Question about Samsung Washing Machines
Our samsung p1053 washing machine keeps locking up and showing the error message "h2". the only thing we can do is then stop the machine and restart the program cycle from the beginning. this error message is not listed in the user manual and we are at a loss to why this keeps happening. any ideas ? Many thanks
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Posted on Jan 13, 2009
  • 53 Answers
SOURCE: Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Posted on Nov 01, 2009
Testimonial: "Thank you so much - exactly right"
SOURCE: Samsung J845 error SE or 5E
Just did the above directions on my washer also.And to make things easier you can pull out the whole drainagehoses by removing 3 little phillips head screws and a couple of hose clamps.Then pull all hoses off individually and clean out all hoses and assembly a lot easier.
Posted on Jul 29, 2010
kapishtech
  • 2272 Answers
SOURCE: Samsung washing machine shows error "LE"
This is usually a communication error, unplug the machine for 20 minutes and then see if it returns when power is restored.
but if this does not helps then the actual reason of LE error code is as follows:--
LE LOCKED MOTOR ERROR
• The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
• The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, female, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
• The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
• The hall sensor is out of order/defective.
The hall sensor seems to be part of the motor.
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Aug 11, 2010
SOURCE: SAMSUNG 845 - ERROR MESSAGE HE2 - not in manual
heater or wiring
Posted on Aug 19, 2010
Samsung front load washing machine showing 2H error
Are you sure that it's a 2H error and not a H2 error?
Mar 09, 2015 | Samsung Washing Machines
Error H1 and H2
this error happen when the temperature increase 7c or more in 1 minutes o by 2c in 2 minutes
Turn OFF the machine for clear and turn ON again.
God bless you
Jul 18, 2012 | Washing Machines
What does "ue'"mean?
UNBALANCE ERROR - Display shows UE.Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Jun 29, 2011 | Samsung Washing Machines
Hi, Bosch WAS28720FF/01 Washing machine sometimes empties and sometimes does not. "Pump blocked" is the typical error message. Pump and drain tube have been inspected and cleared, and there is...
Bosch WAS28720FF/01 Washing machine This video will show you How to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 01, 2011 | Bosch Washing Machines
I have a front loading washing machine and when I press the button to start the washing machine, the machine beeps and the error message "dr" flashes. I know it is the door, what do I need to do...
You need to fit a new Door Interlock switch,Partly remove door boot seal to access this then 2 screws secure the lock/Plastic thing with 3/4 wires on a plug into it....Pull out mains plug 1st keep sa f e at all times.....
Nov 26, 2010 | Frigidaire ATF6000ES Front Load Washer
Jun 14, 2009 | Samsung WF203ANW Front Load Washer
My brand new Samsung J845 washing machine keeps showing an error message (which is not in the manual of 1E. What could this possibly be and how do I fix it?
I contacted Samsung Australia and was informed that this was a Water Sensor Level fault. The machine will be fixed under their warranty guidelines. Thank you.
Apr 17, 2008 | Samsung Washing Machines
Washing Machines Logo
232 people viewed this question
Top Samsung Washing Machines Experts
easy alberta
easy alberta
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
