Question about ViewSonic VX2235wm LCD Monitor
Vx2235wm lcd flickers a bit then turns white
When i turn on my vx2235wm it's fine for a few minutes then it flickers the screen shows white stripes/bars then the screen goes white can i get it fixed?
    Novelist:
  • 159 Answers
White screen is an indication of a faulty video board.
A blown fuse in the actual screen will cause the same effect but usually these do not reset on a fresh startup.
You can check the ribbon going from the video board to the back of the screen to see if it is somehow working loose, but I think based on your description that this isn't the problem.
ebaysbammbammfran
Posted on Oct 12, 2008
I have a Zenith Z50PT320 plasma tv. After a few minutes the picture turns very posterized and flickers. Should I replace the Main Logic CNTRL T-Con board?
There is no T'Con board to Plasma TVs. Flickering can be of many reasons. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Dec 09, 2016 | Zenith Televison & Video
Lg55lv4400-va 55" flatscreen tv ( not a plazma) has developed a wide flickering vertical flickering stripe down the screen. Has been fine . Goes away once in a while. An Ideas what is wrong ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Televison & Video
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. any Ideas ?
NP50 has white vertical stripe down left side of screen
Display is faulty, I would say. Prove it with an external screen.
Mar 06, 2014 | NEC Office Equipment & Supplies
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Viewsonic vx2235vm does not turn on
This really sounds like you have a power supply board that is having problems with the filter capacitors which are causing it to not start up correctly. Here is a like to a repair guide including video instructions showing how to open and repair the monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-viewsonic-vx2235wm-lcm-monitor/
Part one of the video guide:
Feb 07, 2013 | ViewSonic VX2235wm LCD Monitor
Hi, I have a ViewSonic VX2235mw LCD Monitor it was working fine then all of a sudden the screen turned off and now it wont turn back on. The power light is on and is Blue but no sign of life in the screen...
This is a very common problem with this model after a few years of use. This problem is caused by a failure of the capacitors in the power supply board hat powers up the back lights in the monitor. When the back lights don't power up you get no display on the screen. Here is a link to a repair guide for that model that shows how to open the unit and what to look for and replace to repair the monitor.
Here is part one of the three part video repair guide posted at the above link:
Jan 29, 2013 | ViewSonic VX2235wm LCD Monitor
Samsung television flickers to bright white fuzzy picture
In such cases, we have to ensure that it is not the input device that is causing this problem. So, please switch your input device to something you are sure, works. If you notice same problem, look for loose contacts in inter connecting cables and jacks. If problem persists, please refer it to a qualified service technician.
Jul 28, 2012 | Televison & Video
I have a Sony VAIO PCG-K25 Notebook Problem. When I Push the Power on Button, A flickering white screen comes up. The system goes throught boot up just fine but the LCD screen remains white. When hooked...
Hello
These symptoms are not the inverter problem, What can you do if the laptop LCD screen turned completely white? From my experience I can tell that this problem may be related to the following: 1. Loose connection between the video cable and the LCD screen. 2. Defective LCD screen. 3. Defective motherboard (I assume the graphics card is integrated into the motherboard).
Check these by yourself or get assistance from sony support.
Good Luck
Dec 22, 2010 | Sony VAIO PCG-K25 Notebook
Tft problem
your monitor might not recieving incoming signal thats why it turns off try to examin your cpu this might be the problem your system is no booting...replace your videocard..
May 20, 2010 | ViewSonic VX2235wm LCD Monitor
ViewSonic VX2235wm LCD Monitor Logo
1,408 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
