hp will also give you some information http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02911238&cc=uk&dlc=en&lc=en&os=219&product=1153754&sw_lang= Hope this helps.
Oct 31, 2011 | HP Photosmart C7180 All-In-One InkJet...
Lost install disk for Mac book pro My 13" Mac book
You will need some install disks to even begin working on your issue.
Your options:
  • Find someone with the same model MacBook Pro and borrow the disks.
  • Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
  • Check eBay for install disks but make sure they are for the same model MacBook Pro.
  • Contact an Apple service center and purchase a replacement set of install disks.
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
Apr 23, 2011 | Apple Computers & Internet
My problem i install win xp on mabook pro model a1278 vga and sound and nework card not installed and i want driver for win xp
you need to insert the leopard or snow leopard dvd into your macbook while you are bootcamp to win xp.
run the bootcamp and it will install the drivers for sound, nic, wifi etc.
also download the latest bootcamp drivers from apple.com
Mar 28, 2011 | Apple Refurbished MacBook Pro 2.6GHz Intel...
Leopard OS
Is the hard drive SATA or IDE. On IDE, I know you can use delpart. Locate a SATA tool to wipe the partition of SATA drives. Install LEOPARD as usual then after rebooting.
Jul 25, 2009 | Apple Power Mac G5 Desktop
Will Accel-a-writer 4n work running Leopard 10.5.6?
Just download the PPD Installer from here: AW4N_OSX then install the driver. Use System Preferences -> Print and Fax to create new Xante Printer using Default or Apple Talk section of Control Panel.
Jan 02, 2009 | Xante Accel-a-Writer 4N Laser Printer
Macbook, lexmark f4270 driver
Apparently, the drivers for your printer is bundled in with the MAC OS CD. There are no MAC drivers on the Lexmark for your model. And the 4200 series should work.
Follow the instructions below.
Installing the bundled driver
Plug and Play
Steps Action 1 Power on the printer. 2 Plug the USB cable into the printer and into the Mac. 3 The Mac OS will automatically create the printer queue and install the printer.
Manual installation
If you plugged in the USB cable and the print queue was not created, follow these steps:
Steps Action Illustration 1 Plug the USB cable into the printer and into the Mac. ... 2 Launch System Preferences and select Print & Fax. Image 3 Click + to add the printer. Image 4 Select the printer, click Print Using and select your printer from the list. Then click Add to create the printer object. Image 5 Once the printer has been added, close System Preferences. The printer is now ready to print. Image
Troubleshooting
If you installed the driver from the printer·s installation CD or from a web download, uninstall it and follow the instructions below for recovering the driver from the Mac OS 10.5 (Leopard) CD.
Steps Action Illustration 1 Uninstall the installed driver. ... 2 Delete the Lexmark folder found in Library/Printers.
... 3
Insert the Mac OS 10.5 (Leopard) CD to recover the bundled driver and then click Optional Installs. Image 4 Click Optional Installs.mpkg. Image 5 Go through the installation process. ... 6 In the Optional Installs screen, select first Printer Drivers and then Lexmark Printer Drivers. Image 7 Click Continue and complete the installation process. ...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 05, 2008 | Computers & Internet
Installed hp laserjet 3380 on apple desktop pro - message printer stopped
See if it is the right driver. Intel Mac is not the same driver set as regular Mac.
Also, Apple + HP or Okidata often = issues.
Jan 12, 2008 | HP LaserJet 3380 All-In-One Printer
Computers & Internet Logo
18 people viewed this question
Top Digidesign Computers & Internet Experts
ali_zulfikar
ali_zulfikar
Zhenya Ogorodnikov
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
