Question about Canon PIXMA MP460 All-In-One InkJet Printer
Error code 5100 - can't clear it
Hi , I've got error code 5100 on my mp460 and can't clear ir - counds like paper might be jammed but don't know how to open printer to clear jam - ave'nt got anyy mauals for this - can u help pls?
  • Anonymous Oct 22, 2008
    error code 5100. tried maintenance and won't work. can't print.
Lift up below the display screen.The printer top will raise up and a arm will lock into place.Make sure the ink cartriages are firmly in place,snaped into position,sitting flat.Lift arm out of the way and close the lid.Worked for me ,good luck.
Posted on Oct 08, 2008
Terdapat code error 5100
turn off printer, then turn on again, then press paper jam button it may fix the problem
Jan 18, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Hi, I had a paper jam and all I'm getting on screen is ( error code 5100 ). I have missplaced my manual, the machine is a pixma460 all in one. Hope you can help, thanks,
Error code 5100 means that the movement of the fine cartidge holder is blocked. To resolve this, clear the paper jam or any foreign object that is preventing the fine cartridge holder from moving, cancel printing from your computer and then turn OFF the machine and turn it back ON again
Apr 08, 2010 | Office Equipment & Supplies
Alarm is flashing error code 5100 and won't let me print anything
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 04, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Have an MP460 and cleared a paper jam only to have the error code 5100 pop up and stop everything from printing
You will should be able to find information on that error for your printer by entering "error 5100" without quotes in the search box here. Then press Search. Then choose result 1 and follow the steps. Each step will have more detail available by click that steps link.
Hope this helps. Please remember to rate this information.
Thanks
Jun 04, 2009 | Canon Pixma MP450 All-In-One InkJet...
I have got error code 5100
5100 error code means there is somekind of obstruction inside the printer thats interfering with the printing process. You have to check the inside the printer especially near the gears and under the rollers. The obstruction can be anything like a small piece of paper, a paper clip, ball pin etc., check thoroughly and you will find it. Post back if you need more help.
Dec 03, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon pixma mp460 code error 6000
Solutions for error 6000 Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3. The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
May 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Mp460 printer
I can only see a 5100 code is that what you mean?
If it is here's the answer: Movement of the FINE Cartridge Holder is blocked.
Clear the paper jam or foreign object that is preventing the FINE Cartridge Holder from moving, cancel printing from your computer, then turn OFF the machine and turn it back ON again.
Feb 26, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
246 people viewed this question
old marine
old marine
