Protron PLTV-32 Television Logo
Posted on Oct 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv stopped working, will not turn on, is there a reset button?
Tv wont turn on, no lights come on, nothing, is there a reset button somewhere? can this be fixed?
jason
Level 3:
  • Master 905 Answers
  • Posted on Oct 07, 2008
jason
Master
Level 3:
Answers
905
Questions
8
Helped
321124
Points
2511
It can be fixed , it might be a fuse or a protection component or the power transformer but it will have to be tested to find the power problem.
Had the ps3 working fine, plugged it into another tv and nothing, the tv wont pick up the signal.. went to plug it back into the 1st tv and still nothing
Try resetting the display back to standard definition -
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, then beep again 5 seconds later. Let go of the power button when you hear this second beep
Wait for the PS3 display to reset
Hope this helps
22helpful
8answers
My samsung remote for my blu ray player stopped working for my samsung TV today. i have never had this problem before. it still works on the blu ray player which then turns on the TV like it is supposed...
On blu ray remote control hold down TV Power+01 at the same time. If the TV turns off the controller is programmed. If not, try TV Power+02, +03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
4helpful
2answers
My sony trinitron tv wont turn on. it blinks 4 times on standby. what do i do
Try a reset:
  1. Turn on the television.
  2. On the TV remote control, press and hold either the RESET or UP ARROW button.
  3. While holding the RESET or UP ARROW button, press and release the POWER button on the front of the TV. NOTE: The TV will turn off and then back on.
  4. Release the RESET or UP ARROW button.
If that doesnt solve it, you will need a repair.
2answers
Turn tv off wont turn back on ! Model#32AV502R TOSHIBA
Notes from user manual: http://www.tacp.toshiba.com/tacpassets-images/models/37av502r/docs/37av502r_om_e.pdf
Unplug the TV for about an hour to see if it will reset itself, if not, try:
TV stops responding to controls:
If the TV stops responding to the controls on the remote
control or TV control panel and you cannot turn off the
TV, press and hold the POWER button on the TV control
panel for 5 or more seconds to reset the TV.
Reset Factory Defaults
To reset all settings and channels to their factory
default values:
Press and open the Setup menu.
Highlight Installation and press . A new set of
Installation menu icons will appear.
Open the System Status menu, highlight System
Information
, and press .
Press tu to scroll through the menu bar to select
Factory Defaults.
Enter your PIN code (or 0000 if no PIN code has been set).
Highlight Yes and press . The TV will turn off
automatically after a few seconds. After the TV turns off,
unplug the TV power cord and then plug it in again to
complete the reset process.
To cancel the reset:
Highlight No and press .
Otherwise you may jhave bigger problem inside the TV.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
1helpful
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
3helpful
3answers
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
[email protected]
TV wont stay on
no reset button on the tv maybe the tv is shock when you switch on the tv cause sometimes lizard always stuck down the pcb...try check the horizontal output
Timer light blinks on and off and tv wont turn on
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
If ever resetting is no effect then the problem is in the "DM board"
The constant blinking green light means that the TV is not booting up. This is a common problem on this set. Hope it may help you; Regards, VOTIT
Tv wont turn on
That same thing just happened to my t.v. The repair person will be here on 10/10/06. I will let you know what they say.
Top Protron Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
