Degaussing problem Hi can you please tell me if degaussing a Sansui SV2918 TV does not help, what else could be wrong. Could it be the croma or demodultor in the main IC. The colors come wright if you degausse it with a coil. But if you turn the tv of for a while and you turn it on again the colors is smeared again. Mainly green. Thank you
    Scholar:
  • 92 Answers
There is an automatic de-gaussing circuit within the TV and it's likely to be the culprit. When the set is first turned on (before you even see a picture) this circuit is active and as it warms up, a thermistor opens up and stops the circuit from operating. It does this because as it heats up it's resistance rises and the circuit stops the current flowing through the de-gaussing coil. Over time from the heat/cool cycle, the connections to the circuit board fail. Simply re-soldering the thermistor is probabaly all that's needed.
Posted on Oct 09, 2008
TV turns on but top 1/3 of the screen is scrambled
Hi Jeff, the links below are YouTube videos showing how to fix your television if colour distorts, The item that's waved in front of the television is called a degaussing coil, I hope this helps.....CHEERS..
Fix your own CRT Television Color Problem
Fixing Purity Error on CRTs with Degaussing Coil
Arcade Repair Tips Using Degaussing Coil
May 13, 2016 | Televison & Video
How can i troubleshoot a crt tv with colour problem.
Hi Ibrahim, the links below are youtube videos showing how to fix your television, The item that's waved in front of the television is called a degaussing coil, I hope this helps........CHEERS..
May 12, 2016 | Televison & Video
Sir, Iam Raju from vizag. My TV Sansui 21 inchs flat colour tv. displaying with colour. please tell me our tv problem. and solution my mail id arajudmsc@gmail.com please sir
Does this tv dropped? if not, you may have large speaker beside it. Keep it away from magnets, speakers that are not magnetically shielded placed near your tv can cause stain(the problem you have in your tv). After doing so and still stain persist, degaussing in needed (not available as household tools) what we can do is leave it like that for quite sometime it will eventually disappear, arround 2 weeks,, not unless your tv's tube is defective. Tv's are equipped with internal degaussing circuitry but needs time to clean those stains, since it work only few sec after switching On your tv. Hope it helps
Mar 02, 2010 | Televison & Video
Sansui picture is fluorescent ping purple green, etc. Worked fine yesterday.
HELLO
By the sound of this you have a degaussing problem! I think what has happened here is the degauss circuit has failed and the usual cause is the POSISTOR.
What you should try to do is switch the TV on, then OFF again and leave it for 30 mins before switching on again. When you have done this and the problem is no better, then contact a service centre who will cure the fault for you.
Alternatively, try to borrow a DEGAUSS COIL and with the set on, switch the coil on and by using a circular motion go around the screen of the TV moving backward slowly as you do it. When you are say 6 feet away from the screen switch the degauss coil off.
HOPE THIS HAS HELPED YOU (:-)
Nov 07, 2009 | Sansui DTV2760 27" TV
Hi I live in Kempton Park South Africa and my Sansui TV Model SV2918 does not swith on. The product is very good and I would like it to b repaired. Do you have suggested maintenance people that I coul
Hi, I need assistance re tuning my TV for the VCR. I am not able able to get the two solid test lines. My TV is a Sansui SV2790NICAM and the VCR an Orion.
Please help!!
Mike, C.T.
May 25, 2009 | Televison & Video
Degaussing problem
There is either a large metal object or magnet too close to your monitor. Write back! This type of problem has always sparked my intrest! Thank you!
barneyluc
Oct 07, 2008 | iLO 2600 Television
Sansui tv sv2918
replace vert IC301, C432, ( D431 & R431 should also be blown)
Jun 18, 2008 | SansuiM1315 TV
How do i degaussing a dell e550 color monitor usung its built in degaussing system?
Hi - Your monitor has a built in degaussing feature that executes every time you turn the monitor on. To perform extra degaussing, turn your your monitor off for at lest 30 minutes then turn it back on. This will cause it do a more thorough degaussing as opposed to just turning your monitor off and then turning it right back on. If this answered your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
May 06, 2008 | Computers & Internet
Screen Colours incorrect
Your CRT (Picture Tube) screen mask has become magnetized. You need to degauss the CRT. Have you moved you TV lately or at any point had speaker sitting next to it? These are two things that can magnetize the screen mask. Well in any event you will need what is called a degaussing coil to demagnetize the CRT.
Here is the degaussing procedure:
Standing about 10 feet from the TV Screen turn on the degaussing coil which is in a vertical position and rotate it in a circular motion walking towards the TV .
Once about .5 to 1 inch from the TV continue to rotate the degaussing coil and the move away from the TV while still rotating the coil.
Once at the point where you began, position  the coil to a horizontal plane and quickly move the coil back about two feet and the turn the coil off.
This will deguass the CRT.
Thank you,
Shuttle83
Oct 30, 2007 | Sony KV-36FS16 36" TV
Televison & Video Logo
216 people viewed this question
Top Televison & Video Experts
