Question about Marantz Televison & Video
Marantz SR7400 AV Surround Receiver wont switch keeps converting to standby and reading check pow5
  • 1 more comment
  • egnarts Oct 07, 2008
    unfortunately I have tried this and it didn't work
    unable to switch on Marantz SR7400 AV Surround Sound receiver, keeps going on to standby and reading 'check pow5'
    No solution as yet, may need to get repairman
  • 1,183 Answers
I have the same reciver lying with me, and this is chronic problem of this model. What has happened is if you increase the volume on unit quickly and AV IC goes bad. As a work around what i did is , instead of the AUX ports to which my speakers were connected , i connected it using the Tuner ports at the back.
The other thing you can try is that worked for me just once , after which the unit started to go into stand by is
1. Switch of the unit disconnet the speaker cable from the back
2. Make the Volume knob at zero
3. Switch on the receiver, if the unit does not go into standy by, reconnect the speakers
4. Now increase the volume slowly and check
If this fails my friend , you need to get it serviced at repair shop.
Do keep me posted , I was not able to get it repaired in India , coz tere no service tech available for this unit.
Tech & Operational Support hours:
9:00 AM to 5:00 PM ET, M-F
Tel. 201-762-6666
Fax. 201-762-6687 Parts
Thanks
proton
Posted on Oct 07, 2008
  • Mandeep  Singh
    Mandeep Singh Oct 07, 2008
    Alternatively you can also try to reset the unit
    Should the operation or display seem to be abnormal,
    reset the unit with the following procedure.
    The SR7400 is turned on, press and hold the
    SELECT
    and S-DIRECT buttons simultaneously
    for 3 seconds or more.
    Remember that the procedure will reset the
    settings of the function selector, Surround mode,
    delay time, TUNER PRESET etc., to their initial settings
    Thanks
    Proton
    Guru:
  • 1,894 Answers
Try a hard reset
leave the unit unplugged for one night and then switch it ON
  • 1 more comment
  • dewan nafees ahmed Oct 07, 2008
    ok no probs
    It could either be a blown power supply or a board. Perhaps a main board reset will do the trick,
    but make sure you unplug the power before doing doing this. And yes please let us know.
    assuming this unit is new one
    if this does not solve the problem then t is best thing to call the company and ask for a refund.
    Main support number (630) 741-0300
2 Suggested Answers
SOURCE: Marantz SR7400 AV Surround Receiver
Try resoldering the main bridge rectifier on the power amp circuit board. You will have to remove the board from the heat-sink. The rectifier is mounted off the side of the board and screwed to the back of the heat-sink. Resoldering this usually cures that problem.
Posted on Oct 08, 2008
Marantz NR1402 AV receiver Going to standby Mode
There could be a short in one (or more) of the speaker connections. Try disconnecting all speakers and turning on the receiver. If it still switches to standby, there may be an internal problem.
Mar 03, 2014 | Marantz Nr1402 Av Receiver
Power 5 fault on marantz sr7400
Service manual says that POW5 error is because bad 5volts supply but could be something else. Check all supply voltages.
Jul 29, 2011 | Audio Players & Recorders
I have a 5.1 surround sound system hooked up t a Marantz SR7400 receiver. All of the speakers work fine, but my Subwoofer, which is a M&K mx-105, doesn't have any sound coming out of it. It's silent...
hi,
try one thing
go to the setup of the Marantz and surf for speaker configuration. check the status of sub woofer is it ON or OFF ( YES or NO). if OFF(NO) make it ON(YES).
ok
Jan 27, 2011 | Audio Players & Recorders
Our Marantz SR7400 displays check Pow5 when turned on for a few seconds and then dissapears and unit doesn't turn on. We unplugged it and wated and plugged it back in. Same message. we changed the...
pow5 - your receiver has an internal problem, most likely with power supply unit. As soon as macroprocessor detect the power problem it shuts down the receiver. Check the power supply at first.
Jan 08, 2011 | Audio Players & Recorders
When I turn on the receiver it displays check pow5, then returns to standby mode. SR7001 Marantz Unit
I have the problem of check POW5 too and have the similar procedure taken several times but it doesn't help. What actually problem I have encountered? Or the quality of this brand is not reliable? Does any body help?
Aug 09, 2010 | Audio Players & Recorders
I have a Marantz SR-5600 surround Receiver. It has been shutting off the volume at various intervals recently. When I attempt to turn it back on a display reads " Check POW5
The POW5 fault indication means that the 5Volt power supply grid is not OK. The unit needs to be repaired by a professional repair engineer. No user servicable parts inside.
Jul 19, 2010 | Marantz SR-5600 Receiver
Hello i have a marantz receiver sr7400 fuse
Unplug the unit. Carefully unscrew the screws for the case. Probably 4 screws, 2 on each side of the unit. Remove the cover. Look for the fuses, and replace with exact same type/specs of the faulty fuse. If the fuse, is on a printed circuit board, be careful dislodging the fuse. Hope this helps.
Apr 07, 2010 | Marantz SR-7400 Receiver
Marantz SR6001 AV Surround Receiver - Blinking Standy Light
For resetting sr6001: When power lights blinking, press "clear" + "pure direct" + "7.1 ch input" simultaneously for 3 seconds.
iskender
Nov 10, 2008 | Marantz SR-7200 Receiver
Oct 07, 2008 | Televison & Video
Televison & Video Logo
882 people viewed this question
Top Marantz Televison & Video Experts
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
