Question about Kenmore 62602 Electric Dryer
Kenmore dryer I need to replace the belt from the back. It is broken in two, so I need a picture to see what it looked like. Also the pulley (?) came loose. I need a picture to see where it goes before I replace the belt. I m reading this off the dor of the unit: your little system says I am not submitting it correctly.......It is about 5-6 years old. kenmore electric dryer 29 inch wide dryer model # 110.62722100
  • 550 Answers
It is very much easier to replace the belt from the front, than the back, the cabinet disassembles from the front, and the mechanism remians attached to the rear plate and cabinet floor.
  • pull lint filter out
  • remove 2 screws from under lint filter
  • with putty knife or other blunt blade, release clips at front corners of cabinet top
  • tilt up cabinet top
  • remove 1screw 1/3 way down each side of front of cabinet.
  • lift off cabinet front
  • drum, motor, tensioner, are all exposed
  • lift drum out forward
  • check rollers, drum felts, nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage and you dont want to do it again next month)
  • reinstall tensioner in slots in cabinet floor, reinstall tensioner spring between tensioner and cabinet floor
    (Once the cabinet is open the tensioner mounts are easily visible)
  • loop belt around drum at the wear marks of the prior belt
  • reinstall drum on unworn bearing rollers etc
  • loop belt around motor pulley
  • pull tensioner hard against spring to end of travel
  • loop belt around tensioner
  • relax tensioner
  • spin drum by hand to ensure belt isnt going to jump off
reinstall cabinet in reverse order
~15 MINUTES, but I do 3-4 per day
Posted on Oct 08, 2008
  • chotu Sep 11, 2011
    This is good advise, thank you..Salim.
  • 943 Answers
kenmore dryer - whirlpool.gifHere is the belt diagram.
Posted on Oct 07, 2008
Tip
Kenmore Dryer Belt Diagrams and Replacement
Your dryer belt has broken and you have a new belt to install, but you do not know how to route the belt properly. Here are some pictures or diagrams to help you see how the belt needs to go. Of course the belt needs to go around the drum so that is not included.
The important part is the routing around the motor and the tensioner pulley.
For Kenmore models starting with 110 or C110 with a removable back use this:
Style: Flat with ribs
Installation Tips: Ribs against drum
For dryers starting with 110 or C110 with nonremovable back use:
For Dryer models starting with 417 use:
Installation Tips: Ribs face toward drum
on Mar 06, 2010 | Dryers
Kenmore 110.731102100 Gas Dryer replace belt
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
Leave the drum in the machine. Now, directly in front of the motor on the floor of the dryer you will see two slots. This is where the idler pulley will go. You'll notice on the pulley at the bottom of the bracket a piece of metal sticks downward. This will sit in the slot closest to the dryer wall, and the end of the bracket will slide into the other. You'll want to slide the end in first. Now with the pulley in place take the belt and put it around the drum tread side down. To hook the belt around the motor pulley you'll have to pull the idler pulley towards closest dryer wall and place the belt around the motor pulley. Slowly release the idler pulley and thats it. Put it together and your done.
Jun 03, 2012 | Kenmore Dryers
Drum does not turn
Here are a few things to check. If you don't feel comfortable performing these check, please have a repair person come in and check it.
* Broken belt. Open dryer and see if belt is still wrapped around the drum. Pull on the belt to make sure it's not just hanging there. Inspect belt condition. Do not apply spray adhesive in this case: replace the belt. If belt is broken, look for contributing causes for failure such as worn drum rollers, damaged felt kit, or stiff idler roller.
* Motor burned out. Remove belt from motor pulley and start dryer. If motor runs but is noisy and motor is unable to turn the drum when the drum belt is threaded back on the motor pulley, then replace the motor.
* Thermal fuse is open. Run continuity test.
Hope this helps.
Sep 10, 2009 | Kenmore 63942 Dryer
Replace belt on kenmore 97281100 dryer
You have to remove the front panel. The top folds back and there are 2 screws on the inside corners to release the front. Eric
Sep 07, 2009 | Kenmore Dryers
Amana dryer does not run but i can hear the motor faintly
Sounds like the belt is either broken or slipped off the pulley. Remove the back of the dryer and find the motor. Look to see if the belt is still attached to the pulley. If not, look to see if it has slipped form the pulley and is hanging from the drum, or if it is broken. More than likely, regardless of which it is, you will just need to replace the belt.
Jun 03, 2009 | Amana ALE331RAW Gas Dryer
How do you replace a broken belt on the Kenmore 80 series dryer?
The belt is acessable from the front of the dryer you can remove it by popping the top up then taking off the front of the dryer off the drum will come out now place the belt around the drum and put back in now the belt goes around the drum the motor pulley and under the tentioner pulley replace front and top and you are good to go thank you
Please rate me
Apr 20, 2009 | Kenmore Dryers
Can't get replacement parts back on Kenmore 60 series dryer.
The belt has groves, right? Make sure the groves go over the motor pulley from the right. The idler pulley is spring loaded. Place the belt around the idling pulley with the smooth side of the belt on the pulley. This should work.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Broken Belt--kenmore 70 series dryer
it is not that hard to replace the belt if you have the front panel off of the dryer. place the idler pulley in the holes located below the motor pulley put the belt around the drum pull the idler back and the belt loops around the idler and onto the motor pulley
Dec 10, 2008 | Kenmore 24032\24036 Top Load Washer
How do I replace belt on kenmore dryer 66512?
under the lint screen on the top of the dryer there are 2 screws. remove these screws. aong the edge where the front of the top of the dryer meet the top of the front of the dryer there are 2 clips. press in the clips with a putty knife to raise the top. look inside you will see 2 screws that go into the front of the dryer. remove thoughs screws and the front will lean forward and lift off. there you will be able to put belt around the drum, tension pulley and motor pulley
Nov 27, 2007 | Kenmore 65924 Electric Dryer
Kenmore 62602 Electric Dryer Logo
282 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
