Question about Dryers
Hoover Nextra 8 dryer making a squealing noise
My nextra 8 hoover tumble dryer makes a squealing noise when on. It seems to be working ok. Can't find the guarnatee so don't want to call hoover out.
Any help appreciated
  • smandy1979 Apr 21, 2009
    my hoover dryer makes a lound noise when on, sounds like its to do with the fan belt but cant find how to get to it
  • 958 Answers
You have to open the dryer and lubricate the rollers, these are the parts that normally make the squealing sounds.
tnx 4 using fixya,
Posted on Oct 07, 2008
I have a Hoover nextra 6 kg condenser tumble dryer which is leaking water and the collector is empty and seems not to locate fully into the hole at the back?
Check for Lint/Dirt in the Drain and then you need to ensure it is fully connected in the Washer to the Drain...
Jan 03, 2015 | Hoover Dryers
Hoover Nextra 7148 not drying
id check for fluff inside the machine casing.............blocking the air flow...........
Aug 30, 2017 | Hoover Washing Machines
Hoover Nextra 6 1400 6+4kg - the tumble dryer
under top cover there are 2 thermal cut outs to reset.situated centre front
Sep 12, 2009 | Hoover Nextra HNWL 3136 Front Load Washer...
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Noisy when running need to check belt and bearings
i need the serial # to assist you better
thank you
May 14, 2009 | Dryers
There is no heat
Disconnect power and access your dryer fuses. Check and test your fuses for "continuity". Most likely, a white thermal fuse. Can possibly be your ignitor or heat element as well. Is your dryer gas or electric?
Jan 27, 2009 | Hoover Dryers
My noisy hoover tumble please!
possibly bearings gone on drum shaft
Mar 20, 2008 | Dryers
Hoover hdv fm tumble dryer
only thing may make a buzzing sound is a relay not making up or a motor contactor not closing all the way.
Sep 11, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Dryers Logo
1,484 people viewed this question
Top Dryers Experts
