I have a front loader washing machine that wont let me open the door even though the wash cycle ended hours ago
  • 3 more comments
  • madsen01 Oct 07, 2008
    ive tried this ring thing and it wont let me pull it turn it..and I cant check the manual coz bosch wont send me one!
    Hello again, ok the ring thing came out and let alittle bit of water out but door still wont open!
    yea the ring thing unscrews and water came out of there not at the door
    no there is no water..it is empty on the inside where the clothes are
    thanks for the advice..il see how that goes!
  • 958 Answers
Could be a door lock problem. try hitting the door lock a couple of times, the latch could release the hook.
another solution if you have your manual, it is stated there how to open manually your door.
there is a plastic hook at the back of the switch with a ring at the end, you can pull the ring down and the door will open.
in order to get to the plastic, you need to remove the front lower panel. remove 3 screws that are holding it.
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
  • 3 more comments
  • francis rivero Oct 07, 2008
    there could still be power that is holdint the lock of the door. try to un plug the unit and then pull the ring after about ten minutes.
    tnx again,
    drcool
    the ring should not come off . just pull it and you can hear a click from the door lock and if water came out of the door, then the door is no longer locked. maybe it is just stuck. open it slowly and i think you can open it up.
    tnx again,
    drcool
    ok..so the door lock is now broken. do you still have water inside the unit? if you do, drain it first by opening slowly the filter of the water pump. water would flow out and do not let the splash go to the center of the unit. there is a water sensor at the center that would create more trouble.
    then you have to remove the door lock from the inside which is troublesome and then replace the door lock.
    tnx again,
    drcool
    then you will just have to slowly remove the door switch from the inside since it is holding your door. but the screws are accessible only from the outside on an open door so that creates a problem.
    anyway, if you can still touche and feel the door switch, at the top most portion, feel something that could slide downwards or upwards. you might be able to still manually un lock the door. beside the ring, there are still plastic parts that slides, or worst scenario. break the door lock slowly, piece by piece until you can un lock the door.
    tnx again,
    drcool
    your very much welcome,
    drcool
Samsung wf8750lsw front loader door wont open
Not sure if you mean when it is fully off or operating, but if you mean that once it is operating the door won't open, then the following applies...
Once a front loader wash cycle starts, the door on a front loader is physically (electronically) locked until the full cycle ends after spin dry. This is to prevent anyone opening the door and letting all the water out in the middle of the wash cycle, which a lot of people try to do to put in more clothing etc.
Apr 11, 2014 | Zanussi F1045W Front Load Washer
Whatever the cycle you choose, the door open light turns on, even though the door locks when you start the cycle
I take it that it is a front loader, what make and model machine do you have?
regards
Graeme
Apr 20, 2008 | Washing Machines
Door wont open on washing machine zwf16581w at the end of the cycle
The door is designed to stay shut at the end of a cycle usually for about 4 minutes, even if you switch the machine off at the mains. Other than that you probably need a repair.
Dec 17, 2011 | Zanussi Washing Machines
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
The door on my Smeg Allegra front-loader washing does not open
SOME MACHINES HAVE A DELAYED OPENING TIME SO THE DOOR DOSE NOT OPEN WHEN BUTTON PRESSED LOOK IN MANUNAL TO SEE IF THIS FEATURE IS ON MACHINE IF NOT PROBLEM THEN NEW DOOR LOCK WOULD BE IN ORDER
Dec 30, 2009 | Washing Machines
Maytag top loader washing machine
i believe i can help you,,but washers dont agitate in the spin cycle,,i believe you ment it wont wring or spin in the spin cycle..your lid switch is defective,,replace,,if need be i can talk you though,,onthejob
Dec 28, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine
bottom right corner behind the little door
Sep 27, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
186 people viewed this question
Top Washing Machines Experts
