Marantz SR7400 AV Surround Receiver
Unable to switch on the receiver keeps converting back to standby and reading check pow5
Try resoldering the main bridge rectifier on the power amp circuit board. You will have to remove the board from the heat-sink. The rectifier is mounted off the side of the board and screwed to the back of the heat-sink. Resoldering this usually cures that problem.
Posted on Oct 08, 2008
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
Marantz SR7400 AV Surround Receiver wont switch keeps converting to standby and reading check pow5
try a hard reset
leave the unit unplugged for one night and then switch it ON
Oct 07, 2008 | Marantz Televison & Video
Power 5 fault on marantz sr7400
Service manual says that POW5 error is because bad 5volts supply but could be something else. Check all supply voltages.
Jul 29, 2011 | Audio Players & Recorders
Our Marantz SR7400 displays check Pow5 when turned on for a few seconds and then dissapears and unit doesn't turn on. We unplugged it and wated and plugged it back in. Same message. we changed the...
pow5 - your receiver has an internal problem, most likely with power supply unit. As soon as macroprocessor detect the power problem it shuts down the receiver. Check the power supply at first.
Jan 08, 2011 | Audio Players & Recorders
When I turn on the receiver it displays check pow5, then returns to standby mode. SR7001 Marantz Unit
I have the problem of check POW5 too and have the similar procedure taken several times but it doesn't help. What actually problem I have encountered? Or the quality of this brand is not reliable? Does any body help?
Aug 09, 2010 | Audio Players & Recorders
I have a Marantz SR-5600 surround Receiver. It has been shutting off the volume at various intervals recently. When I attempt to turn it back on a display reads " Check POW5
The POW5 fault indication means that the 5Volt power supply grid is not OK. The unit needs to be repaired by a professional repair engineer. No user servicable parts inside.
Jul 19, 2010 | Marantz SR-5600 Receiver
Hello i have a marantz receiver sr7400 fuse
Unplug the unit. Carefully unscrew the screws for the case. Probably 4 screws, 2 on each side of the unit. Remove the cover. Look for the fuses, and replace with exact same type/specs of the faulty fuse. If the fuse, is on a printed circuit board, be careful dislodging the fuse. Hope this helps.
Apr 07, 2010 | Marantz SR-7400 Receiver
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
Reciever not working
Are all the speakers GOOD and all connected right?
If so then you have at least one blown output amplifier module.
Feb 16, 2008 | Sony STR-DE345 Receiver
Televison & Video Logo
380 people viewed this question
Top Televison & Video Experts
