Question about HP Office Equipment & Supplies
Hpphotosmartc4380 the printing is badly out of line .How do yoy align the cartridges?
  • 300 Answers
You may want to run the alignment program again. Below are the steps as found on page 84 of the manual found here.
To align the print cartridges from the HP Photosmart Software
1.
In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Services tab, and then click
Service this device.
The Printer Toolbox appears.
2. Click the Device Services tab.
3. Click Align the Print Cartridges.
The HP All-in-One prints a print cartridge alignment sheet.
4. When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
The HP All-in-One prints a test page, aligns the print head, and calibrates the printer.
5. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Posted on Oct 07, 2008
HP A636 will not print yellow; tricolor cartridge is new
  • Align the print cartridge.
The printer automatically aligns the print cartridge after a new one is installed. You can also align the print cartridge at other times to ensure optimal print quality. Indications that you need to align the print cartridge manually include borderless prints with white space
along an edge, colors not printing satisfactorily, or poor print quality.
To align the print cartridge from the printer
  1. Load a sheet of HP Advanced Photo Paper in the input tray.
  2. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  3. Touch Cartridge.
  4. Touch Align Cartridge and follow the prompts.
Clean the print cartridge automatically.
If the printed pages are missing lines or dots or contain ink streaks, the print cartridge might be low on ink or need to be cleaned.
CAUTION: Clean the print cartridge only when necessary.
Unnecessary cleaning wastes ink and shortens the life of the cartridge.
  • Clean the cartridge.
Follow these steps to clean the cartridge automatically:
To clean the print cartridge from the printer,
  1. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  2. Touch Cartridge.
  3. Touch Clean Cartridge and follow the prompts.
If the documents are still missing lines or dots after cleaning, replace the print cartridge.
Attaching User Manual (see page 59).
http://h10032.www1.hp.com/ctg/Manual/c01518966.pdf
Feb 18, 2014 | HP Photosmart A636 Compact Photo Printer
New black cartridge horz lines cleaned head &cartridge roller ; bought new cartridge still lines
Try to clean the print cartridge nozzles:
  1. On the printer control panel, press Menu.
  2. Press the down arrow button until you highlight Clean Cartridge. Press Select. A nozzle page prints, forcing ink through the nozzles to clean the clogged nozzles.
  3. Print the document again to verify that print quality has improved.
  4. If print quality has not improved, try cleaning the print cartridge nozzles up to two more times.
You can also try to align the cartridges:
  1. On the printer operator panel, press Menu.
  2. Press the down arrow button until you highlight Align Cartridge. Press Select.
Jul 28, 2011 | Lexmark P4350 All-In-One InkJet Printer
How do i align my printhead on canon iP1200
I assume you are using windows.
  1. Go to START, SETTINGS, PRINTERS, double click on the printer icon. Go to FILE, to PROPERTIES, then click on the printer SERVICES tab. Click on ALIGN the print cartridge button and follow instructions on the screen. hope this works
  2. Align the print cartridges Typically, you only align print cartridges after installing or replacing a cartridge. However, you may also need to align cartridges when:
    • Characters are improperly formed or are misaligned at the left margin.
    • Vertical, straight lines are wavy.
    From your printer:
    1. Load plain paper.
    2. Press the Menu button, and scroll to Align Cartridges.
    3. Press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
    From your computer:
    2. Open the Canon Pixma IP 1200 Utility.
    3. From the Cartridges tab, click Align Cartridges... . The Cartridge Alignment dialog appears. alignprintcartridgesa.jpg alignmentpanther.jpg
    4. Click Continue to print the alignment page.
    5. On the Alignment Status dialog, click OK if automatic alignment is successful. If automatic alignment is not successful, clicking OK will return you to Utility Main Window.
Apr 20, 2011 | Canon PIXMA iP1200 Photo Printer
Vertical lines are not smooth, they are jagged. The lines are straight for about an inch, then they are offset to the left. Some words are broken in half horiziontally with the lower half offset to the...
You can align the print cartridges at any time from the control panel or by using the HP Image Zone software on your computer. Aligning the print cartridges ensures high-quality output.
Note: If you remove and reinstall the same print cartridge, the HP all-in-one will not prompt you to align the print cartridges. The HP all-in-one remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges.
To align the cartridges from the control panel:
  1. Load letter or A4 unused plain white paper into the input tray.
  2. Press Setup.
  3. Press 6, then press 2.
  4. This displays the Tools menu and then selects Align Print Cartridge.
  5. The HP all-in-one prints a print cartridge alignment sheet and aligns the print cartridges.
Feb 16, 2011 | HP OfficeJet 7410 All-In-One InkJet...
How do I align the cartridge after I replace it. The fax printed out a sheet and the lines are not straight. I went to tools...to align cartridge and then I am not sure how to adjust the lines
Follow below steps to complete alignment.
  • With the Cartridge compartment cover open, insert the print cartridge into the print cartridge cradle with the contacts facing into the unit. When the cartridge is seated in the print cartridge cradle, push the top of the cartridge towards the back of the unit until the print cartridge clicks into place.
  • Close the cartridge compartment cover and control panel.
  • Press the Start/Enter button.
  • On the keypad, press 1 if the replacement print cartridge is new or 2 if the replacement print cartridge is old
NOTE: When you put in a new cartridge, you must choose 1: New .When you put in a used cartridge, choose 2: Used . This helps you to check the correct amount of ink you have left.
  • An alignment page will print and 06 [01-11] will show on the display
  • Look at the alignment page and select the number under the straightest line, and then press that number on the keypad and then press Start/Enter .
Oct 17, 2010 | HP 1040 Plain Paper Inkjet Fax
How do I align ink jets?
Microsoft Windows 95/98/Me:
(Applies to all printers)
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Nov 13, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Dell 922 printer alignment problem-
try this...
Aligning Ink Cartridges Your printer automatically aligns the ink cartridges when they are installed or replaced. To verify your ink cartridges are aligned, you can print an alignment page. After you close the printer unit, press the Menu button. The alignment page begins printing. During printing, the operator panel display reads Alignment Page Printing. When complete, the message reads Auto Alignment Complete. Your ink cartridges are now aligned for optimal print quality.
You may also need to align ink cartridges when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
To align the ink cartridges:
  1. Load plain paper. For more information, see Loading Paper.
  2. Click Start® Programs or All Programs® Dell Printers® Dell Photo AIO Printer 922® Dell Printer Solution Center.
  3. Click the Maintenance tab
  4. Click Align to fix blurry edges.
  5. Click Print.
The ink cartridges align when the page prints.
If this helps you plz rate this fixya. Thank you kindly. If you need more help post it & I'll be glad to do what I can.
Feb 01, 2009 | Epson Printer
How to change lexmark Cartridge
      3. Click OK.
Dec 09, 2008 | Lexmark X1150 All-In-One InkJet Printer
Alignment problems
Here's the deal with the cartridge alignment page....the machine will spit out a series of black lines mixed with yellow ink and at the beginning of each of these lines is a "Green" check mark. The carriage moves back and forth over these lines and green check marks and reads them by use of what is called a "spot sensor" that resides on the right side of the carriage assembly. This is usually noticed by the blue ray of light that shines out of it. So if you are getting an alignment failure one of two things is happening....1)You've have got a bad cartridge (usually the color) and it is not laying down the right colors, specifically the green check mark or 2)You've got a bad spot sensor...even though it may still be shining the blue light, the sensor board can't process the information. Its an easy fix either way.
Inkworks
Apr 25, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP PSC all-in-one printer skipping lines
  1. Press the Setup button.
  2. Use the arrow keys to select Tools and then press the OK button.
  3. Select Clean Print Cartridge and then press OK . The device prints a test page.
  4. Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.
  5. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
  6. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
If the steps have not solved the problem, clean the electrical contacts on the print cartridge and in the carriage.
  1. Gather the following items to clean the cartridge and print carriage:
    • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
    • Sheets of paper or a paper towel to rest the cartridges on during cleaning.
  2. Open the product cover and wait until the print carriage stops moving.
  3. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up. NOTE: Clean the contacts quickly so that the cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
  4. Unplug the product.
  5. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp.
  6. Clean the print-cartridge contacts. Do not touch the nozzles. Figure 1: Cartridge electrical contacts c00832021.gif
  7. Clean the contacts in the print carriage, inside the product. Figure 2: Carriage contacts c00246272.gif
  8. Either let the cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
  9. Reinstall the cartridge, plug the product back in, and close the product cover.
  10. Try to print again. If the issue still appears, continue to the next step.
In the black print cartridge, this problem might be caused by sediments collecting in the nozzle area. Perform the following steps to solve this problem:
  1. Remove the black print cartridge.
  2. If the carriage has a latch, re-latch it and then close the printer. NOTE: If the printer is not closed, it cannot adequately protect the remaining tri-color cartridge.
  3. Place the cartridge on a level surface with the nozzles up (label down). Figure 4: Cartridge with the nozzles up c00260331.gif
  4. Allow the cartridge to sit undisturbed for two hours.
  5. Reinstall the cartridge and print another diagnostic page.
    2. Press and hold the Cancel button and then press the Start Copy Color button.
    3. Make sure that the test patterns show a complete grid and the thick color lines are complete.
    • More than a few broken lines in a pattern can indicate a problem with the nozzles. You might need to clean the print cartridges.
    • If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black print cartridge in the right slot.
    • If any of the color lines are missing, or if the pattern appears faded, streaked, or shows lines, this might indicate a problem with the tri-color print cartridge in the left slot.
  6. Look for defects on the page. If the diagnostic page shows no defects for the black cartridge, and if the cartridge was new, align the cartridge. To align the cartridge, follow the steps:
    1. Load letter, A4, or legal unused plain white paper into the input tray.
    2. In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Toolbox . NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device . The Printer Toolbox appears.
    3. Click the Device Services tab.
    4. Click Align the Print Cartridges and a print cartridge alignment sheet is printed.
    5. Load the print cartridge alignment sheet with the print side down on the right front corner of the glass.
    6. Press the Start Scan/Reprints button and the HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet. For aligning the cartridges from the hardware only, follow the steps:
    7. Load letter or A4 unused plain white paper into the input tray.
    8. Press and hold the Cancel button and then the On/Power button.
    9. While the Check Paper and Check Print Cartridge lights are blinking, press the following buttons one at a time in the following order: Cancel , Number of Copies , Paper Type , Color Start
Nov 27, 2007 | HP PSC 2355 All-In-One InkJet Printer
220 people viewed this question
Seeker5211
Seeker5211
