Question about Dell Computers & Internet
Not able to run any DVD on my Laptop Latitude D610 whereas i can able to run CD Please solve this issue at the earliest.
  • The Tech May 11, 2010
    Does the Drive support DVD's?
  • 63 Answers
You may have to check if the drive that is installed on the system is capable of running DVDs. if it just CD/CDRW then this will not work for a DVD CD. You need to have a CD/DVD drive.
Posted on Oct 07, 2008
Am having dell latitude d610 , my laptop reads dvd but not cds
I think what you have there is a DVD ROM its only reads DVD'ds not CD's, you need to purchase a combo whick can read both cd's and DVD's
Aug 10, 2011 | Dell Latitude D610 Laptop Computer -...
My laptop dell d610 dont have a cd/dvd+RW it cannot burn cd or dvd, i want to download cd/dvd+Rw to enable to burn
It sounds like the problem is your hardware, the current optical drive you have installed cannot burn disks, not matter what software you download you will not be able to do this without the correct hardware. You will need to buy a new drive that is Read/Write capable from a local computer store.
Mar 01, 2011 | C & D DVD RW Burner Drive For Dell...
When I start up my Dell Latitude D610, it will go throught the boot sequence, and imediatly after the microsoft windows XP loading screen is shown, a blue screen apears that goes by too quick to read. Then...
Pressand hold the key while powering the system on. This will run theDell Diagnostics. Another more intense diagnostic program is located on a DellCD that you should have received with your laptop. Look for one that has "Diagnostics and utilities" listed underthe "Contents". You will have to boot from that CD disk. To do this, power onyour laptop and tap the key to bring you to the "One time bootmenu". Insert the CD and then select CD/DVD drive and hit key. Select the "Run the 32 Bit DellDiagnostics". If the laptop runs the diagnostics without errors then you have a software issue. If it is a hardware issue (i.e. memory,hard drive) diagnostics will indicate faulty component.
Feb 21, 2011 | Dell Latitude D610 Notebook
My laptop has failed to start up. It gives me an error code 1000-0416. It's a Dell latitude D610. What steps should i take to fix this? Thank you.
hello, Plug your laptop to an external monitor and restart,maybe it is a VGA problem,if it does not start change the RAM,if it does not start again,then there is a problem with the motherboard
Nov 18, 2010 | Dell Latitude D610 Intel Pentium M 1.6GHz...
Dell Latitude D610 will not read cds
Clean your DVD's lens and check your data cable and then run the cd and check it. It will work.
Nov 30, 2009 | Dell Latitude D610 Laptop Computer -...
Dell Latitude D610 dvd player won't work
Try a CD ROM lens cleaner. If it fails then I suggest you buy a new one. It is easy to change it: there is a release switch at the bottom with a screw. Open it and remove the old one. Slide the new one into its place.
Aug 05, 2009 | Dell Latitude D610 Laptop Computer -...
My dell d610 laptop cd/dvd drive not working
the drive has one lens, that works for both cd's and dvd's. when it reads a dvd it uses a higher light frequency, however when reading a cd it will use a lower light frequency. the lens is most likely dirty, which is why the high frequency light aka dvd is working but not the low frequency light aka cd. a specialized lens cleaning cd may be needed. or if you want to do it manually open the drive exposing the lens, then get a q-tip and some rubbing alchohol. dip the q-tip in the rubbing alchohol and rub the lens gently in a circlular motion. then turn the q-tip over to the dry side and do the same to dry it. thank you for using fixya!
May 03, 2009 | Dell Latitude D610 Laptop Computer -...
Power for battery on DELL laptop Latitude D610 as posted FixYa
In the BIOS, does it show the battery and it's current state? As weird as it sounds, I've fixed an issue like this on a D600 by updating the BIOS to the most current level. Weird, but true.
Dec 22, 2008 | Dell Latitude D610 Laptop Computer -...
Computers & Internet Logo
121 people viewed this question
Alun Cox
