Question about Jl Audio 1000/1 Car Audio Amplifier
Need help I am getting power to the amp! but no sound is coming out of the speaker! I have a bluetooth radio. One day riding down the road some one called and I heard a pop and every since that nothing came out of the speakers since then!
    Scholar:
  • 92 Answers
If your radio and phone are synced up together, it probably muted the radio when the call came in then didn't un-mute. I'd try to reset the radio (disconnect the power for maybe 10 minutes) and try it then.
Posted on Oct 07, 2008
My Jaguar XJ Vaden plas side and rear radio speakers stopped working. What is the fix?
the norm prob is caused by the power amp gone down and burnt out the speaker coils, needs new power amp and new speakers. hope this helps
Feb 07, 2016 | Jaguar Cars & Trucks
Why dont I get sound from my speakers but the radio works
If you have an equaliser, check that you havent accidentally pressed the button which switches between the main input and aux or bluetooth. Right, if you have aftermarket sound system, check that your RCA's/(look like av cables) arent unplugged broken off or damaged. Another thing is to see if the amps come on (usually shown on amp by a green light) red if not on. Check the power wire from the battery to amp, check if fuse is not blown. Ground the amps properly for the amps to come on and check that the power cable is connected properly as well. Another fault could be blown speakers.
Dec 19, 2014 | Cars & Trucks
Pioneer avh-p8400bh
You didn't indicate what car your radio is in, whether the car has factory amps that the pioneer is integrated into or bypassing, or if you're using the radio's factory amps to power the speakers, or if you have external aftermarket amps fed from the radio's preamp outputs. So with the lack of information, it's hard to say for sure what's going on, but I would suspect either you have a radio whose internal amplifier is dying, or your car has an internal amp that's being overdriven because your pioneer's internal amp is providing a powered signal to your car's factory amp which should never be done. There's too many directions in which to go to troubleshoot this issue because you haven't said anything about the make and model of your car or it's current sound system, so I hope I've given you enough of a foundation to point you in the right direction.
Jul 05, 2017 | Car Audio & Video
There is no sound coming from the speakers, not even the bluetooth. The volume control on the steering wheel and the knob also doesn't work. The radio, cd & dvd player work fine.
So everything is coming on but you have no sound from anything?If that is the case you may want to check the amp fuse.The car has a factory amp i'm trying to remember i think it is in the trunk.Look in your owners manuel for the fuse box location.If the fuse is good then the factory amp may be bad.Or you may have a blown speaker that is showing a short and putting the amp into protect.If the amp and or speakers are bad i highly recommend just buying after market speakers/amp.The price for the factory equipment is very high and there labor rates even higher lol.Plus if properly installed you will noticed better sound from the after market stuff as long as you get brand name equipment.Go to a well trusted audio shop in your area they should be able to see if it is a speaker or amp problem if your fuses are all good.They should be able to test the impedance of the speakers at the amp for you and see what is going on.
Oct 02, 2012 | 2006 Infiniti M35
I have Tevion 43744 car stereo. No sound from radio and bluetooth doesn't connect. Are these issues related? What's the solution?
Could be some bad connections with the speakers; are you check this harnesses and wires?
Additionally, about the Bluetooth, accorrding with the Tevion 43744 User Guide... first will need PAIRING paorcedure. Press and hold BND/ID3/TEL button until the word "PAIRING" blinks on the display waiting for the bluetooth device to connect.
At this blinking time, please run the bluetooth search and connect function in your mobile phone. The car radio model no "BT Car Stereo" will be shown on the mobile phone . Select this car radio and connect. When you are asked for a connection password, please input "0000" in your mobile phone to finish the pairing, there is "PAIR OK" to show on the LCD. Then the bluetooth icon will be shown on the car radio LCD indicating that the bluetooth function is ready to use.
Hope this helps.
Aug 19, 2011 | Car Audio & Video
When I hit a bump in the road w/ my car, the radio stops playing music. The face of the radio is still lit up and has power, however no sound comes out of the speakers. Turns back on and then does the...
Thanks for choosing FixYa and welcome to the site. More then likely, you have a loose wire in the back somewhere. You will need to take the radio out and inspect the wires in the back. Look for loose wires/connections or possibly a cut wire.
Apr 19, 2011 | 2007 Toyota Camry
Screen comes up with updating bluetooth firmware & stays at 45%.
Your unit if locatiing a cell phone close by, could be yours or a friends in the car, on standing near you.
I would disable Bluetooth first, to do that go to Tools...Settings.... Bluetooth.... under Bluetooth disable then re-do your Bluetooth connection
Tools....Settings... Bluetooth .. under Connection you can remove the connection there also
If you don't have a Bluetooth connection you want to use just disable it
Nov 01, 2010 | Garmin Nuvi 760 Car GPS Receiver
I have a 2003 harley road glide with stereo. I have the rear speakers on the detachable tour pack. Also on the tour pack is a 10 or 12 pin connector to what appears to be an amp? All of the wiring is...
Front speaker output comes from the amp, which you removed with the tour pack. You will need to wire the speakers directly to the radio speaker out wires to function without the amp
Oct 06, 2010 | Harley Davidson 426290 AM/FM Radio
Radio working just fine But no sound coming from speakers
if the radio still has power the audio amplifier ic in your radio has failed.
take your radio to an electronics repair shop or, replace the radio; this not something you can fix unless you know how to use an oscilloscope.
Aug 01, 2010 | Harley Davidson 426290 AM/FM Radio
Jl Audio 1000/1 Car Audio Amplifier Logo
70 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
