My files print fine when I try on another hp printer but not on this one. I've tried changing paper, cleaning print heads, and all other system maintenance.
SOURCE: Our hp designjet 110plus is not printing black
Check whether the black cartridge is dry and whether it is releasing the ink properly. This you can check by rubbing the paper on the place where the flows.
Else check with a new cartridge. Even if the problem continues in the printer preferrence you have an option of service. click on it and the problem will be fixed......!
SOURCE: How do I clean the HP designjet 110plus printhead
You need to go to the hp download site and download the System Maintenance Utility Software. Its free, but you need it before you can clean the print heads. also, for some reason it works best when hooked to the network, not directly to Computer.
SOURCE: how do i fix a faulty printerhead for the hp
are you getting a message failure? fix the printhead how? if the printhead is faulty then you need to replace it. if this does not resolve the issue then you may have a problem with the carriage assembly. clean the contacts of the printhead and the carriage assembly with a damp, lint free cloth (old t shirt works good and water) if this does not help, than your problem is with your carriage assembly, trailing cable, main pca. let me know if this helps, if not than i can help you further
SOURCE: Designjet 100 failure of print head
try cleaning the contacts on the back of the head and also the contacts on the printer, it could just be a bad contact between the printer and the head.use a lightly damp cloth and be sure the printer is turned off.
If
you need more help come back.
Post
/ thumbs / testimonial are welcome!
