Question about Whirlpool LSR5132PQ Top Load Washer
Water changes temperature
When my washer is filling, the water temperature will change. I have the temperature set to warm but it keeps changing to hot. When the hot water starts to run, I turn the machine off then on. The warm water runs again then will soon change back to hot. When I have this problem with my washer, a small stream of water runs out from underneath it. I've noticed there has been some times where the washer has worked just fine. Then the problem will start back up again.
I would more than greatly appreciate any information related to this problem. Thank you, Kathy
  • 49 Answers
Just a suggestion kathy;
the hoses that connect the washer to the hose bibs at the wall usually have screens in them at either end. they connect on both ends the same as a garden hose. if the screen on the cold supply is somewhat clogged, this could be your problem.
Posted on Oct 07, 2008
Raise temp above 120
Raising temperature above 120 degrees requires service call.
Or change dip switch settings and risk voiding warranty and causing service call expense.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#temperature
Earliest versions of Rheem tankless 2006-8 let you set temperature up to 140 degrees F using remote.
However the hotter setting caused error codes because the burner cannot keep up with both high temperature and large volume of hot water rushing through pipe. Especially in winter with cooler incoming water that must be heated more to reach temperature set point.
The burner simply cannot keep up.
So Rheem changed maximum temperature at remote control to tepid 120 degrees, which is not hot enough for folks wanting hot shower, or folks filling whirlpool tub because water in tub cools before tub fills.
Oct 27, 2012 | Rheem Tankless Water Heater Main Remote...
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
Automatic warm/cold water temperature setting does
The temperature control board is bad . Pt # 388246
Aug 17, 2009 | Kenmore 22422 Top Load Washer
Washer filles with water but wont change cycles
start filling the washer on the warm cycle,turn washer off,if the water keeps filling then you have a bad water inlet valve,if it turns off then you have a loose water level hose or the water level switch is bad-mike
Jul 21, 2009 | Kenmore 22422 Top Load Washer
No cold water
souds like the cold valve has gone get and expert in to change it or change it yourself you can get parts from espares
Jun 28, 2009 | Washing Machines
Water is not hot enough
What a great energy saver response....run water through another tap in the house in order to fill the pipes with hot water! I have the same problem; cannot even get WARM water in my tub. I have 2 solutions: #1, on my incoming water pipes are regular faucet handles which I am going to attach a hose on the hot side that will reach into the washer and manually mix the temperature. #2, purchase an old refurb washer at a used appliance store that HAS a hot-water setting and hope they will take the "wonderful, new energy saver" as a trade. There are just some times you really need HOT water. I can't imagine washing diapers in cold, although I haven't had to do that in many years. Energy saving factory settings: capital "B", capital "S"!!!
Mar 30, 2009 | Washing Machines
Hot water will not fill into the tank when starting cycle.
The ECU is at fault.
Change it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 13, 2009 | Washing Machines
Water intake and wash cycle
change the water intake valve, that is the only answer i think
Oct 10, 2007 | GE Spacemaker WSLP1100D Top Load Washer
Whirlpool LSR5132PQ Top Load Washer Logo
60 people viewed this question
Dan Webster
Dan Webster
Sal De
