Question about JVC RX-9010V Receiver
The EQ for the JVC RX-9010V
I have my Dish network hooked up optical. I am useing the DTS Pro Logic setting on the stereo. I have 2 external MTX subs *all MTX speakers.
My problem is getting a good Eq setup for watching movies, sports, etc.
Does anyone here have a setup they are happy with and maybe let me try it out. Any help is better than no help.
Is setting it up 5 channel stereo better? Or 3d action? (never use it)
I was also thinking of buying a new center channel speaker. Any advice?
snakehead
  • 1074 Answers
SOURCE: JVC RX6040 OVERLOAD TROUBLE
clean your volume control if that does not help take it to a tech for repairs.
Posted on Mar 30, 2007
snakehead
  • 1074 Answers
SOURCE: RX-668V - Center Speaker Channel
have a tech check your set it is a bad cap that that bias a very small voltage to that circuit or it could be cold solder.good luck.
Posted on Apr 16, 2007
SOURCE: JVC RX-9010V - Setting up Digital Inputs
Just to the left of the volume is a "settings" button. Press it and cycle through the options until you reach "Digital Coax," then use the "Control" up and down buttons to change the assigned source.
Posted on Jul 04, 2008
justuscc
  • 360 Answers
SOURCE: jvc kd-g720, hook up eq
yea but you will only have control on the low side of the eq. your beter off using that eq for your mids and highs
Posted on Oct 02, 2008
  • 125 Answers
SOURCE: analog only
You need to connect your source to your receiver with a Digital coax cable or a Optical cable to get true surround sound. Analog will only give you simulated surrond sound.
Posted on Mar 28, 2009
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
I have a JVC RX-9010V I am not getting any sound but i am using smaller speakers rated at 8 omns but the one is rated 150 watt..no sound no hiss..The amp does click as it where turning on, have seen n
Have you tried re-initiating it ? Strange the unit initiates but no sound.
Sorry, I forgot exactly how, but you can Google " factory reset
JVC RX-9010V". hope that helps.
Oct 27, 2014 | JVC RX-9010V Receiver
Have a JVC RX-9010V receiver and get no sound on FM , tv, etc.
no my antenna is a good one i tried with mp player too?? Is this a way to reset it to factory?
Nov 14, 2013 | JVC RX-9010V Receiver
I have an older onkyo 1994 or 1995 receiver dolby pro logic with the amplifier and 6 disk changer wnd the system is clear as could be in cd mode. my problem is Ihave my xbox hooked up to the tv with hdmi...
No no no!
# 1. You need to connect all your components to your TV via an HDMI cable. For true HD and digital sound this is needed. Your TV (if its an HD TV) should have 3 or 4 HDMI inputs. So your Xbox/PS3 should be connected via HDMI cable. Your HD sat or cable box should also be connected with an HDMI cable. Same for your Blu Ray player.
#2. Now that your components are connect in a way which will enable you to see their media in either 720p, 1080i or 1080p your ready to get the Digital sound to your speakers. On the back of your TV you should (again on most all HD tv's) have a digital audio (optical) out. You need to purchase a digital (optical) audio cable and plug one end into your tv's digital audio out jack. Then plug the other end into your audio receivers digital audio in jack. You may have to go into your receivers menu to select or enable the digital/optical input. Then you should be rocking and rolling with true digital DTS, Pro Logic, Pro Logic 2 in either 5.1 or 7.1...
Think of your TV as the hub. Connect all the components with HDMI cables. And then your TV to your receiver with a digital/optical cable. It's that simple.
Never never use the red and white cables for audio. They were designed for 2 channel stereo sound. They won't deliver 5.1 or 7.1 digital sound.
Also... Don't ever hook up any component using the old "yellow" video cable if you want picture quality better than 480i resolution. They won't do HD period.
Here is a list of the popular video cables and they highest resolution.
Yellow video cables - 480i resolution
S video (super video) cable - 480p
Component video cables (red/blue/green) - up to 720p
HIgh definition multimedia interface HDMI - up to 1080p (full HD) and digital sound.
Hope this helps...
Nov 03, 2012 | Onkyo Audio Players & Recorders
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
Analog only
what cables are you using ?
if you are using anything but optical or coaxial
you will only get stereo sound
Mar 28, 2009 | JVC RX-5032 Dolby/DTS 5x100 Watts Receiver...
Yamaha rx-797 w/Yamaha ge-60 eq utilizing prein/main out ..and ad
It sounds like you want to use the external amp rather than the internal one. If that is the case, just connect the output of the EQ to the input of the external amp. All you are doing is inserting the EQ between the amp stages now. Using the mx-1 rather than the internal amp is no different.
Dan
Feb 25, 2009 | Yamaha MX-D1 2-Channel Amplifier
Jvc 6500v no sub signal on soround sound
Hi, I had the same issue but if you change the front spk and center spk settings to "small" rather than large, the lower frequency is sent to the sub instead
Oct 11, 2008 | JVC RX-6500V Receiver
Jul 02, 2008 | JVC RX-9010V Receiver
PS3 with this receiver.
I dont know your reciver but if it has a hdmi input plug ps3 into it and set audio on ps3 to pcm,this will give you digital surround eg multichannel,if not you must use a optical cable from ps3 to reciver and set ps3 audio to digital.
hope this helps.
CABLE GUY.
Jun 30, 2008 | JVC RX-6030V Receiver
JVC RX-9010V Receiver Logo
42 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
