Question about Sharp Audio Players & Recorders
My Aging GX CD1200 was recently sent in for repair but the repair shop was unable to get spares for the circuit board. I found, upon its return that they had actually fixed the problem. However, they snapped an equaliser shaft which I would like to repair. However, despite undoing all the screws I could find, I cannot get the machine apart. The base will not move but the top is quite loose. Any suggestions?
As I mentioned in my somewhat lengthy problem description, I had undone - or rather thought I had - all of the screws holding the back of machine to the front. However, even though the large screw accessible from inside the batterry cover seemed to be turning freely, the bottom section of the machine would not separate. In desperation, I changed to a finer head on my philips screwdriver and pressed it in really hard. As soon as I turned it, the bottom of the machine began to move away from the front.
So the only problem was that the screw in question had not been loosened properly. Although the initial philips head had loosened all the other screws, on close examination, it seemed worn and the new head was obviously sharp enough to do the trick.
Posted on Oct 07, 2008
Flamerite fire spare parts
This is an issue to be resolved with Flamerite.
Oct 22, 2013 | Grilling
DMTech LW19XTM LCD TV,
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 06, 2017 | Televison & Video
I have AIWA A219 TV. No remote functions are working, even manual switches are also not functioning, It got stuck on One channel, The error which is coming on screen is AGING 3CDDH
Hello
Its front panel microswitches are struk. These can be replaced. They are microswitches, which can be resoldered out from the front panel board. For this, you have to open your TV, take out the front panel after unscrewing it from the cabin, desolder one out of it and go with that microswitch as sample. You can bought it from electronic spare part shops at your town. Buy all of them and replace all at same time. This will solve your TVs problem. OK.
Jun 17, 2011 | Aiwa F2000 20" TV
I have a Canon T70 SLR and I cannot get anything to work it does not advance the film I cannot get the programs to work,I cannot set the ISO
Your only fix for this is to replace the camera. The faults you describe indicate a main circuit board failure and it's simply not economic to repair.
The spare boards are long discontinued (the camera is nearly thirty years old) and you can buy a replacement T70 body realistically for between £5 and £20 on auction websites which is far less than the repair costs if you were lucky enough to find a spare board. In reality, the camera is usually a free item attached to whatever lens it comes with (a typical recent example is item number 110487194549 .
As they're effectively worthless, they do also turn up on FreeCycle occasionally.
Sorry that I cannot offer you a quick fix, but hopefully I've saved you the time and worthless expense of repairing your camera. All that I ask in return is that you return the favour by rating my answer.
Feb 05, 2010 | Cameras
The dishwasher will not turn on
Congratulations - you found the fault !
The options you have are -
Buy areplacement board from a spares centre.
Buy a take- off board from a scrap one on Ebay.
Or - Learn about electronic repair - and identify the burnt component , buy the parts and replace it yourself.
You can take it to an electronic repair shop - if you can find one - or a electronic supply shop - and ask for a new one of "them".
If replacing a burnt component - often there is a cause other than just that component.
Experience tells you what else might be wrong to cause it.
Aug 04, 2009 | Maytag MDB9600A Jetclean II Built-in...
I have the same problem with the static and distortion
I can only assume that the unit either produces noise or no sound at all. The DSP board contains all of the digital processing circuits. Even with all surround processing turned of, the signal still passes through this board. It is possible to repair the board, but special tools and techniques are required and most shops are not set up for that level of repair. Unfortunately, the safest option is to replace the board. Inquire whether or not there is a "core" charge. This means that there is some value to the bad board that can be refunded to you upon its return to the manufacturer. With a $300 board, you may be able to recover up to $100 by returning the defective board. Dan
Jun 05, 2009 | Pioneer VSX-35TX Receiver
Unable to get spares of my mobile GX25
Typically, finding parts to fix up your mobile device is difficult to find. However, you can contact the manufacture of your mobile device and they'll have a repair and return program. Pricing is subject to the manufacture.
For Example, if My Blackberry 8700g has a cracked screen. Obviously not covered under normal manufacture's warranty. So, I send the device in to their return and repair program. Either they fix the device, or send you another one or one of equal value. As a sub topic to that, Blackberry also has a trade in program. You can trade in your RIM device to cut the cost down on a new RIM device. Very handy!! Though, they last a long time, chances are you'll be sending in a brick a get something really shiny!
For Batteries, check out your carrier's web site. They'll carry battiers, chargers, head phone adapters, and covered.
So, in close my suggestion is to go to the source. Like, if your TV stopped working, you'd call Zennith, right?
Cheers!
Feb 02, 2009 | Cell Phones
Return key
the "index" motor has gone bad or the gears have broken, will need a visit to the repair shop, or get a new one
Nov 12, 2008 | Brother GX-6750 Typewriter
Nuvi 350 cannot locate satellites
I own & operate the electronics repair company, Westek Electronics in Nashville, TN. We repair & refurbish GPS units among other things. We have repaired many nuvi 350/360 units with this issue.
This issue is typically due to a hardware malfunction and cannot be remedied by software upgrades, resetting, etc.
Do this test:
  1. Strip a ¼” of a wire twist-tie end (the kind found on bread wrappers) bare exposing the fine wire core.
  2. Power up your nuvi 350/360 and confirm that you are not receiving any signal.
  3. While still powered on, insert the bare-wire end of the twist-tie into the center female external antenna jack located on the side of the antenna. If done correctly the external antenna jack will firmly hold the twist-tie in place. You cannot damage the unit by doing this.
  4. If you now have satellite reception then proceed to step 5. If you still do not have any reception then I have no further advice other than to try all of the update/reset procedures. If all else fails return to Garmin for repair.
  5. Once you have established that you have signal using the twist-tie, remove the twist-tie and confirm signal loss.
Your choices to remedy this issue is as follows:
  1. Purchase & use an external antenna.
  2. Return the GPS to Garmin for repair ($175 if its out-of-warranty). Or,
  3. Send your Garmin Nuvi 350/360 to us for repair. We charge $55 (return shipping included) to repair this malfunction. We can also accommodate this repair transaction via eBay in order to provide you with additional reassurance (an addition $5 is added to cover eBay fees, etc. when using this option). Our eBay ID is westek_electronics, feel free to review our feedback ratings. Our repairs are covered by a 30-day warranty. If for some reason we are unable to successfully complete the repair we will return the unit to you and charge only $10 for return shipping. To initiate your repair contact us at westek12@hotmail.com.
Hope this helps.
Jul 13, 2008 | Garmin Nuvi 350 Car GPS Receiver
Lost satellite reception
This problem is not caused by poor solder joints. It's caused by a defective part. We sent a "marked" defective unit to the repair shop mentioned above and upon its return, disamantled the GPS receiver assembly and made the following evaluation:
1. The shop did NOT replace the defective component causing the initial problem in the 1st place. The defective part was STILL in the circuit.
2. The shop placed a wire jumper between the internal antenna and the external antenna port. This type of modification places a +2.5VDC bias on the internal antenna and essentially shorts the internal antenna to the external antenna (when connected), giving unpredictable results. It also affects the circuit impedance and signal strength. This is not the correct way to resolve this issue.
3. The defective part needs to be replaced with a higher rated part. This type of repair returns the unit to full functionality and allows the unit to properly switch between the internal and external antenna as it was intended to do by design
- Jim
SHARCNET-USA
Comments: I will aso add, as the part deteriorates, it becomes resistive and can eventually short out and shunt the incoming RF signal to ground......EVEN with the jumper procedure performed by the shop mentioned above.
- Jim
SHARCNET-USA
Jun 03, 2008 | Garmin nuvi 200W GPS Receiver
129 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
