Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
Only showing as a network device on 2 of the 3 pcs on the network
Gday.
Just bought a WD My Book World Edition HDD. Set it up on a network between 3 PC and it appears on 2 of the 3. Only one it doesnt appear on is the main one I want it on... typical.
Other 2 PCs that show the My Book on the network are running through the same ethernet switch as the one that isnt so thats not an issue. I even connected the My Book directly to the PC that wont detect it and still nothing. All of the PCs are running Vista. 2 of the 3 are running 64 bit version. One of the PCs running 64 bit vista is fine, the other doesnt detect it. This is probably a local issue for that particular PC but I dont know where to start. The network connection is fine as thats the same connection I use for the internet (which is currently running through the same ethernet hub).
All 3 PCs show on the network when checked on each PC. Seems the PCs are networking ok, just cant get this drive to show on 1 of them.
If someone can tell me where to start that would be appreciated.
Thanks
  • 3 Answers
Did u added the new network devices, or did u wait till thy popped up?
If u didn't added them manually, then go to networklocations, add network location, press next, and again next, then type in \\mybookworld\"here the name of the folder of your mybook, ex. Movies or music,.." (without " ")
Do it for every folder.
Posted on Oct 25, 2008
Western Digital World Book 1TB - Lights don't light, HDD vibrates
I would try to connect the drive directly into an ide or a sata cable on the motherboard. Maybe using the western digital tools from their website you'll be able to access the data and copy it. I hope this helps you.
Aug 23, 2009 | Western Digital My Book World Edition 1TB...
My network wont detect wd my book world edition 500 GB HD
if u have a Cd rom which have a driver then u shoud download it on all computers in ur network to make it work better and faster but if there is no CD driver then u shoud read its manual
Jul 25, 2009 | Western Digital 500GB My Book World...
Cant connect my 1TB WD world edition to my linksys router
Your My Book World should not be formatted or you will lose all ability to access it through the Network -- it will simply become a hard-drive at that point. There is software installed on the hard-drives that communicate with your Router in order to obtain an IP and be available as a Network Drive. If the drive and the Router are communicating, you should see an IP in the DHCP list of your Router. It is possible that the My Book World is not setup for DHCP, so if it is placed in an alternate environment with incompatible static IPs, it won't be able to access the Internet or be available locally. You can try a hardware reset on the drive and see if it pops up in your Router's DHCP/Client list, at which point it should also appear locally and over MioNet (MioNet will need to register the device to an account before it will appear in MioNet, but it must detect the drive locally in order to attach).
1. Turn off My Book World
2. Identify the reset button on the back of My Book World
3. Depress the reset button while restarting My Book World
4. Keep the reset button depressed for about 10 seconds after you see blue lights on My Book World
Jul 02, 2009 | Western Digital 500GB My Book World...
Wd my book device usb device not recognized by computer
Hi, Take the drive to a pc store and ask the techs to move the HDD into a new shell and test it for you. Most likely it's ok and you can just buy a new shell/enclosure for it. If that doesn't work it may need the help of a recovery pro. If that's the case comment back here with your country/state/city and I'll pass on a recommendation for a nearby facility that can assist you in retrieving the files. Chris
Jun 09, 2009 | Western Digital 500GB My Book World...
Defrag a wd world book
The file system used by the WD My Book World unit is Linux based and does not fragment in the same ways that Windows users are used to dealing with. You will not need to worry about fragmentation.
If you are interested in a more geeky, but still somewhat simple explanation at http://geekblog.oneandoneis2.org/index.php/2006/08/17/why_doesn_t_linux_need_defragmenting
Happy computing! :D
-= M =-
Apr 01, 2009 | Western Digital My Book World Edition II 2...
WD 2 TB external HDD asking for password
log in from administrator see if your anti virus's or your windows fire wall is not interrupting if not solved go to run in the start menu type command "chkdsk" "netuser administrator (the password you want to give)"
Jan 20, 2009 | Western Digital My Book Essential Edition...
I have a world book 1tb hd with mionet. connec to network
hard drive is hanging up continually have to p[lug in and unplug in order for me to transfer everything off of it!
Dec 11, 2008 | Western Digital 500GB My Book World...
Mionet application doesn't show files in subfolders of shared folders
I believe you have a choice of using either the web interface or the desktop version of Mionet when you are on the same network (LAN), and as you mentioned both of you have no problem when you are on the same network as the NAS drive (MBWE) is.
When you are out of the local network where your NAS drive is, the only choice you would have is the web interface of Mionet. Eventhough you may have installed the desktop version of Mionet tool on a remote PC, I don't think you can access through that desktop tool. Sorry !!!
Oct 30, 2008 | Western Digital My Book World Edition 1TB...
Next day WD World Book can not be accessed from IE
Look there for a start
http://mybookworld.wikidot.com/start
J.
Oct 01, 2008 | Western Digital 500GB My Book World...
How do you set up multiple WD Anywhere users on the network to share the same MyBook World Edition
hey,
-No WD Anywhere allows 5 users I think.
This could only be the solution, if you installed WD Anywhere on other PCs before
Check out the MioNet site, think they give options for new users.
if this is not the problem, I don't have a solution by now.
bye
Feb 08, 2008 | Western Digital 500GB My Book World...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
118 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
