Kenmore Washer Won't Drain
I have  Kenmore 70 Series Heavy Duty Plus Washer (Model 82370120 I think).
I run a load of clothes almost every night -- towels tonight, though not many. The washer filled with water, agitated, and didn't drain. When it finished (the timer went all the way around), I went to check on it and smelled something "electrical" -- like something had gotten hot. The washer is full of clothes and dirty water. I suspect the hot electrical smell developed when it tried to spin, but I don't know and won't risk spinning it again.
I've run the washer through its cycles -- it will agitate and will try to spin, but simply won't drain. Is it possible that the hose or something is clogged?
  • 2 more comments
  • nathanreed Oct 07, 2008
    Thanks for the speedy answer. So... I should remove the clothes from the washer and possibly "open up" the washer? Any clues how to get into this thing?
    You've been great! Is the door to access the filter on the back of the machine, do you think, or will I have to take the machine apart (remove console, etc)?
    A picture is worth a thousand words...
    The washer and dryer are wedged into a "nook" in my guest bath. I have no idea how they got them both in there. I know one man did it. Regardless, I managed to get the top raised on the washer. Here's what I saw:
    Here's the inside the machine on the left side where the hose seems to exit:
    Here's the inside the machine on the right side of the tub:
    This is behind the washer -- where the hose drains out I think:
    I lifte the hose out of the way -- this is a picture showing the hose exiting out the back of the washer:
    Dont' ask how, but if I create some suction, I can **** water through the drainage hose (I thought it might clear the blockage, it didn't). The problem is accessing the rear of the washer where I bet the door to access the pump is located. While one man got the washer and dryer into this "nook", I'm not sure I'll be able to get one or the other out so I can get behind the washer.
    Seeing the above, do you have any thoughts?
    I've got clean clothes for a few days, but I'd rather not call a repair man. If the pump is clogged, I should be able to fix it myself...
    Thank you so much!
  • Anonymous Mar 15, 2014
    Timer won't advance . Tried a different setting and started to work but then smelled electrical overheat. Won't work on any setting now. Is the timer the only thing to worry about? How do I check for other problems
  • 958 Answers
Yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Posted on Oct 07, 2008
  • 1 more comment
  • francis rivero Oct 07, 2008
    collect the water manually from the tub and pick up the clothes.
    there should be a door to access the filter of the water pump, find it and slowly open it up, water would come out. be careful not let water go into the center of the unit.
    from that access cover, you could probably check the water pump.
    tnx again
    drcool
    no need to remove top console, trace the drain hose, that is the outlet of the water pump, you mat have to tilt the machine to see the pump from the bottom. or could be from the front, look for a panel that could be remove.
    tnx again,
    drcool
  • francis rivero Oct 08, 2008
    thank you very much for the pictures. they were in deed very helpful.
    it seems though that you are in a very tight position.
    i guess you really have to bring the washer out of the nook and continue trouble shooting it outside where there would be room to perform what is needed.
    you will need at least 2 men to lift it up and take off the room.
    tnx again
    drcool
Kenmore 90 series washing machine, heavy duty, super capascity plus,quiet pak2 3spd motor w/5spd combo, when in spin mode, it smells like melted crayons
If drain hose is connected to a standpipe check that it's inserted no more than 4". You may be getting a syphoning situation that is allowing gray water to contaminate clean clothes.
Jan 06, 2013 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
May 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Finding Lint Filter on Kenmore 70 Series Model 110
I've got a Kenmore 70 Series, Model # 82370120 washer and the lint filter in under the machine. I had to tip the thing over to get at it.
Apr 19, 2009 | Kenmore 22422 Top Load Washer
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore top load washer
First check the oulet hose for any obvious blockages.
If you can hear the pump working fine, then check before the pump for any blockages (odd socks etc).
If the pump is making funny sounds or no sound at all, it needs clearing of any debris, and possibly replacing if faulty.
If the pump tests fine, but just doesn't work, ten the control board must be defective or a wire broken.
If this helps - please spare a moment to rate as Fixya! thanks.
Jun 20, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
939 people viewed this question
Top Washing Machines Experts
