Question about D-Link Computers & Internet
NAT Router - Problem
My Requirement :-
i want to access the database of a software on a client machine from my web based application which resides on a linux server. For this do i need to have a static IP on my client machine? Also can i access a client machine which is in a LAN network under no user verification internet service.
    Problem Solver:
  • 18 Answers
No static on the client side, but it's a good thing to run the server static.
You could setup a VPN into the LAN where the client machine is connected.
Stacey
PC REPAIR
www.wvpcrepair.com
Posted on Oct 13, 2008
Assess my emails when my labtop has been wiped clean
You can still access emails but you will have to sign in! Only links and saved passwords will be lost by wiping Laptop!
Dec 27, 2014 | Computers & Internet
Unable Connect To Database
Need more detail in order to help you. Let's start with:
Is this a home or office PC (or Mac, or Linux machine)?
Is the database stored on your machine, or are you connecting to a database server?
What type of database (Oracle, MS Access, Sybase, etc.)?
What type of client / business software are you trying to use to connect to this database?
With that, I may be of some assistance.
Oct 18, 2013 | Computers & Internet
My router can not access dhcp.Why?
A DHCP Reservation is a permanent IP address assignment. It is a specific IP address within a DHCP scope that is permanently reserved for leased use to a specific DHCP client.
You can configure a DHCP reservation in your DHCP server when you need to reserve a permanent IP address assignment. You can use these reservations for DHCP-enabled devices like print and file servers or other application servers which always have the fixed IP address on a network.
To configure a DHCP reservation, follow the steps provided below:
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: To learn how to access the web-based setup page on a Mac computer, click here.
Step 2:
Click Setup > Basic Setup.
Step 3:
Make sure that the DHCP Server option is Enabled. Click the DHCP Reservation button if you want to assign a fixed local IP address to a MAC address.
Step 4:
When you click on DHCP Reservation, a new web browser window will pop-up. Click the Select checkbox to reserve a client's IP address. Click the Add Clients button afterwards.
kb17362-003_en.png Step 5:
If you want to manually assign an IP address, enter the client's host name in the Enter Client Name field. You can do this as well in the IP Address and MAC address fields.
Step 6:
Click the Add button.
Step 7:
A list of DHCP clients and their fixed local IP addresses will be displayed at the bottom of the screen. If you want to remove a client from this list, click the Remove button.
On this window, you can do any of the following:
• Click the kb17362-006_en.png button to save your changes.
• Click the kb17362-007_en.png button to cancel your changes.
• To view the most up-to-date information, click the kb17362-008_en.png button.
• To exit this screen, click the kb17362-009_en.png button
If you need more help come back.Post / thumbs / testimonial are welcome!.
Nov 20, 2010 | Linksys WRT160N Wireless Router
My nat settings are strict and I don't know how to change them to open?
Using your Internet browser, you can access the Router’s Web-Based Advanced User Interface. In your browser, type “192.168.2.1” (do not type in anything else such as “http://” or “www”). Then press the “Enter” key.
You will get a set up page where you can disable NAT
Follow me on Twitter
May 20, 2010 | Belkin (F5D8231-4) Wireless Router...
No incoming and outgoing call
You may be behind a firewall or NAT. You can set an option that you are; if that still does not work, you may need to open some ports on the firewall.
Yahoo! Messenger uses a variety of ports.
Service Ports Chat & Messenger TCP Port 5050: Client Access only Insider/Room Lists TCP Port 80: Client Access only File Transfer TCP Port 80: Server Access.
Your ISP may block this port, as its used for web hosting.
You can change port in Messenger, Preferences, File Transfer. Voice Chat UDP 5000-5010
TCP 5000-5001: Client Access
If UDP Fails, TCP will be used instead, see below. WebCam TCP Port 5100: Client Access Super Webcam TCP Port 5100: Server Access P2P Instant Messages TCP Port 5101: Server Access
PMs between Buddys may not use the Yahoo! Server, but this is not a requirement.
Feb 03, 2009 | Yahoo Messenger
Nat type
I have the same router (WRT300N) and this is what I did. I don't know if it will work for more than one Xbox360.
- Go to the Setting of the router.
- Applications & Gaming
- DMZ
. Enable the DMZ
. Choice the Mac Adress under the Destination.
. If you don't know the Mac Adress of your Xbox360 click on the tab: DHCP CLIENT TABLE
.Now from there choice your Xbox360 ( the Xbox360 won't have a Client Name but hopefully you only have your Xbox360 and your computer)
and now save your setting and restart your Xbox360 and there you go NAT open. This also help if you get any kind of  LAG while someone is on the computer using the internet, your Xbox360 will be high priorty to the router.
HOPE THAT HELP
Apr 05, 2008 | Linksys WRT300N Wireless Router
Windows xp pro oracle 8i database access very slow
check your computer comfiguration check the ram for memory
Nov 28, 2007 | Microsoft Windows XP Professional for PC
What is the main difference between WinGate and the Prestige 310 ?
# WinGate is a software only solution that needs to be installed in a dedicated Windows 95 PC based server. The total cost and complexity are many times over ATI?s product. The Prestige 310 Internet Access Sharing Router is a plug-n-play internet appliance. # WinGate requires all TCP/IP applications such as Netscape Navigator to be reconfigured to have the dedicated server as a proxy. The Prestige 310 Internet Access Sharing Router does not require users to reconfigure any software at all. # The Prestige 310 Internet Access Sharing Router uses Network Address Translation (NAT) scheme, which supports all TCP/UDP ports. WinGate only supports limited number of ports, such as http(80), ftp(21), telnet(23), and pop3(110). # WinGate works as a proxy, while the Prestige 310 Internet Access Sharing Router works as a gateway. The gateway approach is more efficient than the proxy during the processing of TCP/IP commands. As a result, the Prestige 310 Internet Access Sharing Router achieves 10% to 20% higher performance than that of software solutions such as WinGate. # The Prestige 310 Internet Access Sharing Router uses Solid State Disk technology. There are no moving parts in the product. It is much more reliable than any hard disk based system, such as the one for WinGate.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
Why won´t my FTP Client work with my D-Link router?
Make sure your FTP client software is set to passive. For security reasons the D-Link router does not deal with an active FTP client. An active FTP client can allow a hacker masquerading as an FTP server to gain access to your computer. Please contact your FTP client software manufacturer to determine how to configure the client for passive rather than active. Note: You will not be able to use an active connection through most NAT routers.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Nortel Contivity VPN client?
Nortel Contivity will work with the your D-Link router, however its functionality depends on the authentication type (AH will not work), NAT compatibilty mode, and disabling keep alives on the server. Contact your Network Administrator to find out how your VPN is configured. Step 1 Verify that you are using the latest version of firmware on your router. Step 2 Login to the Web Management for your router by entering its IP address (192.168.0.1) in your web browser. The default username is admin, and the password is blank. Step 3 Click the Advanced Tab to access the Virtual Server Settings. There is a list of pre-defined Virtual Server Rules towards the bottom of the page. Find the IPSec Rule. Click the pen and paper icon to edit its settings. Enable the rule, enter the IP address of the computer attempting to connect to the VPN in the Private IP field, then Apply the changes. Step 4 Create a new Virtual Server entry. Name the Virtual Server, "NortelVPN". Enter the IP address of the computer attempting to connect to the VPN in the Private IP field. For the Protocol Type, select Both. Enter 9550 for both the Public and Private Ports. Set the Schedule to always, then Apply the settings. Step 5 Access the Tools Page, then click the Misc button. Disable IPSec Pass-through, then click Apply. If the VPN Server is properly configured to work with clients behind NAT routers you should be able to connect to the VPN.
Computers & Internet Logo
132 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
