Question about Cameras
Kodak Easyshare - photos not always saving to SD card - sometimes saving on camera.
After taking a photo, it doesn't always save onto the SD card (it appears to save some pictures onto the camera). I can't work out how to get them off the camera and onto the card so I can download them.
5 Suggested Answers
jackboy
  • 2985 Answers
SOURCE: Nikon Coolpix L15 - save picture to photo card
I assume you mean transfer from internal memory to card?
This is on the menu system - simple scroll through the menus to find transfer.
Also the MANUAL[Handbook] will tell you.
no book - look on the software disk it is there as a PDF file that can be read/printed.
Posted on Feb 12, 2008
SOURCE: Savings photos to cd
As advised, I opened the 'Save to cd' part of Windows XP (Home) and followed the instructions. Easy when you know how! Many thanks, Tim
Posted on Jul 01, 2008
jackboy
  • 2985 Answers
SOURCE: Kodak EasyShare DX7630 Camera
Check the ASA setting - read up the manual
Posted on Jul 19, 2008
SOURCE: Lost pictures
I have taken several photos by using SONY Cyber-shot Camera(DSC-W150/W170) then my son undelibrately pressed somewhere. After a while the all photos which was taken by me disappeared from camera. Could you advise there any solution to retreive all the photos? Your advise on this issue is highly appreciated. majeedpth@gmail.com
Posted on Mar 05, 2009
  • 11967 Answers
SOURCE: Kodak Easyshare z1012: 676 photos downloaded to
First of all, it's not a good idea to leave that many pictures on a card for any length of time...they may get corrupted. Download to your computer more often. As for your present problem, take the card to a store that has a Kodak picture maker machine (like Walmart). Usually, all the pictures will show up ok and you can print them or even make a cd of them.
Posted on Oct 15, 2009
I have kodak easyshare z915 and i am trying to move internal memory photo to sd card. I went to menu but no option to save to sd card
Go into the playback mode then press the MENU button. You'll find the "Copy" command there.
Here's the page from the extended user guidel
Oct 04, 2011 | Kodak EasyShare Z915 Digital Camera
I have a kodak easy share camera M340 and I can't take any photos since it says Internal memory is full. Help
Buy yourself an SD memory card and transfer your pics to the card. That will clear your internal memory. You can save all your pics that you take from now on in the SD card.
Sep 10, 2011 | Kodak EasyShare Z612 Digital Camera
My digital camera , kodak easyshare M320 saying internal memory full and I have lost some pictures. 1 how do I get the camera to work again 2. how do i retrieve the lost pictures
Don`t you have a SD/SDHC memory card in the camera .In review picture mode select copy & send photos from internal memory to SD card and then delete internal memory for fresh space
Aug 12, 2010 | Kodak Cameras
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    My Kodak Easyshare caemra will only hold 3 photos.
    1: Menu, Cam settings, Chose AUTO or SD card option Press OK
    If successful please give me the feedback as a rating or recommendation. Thank you
    Jan 10, 2010 | Kodak Easyshare 1725043 M893Is Digital...
    I put a new memory card in our Kodak EasyShare
    Your camera is only supporting SD/MMC Cards (up to 1 GB)
    The card that you currently have might be faulty. Please try another card.
    You might also need to switch the camera over to saving pictures directly onto the SD card.
    1: Menu 2: Cam settings 3: Chose AUTO or SD card option Press OK
    Dec 25, 2009 | Kodak EasyShare C330 Digital Camera
    How do we move the photos to the memory card in the camera?
    Get out your manual and read the chapter about file transfers. It should be fairly simple to move the files from internal memory to external memory.
    Aug 06, 2009 | Kodak EasyShare Z1275 Digital Camera
    Kodak C813
    If the photos are saved on the sd card in the camera you should be able to copy them onto your pc by taking out the card and inserting it into the pc. If you have no card slopt use a card reader with a usb end. The photos will then open up with any program capable of opening photos such as paint,photoshop or whatever. The easyshare software is only necessary if you are getting the photos to your pc via the cable which came with the camera. Personally I just pop the sd card into the pc and use mgi.photosuite or paint to open it. If you copy the photos onto the pc just double click on one of the photos and it will most likely open with the default program.
    Jun 30, 2009 | Kodak Easyshare C813 Digital Camera
    Missing pictures on sd card
    I had success with this
    1. Do not save any new file to memory card.
    2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
    3. Download SD card photo recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
    http://www.asoftech.com/apr/
    4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
    Mar 29, 2009 | Kodak EasyShare C613 Digital Camera
    Cameras Logo
    44 people viewed this question
    Top Cameras Experts
    Steve
    Are you a Camera Expert? Answer questions, earn points and help others
