Question about Samsung BIXOLON® SRP-770II Thermal Label Printer
Muliple labels when asked to print eg 8 of the same label, it only prints 1
  • 3 Answers
Why do not you download new driver from their website? www.samsungminiprinters.com
Posted on Jan 02, 2009
Label is printed fine but each printed label print blank line before label print
To isolate problem run a test label from printer.Does the same thing happen? If so it is a printer problem.If not the problem is in the document itself.
Apr 24, 2014 | Zebra LP 2844 Thermal Printer
Zebra 105sl - printer does not print correct size
This sounds like a mismatch between the printer settings in the print driver and the label settings in your label design software.
In the printer driver - printer preferences- set the physical label dimentions.
Also set the printing defaults to the same settings.
In you design program ensure your label size is the same as the printer driver and also you can set the print preferences in the same program, ensure they all match and hey presto it works. But if nt then contact www,lancerlabels.co.uk, they will talk you through the problem on the phone. They will not charge for the advice.
Mar 17, 2013 | Zebra 105SL Thermal Label Printer
Smart LabelPrinter Seiko 440
The code between the labels indicates either you are using labels designed for another model or that it is thinking it has a shippinhg label opr some lareger type installed. IT is more likely to be the first option, you are usinjg the wrong coded labels
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | Seiko Smart Label Printer Pro Thermal
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
Issue trying to print mulitple labels, red light
The physical label size must be set in the printer driver, both in the "Properties" and the "Default" tabs.
Jan 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
MY TLP2844 SKIPPING LABELS HOW CAN I FIX IT
try feeding just one label the 2 or 3.
if the printer feeds fine, check the format.
there is an unprintable area top and bottom of the label to reflect tolerances on the printer.
I usually like to keep the format 1/8" top and bottom spacing.
If you software, check that you do not have the printing too close to the edge.
Dec 12, 2008 | Zebra 110Xi III Plus Thermal Printer
Printing envelopes and labels
I foubd the Brother website to be very helpful with my label and envelope printing:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000000/000063/faq000063_007.html?reg=us&c=us&lang=en&prod=hl5240_all&Cat=4
Apr 01, 2008 | Brother HL-5240 Laser Printer
This can happen if you have the wrong dpi setup. For instance the 105sl can be either 203dpi or 300dpi. If your printhead is 300dpi and the label you create is expecting 203dpi, then you will see shrunken label. Your situation doesn't exactly sound like this is the case but it may be worth checking.
Mar 21, 2008 | Zebra 105SL Thermal Label Printer
Samsung BIXOLON® SRP-770II Thermal Label Printer Logo
76 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
