Question about Daewoo DWC-121R Air Conditioner
Daewoo DOC-091RHL portable air conditioner reads E 1
Fan will run and the compressor will try to turn on (when on air conditioner setting), but then will turn off and the display will read E 1 and then fan will turn on again, over and over. Then if in the (fan only) setting it will read E 1 and turn on and off real fast, over and over, but the fan will run just long enough to turn off. The fan will only run about 2 seconds before shutting off in this setting (fan only) but turn right back on.
SOURCE: Outdoor fan motor is not running fast enough?
Thanks for the suggestion. I figured out the problem. The replacement fan motor I bought was general fan motor. it had 5 wires. Two of them went to the capacitor (this unit has combo capacitor, 3 leg). I followed the schematic diag on the motor and connected one leg to the C and the other leg to the FAN on capacitor. what was happening, the start winding was working against the run winding in the motor. Once I switch the wires in the capacitor, fan ran at full speed. thanks again for your reply.
Posted on Oct 15, 2008
SOURCE: Whirlpool portable AC, compressor works, but no exhaust fan
This is a single speed permanent split capacitor motor for the condenser. One of the capacitor wires shows infinite resistance to hot and netral. The motor needs to be replaced.
Posted on Mar 31, 2009
  • 306 Answers
SOURCE: Compressor Fan stop working
Do you have a meter? Either the fan is bad or the capacitor is bad. Ohm out the fan and then the capacitor. Be sure you take the disconnect out of the electrical box on the side of the house and or trip the breaker off. The capacitor is a dual run one side operates the compressor and one side operates the fan. I would really bet on the capacitor being bad. Have seen that a lot in my experience. Be sure to make note of the wiring of the capacitor before you take it out to check and if you are not sure how to check it take it to the parts house and they can check it.
Posted on May 17, 2009
  • 588 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • 19 Answers
SOURCE: When I tried to turn on my Daewoo air conditioner
no you may not you can check the fan's capasitor or you may have to get a new fan motor
Posted on May 03, 2010
How do I get my LG 12000 BTU ac/dehumidifier to dehumidify
This is a quote from the manufacturer.
Dry mode is used to remove humidity from the room
without additional cooling. Once the set temperature
is reached, the compressor and circulation fan turns
off and only the exhaust fan will run. Fan speed is
pre-set and cannot be adjusted.
Apr 24, 2011 | LG LP1200DXR Portable Air Conditioner
Compressor not turning on - but unit turns on and fan works - even when temp turned all the way down.
all the way down is as warm as the refrigrator can get. Sounds like start components are the problem.
Apr 17, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
I have a portable air conditioner from dimplex, dac15hc, it cools when 1st turned on then aprox 1-2 min later i hear the compressor turn off, the air coming out gets warmer until a code of ES is shown on...
E5 Outdoor activation of compressor over heatprotection or motor lock. Check fan motor mechanism is locked. Replace fan motor.If compressor getting high amps, replace running capacitor and check. If still problem, replace compressor. Thanks, helpful.
Feb 01, 2011 | Heating & Cooling
My daewoo cielo (nexia sedan) AC is not working.only fan is good
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 08, 2011 | Daewoo Heating & Cooling
Compressor wont start..blows hot air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 27, 2010 | LG LP1200DXR Portable Air Conditioner
Air conditioner shuts off and trips breaker on power cord
It sounds like a short or ground in the compressor. If you have an ohmmeter, unplug the unit and use the meter to check the wires to the compressor. Connect 1 meter lead to the compressor case then to the wires coming from the compressor 1 at a time. If none are grounded then connect 1 meter lead to the Com. Then connect the other lead first to the run wire, then to the start wire reading the resistance each time. neither should be less than 1. You can also check the condenser fan.
May 25, 2010 | Whirlpool ACP102PS Portable Air...
I have a Noma/ DeLonghi portable air conditioner. 3 Modes-fan-dehumidify-air conditioner.When I try the Dehumidify or air conditioner mode the mchine strains to start up and then blows a fuse. Fan still...
Compressor is not starting, it could be a bad or shorted run capacitor, start capacitor and relay, low voltage, loose or disconnected wire or a shorted compressor.
Aug 22, 2009 | Heating & Cooling
Compressor cuts in and then cuts out
sounds like compressor is locked up or bad compressor start components or could be tripping on a high pressure switch is condenser clean? .T
Jun 17, 2009 | Danby Portable Air Conditioner
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Daewoo DWC-121R Air Conditioner Logo
347 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
