When i select shutdown computer it doesn't sitch off it restart again
I have windows xp , all applications are working properly but when i go for sysyem shut down the system not down its go for restart pl give me solution
surendra
  • 90 Answers
Thanks for using FixYa.
You need to disable the Startup items from the MSCONFIG.
Start the PC and in the Desktop
Go to
1. Click Start --> Run --> Type MSCONFIG --> Click OK
2. On the General tab, choose Selective Startup
Uncheck the program running and click apply. then try to shut down.
Let me know the result, I will further investigate and fix the problem.
Best of Luck & Have a Nice Day
Puneet
Posted on Oct 07, 2008
How can i reboot my computer please
Rebooting a computer means, pressing the Reset/Restart button. But if you wish to securely restart it, click Start (Windows XP) and then "ShutDown" button, again click "Restart". There's another option when Windows XP is in Classic mode, once you press the Shutdown button, you'll see a small window showing "Shutdown", you can click the arrow button next to the "Shutdown" and then select "Restart", now click the "Ok" button to restart the system. In Windows Vista and Windows 7, click "Start", if you don't see the "Restart" button, you might be seeing the "Shutdown" button, just next to the "Shutdown" button, there's a small right arrow button, click it and select "Restart". Your system will restart.
Let me know if you need further help.
Good Luck.
Sep 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
How do I reboot the computer?
Click on START -> Shutdown and scroll to restart option.
Mar 03, 2011 | HP Pavilion m7760n PC Desktop
What means of reboot ?
Reboot means to restart the Computer. All the opened applications will be closed and Computer will be re power cycled.
Jul 10, 2010 | Microsoft Windows XP Professional for PC
Umm... can't boot to windows at all so the program that was provided wont work, can't reinstall windows automatic disk eject on startup!
Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
And Thanks.
Mar 19, 2010 | Microsoft Windows XP Professional With...
Restart at shutdown
This behavior may occur if Windows stops responding during a typical operation or during the shutdown process. By default, the computer is configured to automatically restart when Windows stops responding. To view this setting, follow these steps:
  1. Click the Start button, right-click My Computer, click Properties, click the Advanced tab, and then click Settings under Startup and Recovery.
  2. Under System Failure, view the Automatically restart check box. If the Automatically restart check box is selected, Windows automatically restarts if the computer stops unexpectedly.
I can give you anotther solution too
Thanks
Xeeshan
Nov 22, 2009 | Microsoft Windows XP Professional
Wont shutdown when shutdown butten is pressed shuts windows well i have to cut off power to shutdown.
Go to Start > Run and type services.msc. Locate the nVidia Driver Helper item and right click it. Select Properties. Set the startup value of the service to “Manual” or “Disabled”.
Your computer should shut down normally now.
Apr 18, 2009 | Computers & Internet
Computer restarts on shutdown
If your computer constantly restarts while you are using it, or if you are trying to shut down the computer after it has stopped unexpectedly, click to clear the Automatically restart check box. If you clear this check box, you receive an error message when the computer stops responding. This error message may describe the cause of the problem. You can also review the system log in Event Viewer to view the critical stop error that occurs when the computer restarts.
Thanks & Regards
Nandu :)
Mar 25, 2009 | MSI Computers & Internet
PC SHUTS DOWN MONITOR AND FAN
Hi Brandy19960,
Thanks for the posting in FIXYA.
Please do the following steps:
Step – 1
Right-click on My Computer, open Properties, click the Advanced tab. Under “Startup & Recovery,” click Settings. Under “System Failure,” Uncheck the box in front of “Automatically restart.”
Step - 2
To change the setting, click Start --> Run--> type GPEDIT.MSC, click OK.
Drill down to Computer Configuration | Windows Settings | Security Settings | Local Policies | Security Options.
In the right pane, find “Shutdown: Clear Virtual Memory Pagefile.”
NOTE: Since someone actually has to have set this policy, the problem will be pretty rare, but is worth mentioning. However, Forum participant “roadrunner” reported that the personal security app Privacy Eraser automatically enables “Clear virtual memory pagefile,” and, therefore, may be the cause of a slow shutdown.
Step - 3
When Windows XP won’t powerdown automatically, the APM/NT Legacy Power Node may not be enabled. To enable this, right-click on the My Computer icon, click Properties | Hardware | Device Manager | View. Check the box labeled “Show Hidden Devices.” If it’s available on your computer, there will be a red X on the APM/NT Legacy Node. Try enabling it and see if this resolves the powerdown problem (Tip from Terri Stratton). Or, to check the other side of the APM/ACPI coin, open the Power Options applet in Control Panel. If there is an APM tab, make sure the “Enable Advanced Power Management Support” box is checked.
Step - 4
Try a Shutdown shortcut -
For a shortcut to RESTART Windows XP:
SHUTDOWN -r -t 01
For a shortcut to SHUT DOWN Windows XP:
SHUTDOWN -s -t 01
Step 5
WORK-AROUND: Disable power management for your USB hub: Open Device Manager (click Start, click Run, type DEVMGMT.MSC, click OK). Double-click to expand Universal Serial Bus Controllers. Double-click USB Root Hub. Click Power Management. Uncheck the box “Allow the computer to turn off this device to save power.” OK your way out
Step – 6
Click on the Start button.
Select Run from the menu.
In the run dialog box type “msconfig”.
Click OK.
Once in the msconfig utility select the startup tab. In the startup tab you will see several programs listed with a checkbox beside it. If there is a check mark beside the application listed, the application will startup when your computer starts up.
Regards
ELLIN
Sep 13, 2008 | Microsoft Windows XP Home Edition
Viao PCG-GRX650 won't shut down fully
DaveBaker,
Here are a couple of tips that I've collected that may address your problem.
Go to start>run>then type in "cmd" without the quotes. this will bring up the command prompt. next type in the following command: "shutdown -s" without the quotes again. This should tell your system to shutdown your computer entirely.
Next
Try doing this. Hold down "ctrl" and left click "shutdown". This skips some windows XP shutdown procedure and should do the trick.
And, finally
http://support.microsoft.com/?kbid=831431
You cannot log off, restart, or shut down your Windows XP-based computer This article talks about an issue with Norton 2003 incompatibility.
Would appreciate any feedback as to which of these worked for you.
Thanks much!
Ron-
Nov 09, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
