Question about Acer X191WSD Monitor
X191w blank screen after 2 seconds
To anyone who can help,
okay so out of the blue my monitor goes blank... worked perfectly for a good year or more... no problems what so ever...
symptoms:
I power off the monitor and power it back on and it will display for 2 seconds before it goes blank again... I also tried unplugging it for a day... and got a good 30 seconds out of it before it blacked out again...
the power light is green all the way through...
there is zero functionality from the menu and eAuto buttons while blank....
video card is fine... plugged an old crt monitor to replace it for now...
dvi connection is fine cause it still gets a picture for 2 seconds...
it's kinda like it goes into a no signal monitor sleep mode when there is signal...
I've tried taking out the dvi cord and booting the monitor with out connections... and it will say no signal for 2 seconds and black out...
acer driver support is no help... they only have windows vista drivers no xp...
any help would be very appreciated.
thanks
  • 2 more comments
  • akumaokami Oct 24, 2008
    I have this same problem with my Acer P191w lcd monitor. I noticed however the image is still on the screen but with mine it's the brightness that goes out, the monitor looks blank but you can see the image if you look real close. I did research and found out the florecent bulb that lights the screen is either loose or going out. however I dont see any screws to get inside the monitor to replace it or if anyone sells the bulb.
  • KeaChan Dec 22, 2008
    thanks for the help... I'll give it a try... i already got a new monitor... but could always use a dual screen if it works.
    Thanks for the help... I already got another monitor,.. but I'll give it a try... always good to have a backup or a dual screen :)
    thanks again.
  • watson1996 Apr 16, 2009
    ditto on the screen going out. displays for a moment then goes black
Just got off the phone with Acer Suppport. This was after I sent an email to them, that suggested that I call. 8-/ annoying. So the guy on the phone says there is one thing that we can do before sending it in. Unplug it completely for the wall and computer. Hold the on/off button in for 30 secs. reconnect power and the computer. It worked for me
Posted on Dec 22, 2008
I have had my monitor for almost a year now. I comes on , displays image for 1 second and then goes blank, but it is still on power blue light is on. if i switch off and on it does the same thing. if i...
lumixgx, All you need to do is read my fixya profile for about an hour!! You will then know all you need to know about why your unit's "switch-mode-power-supply" /"CCFL inverter supply" circuit NEEDS SOME WORK DONE on it to fix it!!! Good luck with the repair. 12fixlouie
Mar 13, 2010 | Samsung 943BWX Monitor
Al2416W black screen (picture only lasts for 0.5 seconds)
After two years, it will more likely to have failed caps in the power supply, common problems in ALL monitors these days, theymade them to fail after a couple years, does not matter what brand, see examples here: http://s807.photobucket.com/home/budm/allalbums
Post back what you find inside.
Jan 23, 2010 | Computers & Internet
It switches on for just a second and then the screen stays blank
yetimonsta, Are you sure that the monitor is BLANK?? Or is it just BLACK? Or is it both BLANK and BLACK? Connect a known good monitor to your pc to prove that your pc is working correctly. What does your L90D+ do when connected to good pc. Have you done the flashlight test to evaluate the state of the "switch-mode-power-supply" when lcd panel goes black /blank?? View more of my profile on fixya and you will discover all the options you have open to you. 12fixlouie
Jan 17, 2010 | Hyundai L90D+ 19" LCD Monitor
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Jun 19, 2009 | LG Flatron L1750S 17" LCD Monitor
Problem with monitor
Hi.
Are you able to see a slight image on it at dusk and maybe with the help of a flashlight. since your blue light stays on the video board, may be okay.
It sounds like you have bad capacitors on your powerboard or possibly a burned out transistor on the inverter.
Only way to really tell is to open it up.
If you unplug the screen to video board ribbon, you may notice a different effect in the screen lighting.
There is a chance one of your bulbs is creating a problem
Should the screen happen to light up all white, then your power board and inverter are okay and the problem may be in the video board.
If it looks pinkish or dark or flickers then the bulbs or a bulb may be the issue.
If it flashes on then goes off, it's in the power or inverter board.
ebaysbammbammfran
Sep 14, 2008 | ViewSonic VX2235wm LCD Monitor
Monitor displays breifly then goes to blank screen
The power -inverter board probably needs an overhaul.
I redo many of these.
If the screen was pinkish or flickering before it finally got to this point, it is possible that a bulb has gone bad.
Fran
Sep 07, 2008 | Proview PL926WBi 19" LCD Monitor
Black screen
Hi
did you get a solution for this problem as mine does exactly the same!
Thanks
jim.ross@virgin.net
Aug 22, 2008 | Relisys RLT1720 17" LCD Monitor
Good picture for 30 seconds then screen goes black with a faint ghost of the image
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Blank after 2 seconds
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
Jun 14, 2007 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Acer X191WSD Monitor Logo
373 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
